| Kickstart |
 Kickstart The Oracle
 Posted: 18:58 - 31 Aug 2014 Post subject: Electric motor controller |
I have had a google, but not sure enough of the terms to enable me to find anything useful.
We have an old electric scooter floating around. The control for speed on this is very crude (to put it politely). Effectively seems to be a series of contacts with different resistance, but the return spring on it needs to be fairly strong and this seems to sometimes try and pull the contacts apart.
I was umming and ahhing about trying to do something with it.
It could do with a better way to control speed, probably using a pulse width modulator to control it. However struggling to find something suitable for reasonable money.
Any suggestions on what might be suitable (something that works directly off a twist grip, or can easily be connected to a cable would be best) and where to source one?
| G |
 G The Voice of Reason
| Northern Monkey |
 Northern Monkey World Chat Champion
| Northern Monkey |
| G |
| Kickstart |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 20:38 - 31 Aug 2014 Post subject: |
Quickest way to see if its brushless or brushed is unfortunately to just open the motor ( think like a bigger stator motor , couple of bolts pop the back of it and look for brushes in the top ).
If it is brushless then you need a variable resistor type throttle capable of your voltage and wattage, which I GUESS FROM SIMILAR scooters to be around 24v - 500w range..
I dont think its brushless as there is no control module between the contact and the motor.
Usually brushless motors are electronically controlled to prevent burning of the coils, stalling etc.
The usually work off a small resistor or hall sensor which sends back a voltage to the controller, for example 0-5v, on my electric dirt bike 0v was flat out, and 5v was no throttle at all.
The controller picks up this voltage and then lets a pre-determined amount of voltage through to the motor, all being well if you wack open the throttle the motor will see full voltage and you will take off.
If the shaft speed sensor ( fitted to motor incase of stall - trying to do a burn-out for example) or temp sensor are relaying back problems the bike / scooter may shut-off or reduce voltage to prevent damage.
your appears to be a lot more primitive with a cable operated contact plate.
You either need to run the live wire to battery through to a variable resistance throttle and back to motor ( so the throttle can regulate how much current passes and therefore regulate the motor) - Or look for a 1/2 turn variable resistor of the correct size and fit a small arm to it - that will allow it to be operated by cable.
You could also repair the contact plate.
Easiest way would be use round headed coach bolts so the contact arm can pass over the heads smoothly, and connect each one individually to the motor ( or a common rail next to the motor ) with big resistors wired in ( more work but could be very cheap in the long run).
there is loads of resistor calculators online, and you need the first bolt to have NO CONTACT to the motor - so it gets no power. The last bolt should just be wire - no resistor so it can get full power.
Bolts in-between should have the voltage divided roughly equally.
So with 5 bolts we would have 0v,6v,12v, 18v, 24v.
It would be quicker to measure the resistance of the contacts installed and copy them though.
| G |
 Posted: 20:43 - 31 Aug 2014 Post subject: |
2 wires to the motor means it's brushed - brushless uses three wires - I believe they are basically a three phase motor, but the phases are artificially 'created' by the ESC.
2 batteries in parallel suggests 12v.
A bit of digging gets that it's probably one of these:
https://www.badsey.com/old/emx.html
As it uses two batteries I'm presuming it's not the 'racer' model, but seems the others use 24v, so batteries wired in serial, or 24v batteries (which are very rare) .
Working on 24v...
It says 1hp, so 750w.
If you were looking to use it, I'd certainly consider swapping to lithium at some point - you can get 7s (similar to 24v lead acid) lithium packs with a reasonable ah for not too much and they are significantly lighter.
This doesn't specify a price, but seems to be the sort of thing you are looking for (it does say 'low cost'):
https://www.deltasense.co.uk/products/variable-speed-drives/24v-brushed-dc-drive/
This is a more common sort of thing and suited to purpose:
https://kellycontroller.com/kds24050e50a12v-24v-mini-brushed-controller-p-72.html
Typically when power levels get up to 750w, most things are going to 36v. Also, a lot of modern stuff tends to be brushless as it offers better performance and less hassle (no brushes wearing down, which get metal dust everywhere etc).
Here's an RC one that fits the spec:
www.ebay.co.uk/itm/261554288499
However, again note that often the RC stuff isn't intended for the same use - generally it won't be dealing with sutained period of high amps, where an electric motor is more likely to - saying that, I have a feeling brushed motors may not draw so much at low rpm, where they often don't work as well as brushless.
My RC car doesn't have wheels THAT much smaller than your scoot and has more power - however if you try and use it at low rpm you either spin the wheels of flip it (will do a back flip from standing easily), so can't sustain that amp draw.
If you were spending a bit of money on, I'd consider just replacing it with something like this - https://alienpowersystem.com/shop/kits/alien-power-system-120amp-2-0kw-sensored-single-motor-kit-evolution-3/
£120 for the motor, esc and a throttle to match which gives you 2kw sensored brushless.
You would probably want to add a fan to the motor as it's pretty compact - if they get the 3kw available, that'd make more sense as it's bigger surface area will handle heat better.
