Braized frame rather than welded, why?
Ribenapigeon
PostPosted: 11:05 - 30 Aug 2014    Post subject: Braized frame rather than welded, why? Reply with quote
I was watching the Motorbike Show and Henry Cole had a frame built which was braized together. Why woiuld this be done surely welding is stronger and with modern welding equipment quicker and easier?
sickpup
Old Timer
PostPosted: 11:21 - 30 Aug 2014    Post subject: Reply with quote
Brazing, especially silver soldering can be performed at a lower temperature than welding and so heat treated tubing doesn't required re-heat treating.
kramdra
PostPosted: 11:26 - 30 Aug 2014    Post subject: Reply with quote
Probably a lack of equipement or cost? Perhaps as a one-off, braising is easier to change.
Welding temperatures can weaken and stress the metal around joints. A good braised joint will be stronger than the parent metal. Modern cars are made with higher strength steels that would be weakened at weld temperatures, so braised instead.
Ribenapigeon
PostPosted: 11:36 - 30 Aug 2014    Post subject: Reply with quote
Thanks that's interesting.
davebike
PostPosted: 15:11 - 30 Aug 2014    Post subject: Reply with quote
Braising was used before modern steels were available as it did not effect the them best steel options as it occurs at a lower temperature (800/900c) but it is no where near as strong as a well made weld (2500/3000c)
More modern welding methods and better steels make it mostly redundant
Modern braising is often TIg braising carried out using a braising rod and TIG welding gear
I am set up to do this but still looking for the job to try it out on
Dave
NC750Xdct + others at work !
davebike1@gmail.com
sickpup
Old Timer
PostPosted: 22:14 - 30 Aug 2014    Post subject: Reply with quote
Incorrect, read wht I wrote above.
Davebike and Kramsa
Why would you braise steel?
Islander
PostPosted: 22:50 - 30 Aug 2014    Post subject: Reply with quote
Perhaps they're a tad peckish and anaemic into the bargain. Razz
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 51.24 Kb