They are out of stock of that one at the moment as someone ordered one a few days ago it seems. I'll report back on the findings .
First off - I think I'd just find the resistances and see if I could replace them with a pot and see what that does. Might be able to use a standard ebike throttle, or a variable pot, maybe setup to a thumb throttle for ease.
I'd be tempted to just stick an ad on endless sphere seeing if anyone wanted to buy it - wouldn't be surprised if a few were interested for the 'history' . |
| Kickstart |
 Posted: 20:49 - 31 Aug 2014 Post subject: |
That kind of setup is how it is now. Problem is that the power feed goes to the contacts from the battery, through resistors, and then makes contact with the arm. An issue is that the cable from the battery contacts with the arm but the cable is fairly hefty and needs to bend as the arm moves.
I could clean up the contacts and have it working again (subject to spending £50+ on new batteries) but would rather have it working some way without just using a bunch of resistors. Hence hoping I could find a sensibly priced PWM controller.
The other option would be to set up the contacts to just connect to a set of relays, one for each contact. Hence the actual contacts with have minimal power going through them, and also no need for the heavy cable onto the arm.
Probably should mention that this scooter is close to 20 years old.
| gavcarter |
| Kickstart |
 Posted: 21:05 - 31 Aug 2014 Post subject: |
Hi G
The one you linked to is about the right model (although this one has a seat). Closest match is the Hot Scoot.
I think they are a pair of 12 volt batteries wired in parallel. No cells are obvious to count, and no markings beyond those about charging (ie, ~13.5 volts - can't take a photo of them as there is a strap in the way that holds the 2 batteries together).
| Kickstart |
| gavcarter |
 Posted: 21:38 - 31 Aug 2014 Post subject: |
| Kickstart wrote: |
Cheers, but how is that wired up? What takes power from the battery, what pushes power to the motor and which connects to the 'throttle' grip? And why so many connections?
Keith |
Should come with badly translated instructions.
In my case, the hall sensor was called throttle so you plug that into the throttle (most are black red and a colour, so match them black - black red - red and a colour - colour).
Red and black ( thickest wires ) to battery
Yellow and Blue to motor ( either way to test, reverse if motor goes backwards )
One will more likely be an ignition and labelled as ignition or on / off etc, short it out of no ignition exists.
There will probably be a battery life / voltage / brake switches loads of other crap that is not needed.
Here is similar item with instructions included on the listing
https://www.ebay.co.uk/itm/24V-500W-motor-brush-controller-for-Electric-bicycle-scooter-e-bike-/251603544080?pt=UK_Motorcycle_Parts&hash=item3a94bd6810
1.Red & Black (large cable)
Battery connections
2.Yellow & Blue
Motor connections
3.Red & Blue
Key Switch(power lock)
(If there is no power door locks,red connection to blue)
4.Yellow & black
brake
5.Red & Yellow
Brake light
6.Red&Black(small cable)
indicator light
7.Red, Black & Blue
Speed Regulator 1-4 V(Throttle )
(Red:+5v,Black: - ,Blue :Signal Wire)
8.Red & Black (small cable)
Charger
Brake switch should be fitted if rear wheel is braked as it can damage the controller, motor if you throttle + brake at same time.
These types of controllers run right up to 2000w but get more expensive above 500w, they are all generically wired.
BE SURE TO GET THROTTLE CONNECTIONS SECURE! Mine had different plug shapes so i used mini-spades to connect them together, one came off and I was stuck on full throttle in the living room.....
I would only connect battery, motor and throttle, brake switch if you can.
Dont try and use the charging port, unless you can find exactly what batteries the controller was made for.
Lights etc are optional
[EDIT] indicator light means, voltage gauge, an led to show ignition has come on etc, could be useful to attach a cheap voltmeter to this connection. |
| Kickstart |
| G |
 Posted: 22:00 - 31 Aug 2014 Post subject: |
If they are 12v and if it is 750, then all bets are off and I think you're going to have trouble finding a controller designed to take that without it costing a fair bit - both because of the high amps and that it's uncommon.
Back on 24v, which does seem more likely for 2 batteries - parallel is generally considered a bad thing and for 12v it's unusual you'd have two batteries until you get to *big* batteries, or people being lazy when making motor-homes and the like - as in most cases you might as well just get a bigger 12v battery.
These do actually seem to have had at least a little thought behind them.
I had been searching for 'brushed', seems you get more options searching for 'brush' as per gavcarter's link - www.ebay.co.uk/itm/121169901668 - gives us a 24v rated at 700w.
I believe you would be strongly advised to avoid ones rated for 500w - as I believe that would be quite likely to result in stuff melting, possible fire and the like.
[edit] Or, maybe a little late - I'd stronger suggest checking up and consider cancelling the order - they may well have a bit of a margin, but I wouldn't really trust cheap chinese stuff running at 150% of it's rated capacity for long.[/edit]
On RC stuff they advise going for a controller rated at 125% of the motor, so you're not pushing it. Though, ebike stuff tends to be more likely to use ones listed for the power of the motor.
If you're going to spend on batteries, definitely look at lithium options. Keep an eye out on ebay, or Hobbyking have some good deals - make sure you select sort by 'UK Warehouse' or whatever, so you don't end up ordering from various other places in the world. You would then need a lithium charger, but they can be got pretty cheaply. They also have pretty impressive amp ratings - ie I was looking earlier for one to make a car jump starter and for around £40 I can get one that deliver 500 'cranking amps', which should be plenty for most stuff. |
| gavcarter |
 Posted: 23:05 - 31 Aug 2014 Post subject: |
| Kickstart wrote: | Hi
Cheers. I have ordered those bits.
Why does the throttle have 3 wires?
There is no facility for a brake light switch on the brake lever. But that bit is easy enough to fix.
That unit is 24V. But not sure what the motor is.
Keith |
Some use a positive, neg and a "reference".
So instead of putting +4v in and getting between 0 and +4v out ( two wires versions ) and acting on what is returned.
The three wires versions have +4V 0v( neg, earth) and +4v reference again.
Remember I said a 0v return is usually full throttle?
Some controllers, calculate the difference between the "reference" and the return, so if you unplug the throttle, or it breaks etc there will be 0v returning from the "reference" wire and it will know you are not holding the throttle open, so shouldn't accelerate the motor to full speed.
If you feed in 4v and get 4v back the controller know the throttle is closed and no power should go to motor.
If voltage drops, crap connection, bit of water in sensor, high motor loads sucking up voltage from the controller and you can only feed in 3v the controller will think the throttle is slightly open as its only getting a 3v return.
The third wire enable a "difference" to be drawn up and the controller usually acts on the difference between return and reference,
On the two versions there was no reference wire so unplugging a throttle meant the motor maxed out until the controller had a 4v return on that connection again.
Im guessing its either a safety feature, are more accurate way of controlling the motor ( fluctuating voltage at the sensor wont mean fluctuating power to motor as the reference wire is used to determine why) or a combination of both.
The throttle I linked to has the "extra" wire too, so it should be a case of red - red, black - black, and blue - green. I'd be surprised if they are the same shaped plugs, so you may have to connect with bullets / spades etc but it will work.
[edit] MISSED THE 750W PART! FIT A 20 AMP FUSE ON EITHER SIDE OF THE CONTROLLER, OR GET A BIGGER CONTROLLER!
Just reading G's thread above, if the motor is 750W it wont run full power on that controller. If we still don't know the motors size, I would fit a 20amp fuse on both the battery side and motor side of the controller to protect it.
If the motor draws more than 20amps (480W @ 24v) then the fuse will pop.
Personally I think it would be unlikely to be bigger than 750w, but its not impossible, most these days run about 250-300w in scooters and 500w in mini moto's.
That said it is 20 years old and probably not as efficient so could eat up 750w...... |
| Kickstart |
| gavcarter |
| Kickstart |
| G |
| Kickstart |
| gavcarter |
 Posted: 00:26 - 01 Sep 2014 Post subject: |
| G wrote: | I wonder if it should be running on 24v, but has been wired up for 12v?
If it's the ones I linked to, which seems most likely, they specify 1hp.
They also state 1500 for their faster model - which doesn't seem unreasonable for something likely a bit more of a 'premium' product for both versions than today's cheap chinese stuff.
I'd certainly expect more than 10mph - or expect it to be very nippy getting there. Have you tried it with a well charged decent size battery/batteries?
Older batteries can have pretty reduced current.
As idea, a 500w push bike hub motor will probably do around 20mph. |
I agree, kids got electric mini moto's two xmas's ago, just chinese cheapies - still did around 10-15mph with me on
here they are, only 350w https://www.ebay.co.uk/itm/Kids-Rocket-DB350-Electric-Battery-Motorbike-24v-350-Watt-Ride-On-Car-Dirt-Bike-/351099672632?pt=UK_Sporting_Goods_Scooters_LE&hash=item51bf2bd838 but very nippy.
Things is with electric motors HP and Wattage dont mean speed, they just mean torque, The motor will only do a certain rpm and no more ( without burning up).
I would wire it up as 24v and stick an ameter (check multimeter some measure amps too) on the motor feed.
If worst comes to worst the motor will die - but as G said, i would expect it to be 24v system. To get 750w out of a 12v system you need over 60 amps....2x 12v 60amp batteries in parallel
750w out of 24v system is just over 31amps so this seems a lot more likely 2x 12v 15amp batteries in series...
If the motor does need changing this sort of shape, size is more common and comes in wider choices of size
https://www.ebay.co.uk/itm/24-VOLT-300-WATT-ELECTRIC-E-SCOOTER-MOTOR-24v-300w-/400758002914?pt=UK_Sporting_Goods_Scooters_LE&hash=item5d4f09d4e2
When going in SERIES with batteries you get double voltage but same capacity i.e 12v-10ah + 12v-10ah = 24v10ah
When going in parallel you get 12v20ah as its the capacity that's doubled, not the voltage ( you've basically made the battery bigger) |
| gavcarter |
| trisers |
 trisers Scooby Slapper
 Posted: 08:12 - 01 Sep 2014 Post subject: |
| Kickstart |
The last post was made 11 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
