KTM Duke 125 not charging battery
Fangita
PostPosted: 20:28 - 02 Sep 2014    Post subject: KTM Duke 125 not charging battery Reply with quote
I have a Ktm duke 125 and it is not charging the battery when running. Thinking it may be the battery I replaced it with a new one, charged the battery using an appropriate charger overnight, but I am still getting a low battery warning. Can anyone help please?
P.
PostPosted: 20:31 - 02 Sep 2014    Post subject: Reply with quote
Get it running and check voltage across battery with a multimeter.
Fangita
PostPosted: 20:41 - 02 Sep 2014    Post subject: Reply with quote
Thanks Paddy, found a mate who's got one so I'll do that tomorrow, what voltage should I be getting while it's running?
P.
PostPosted: 20:43 - 02 Sep 2014    Post subject: Reply with quote
With a few revs, maximum about 14.5V, lowest about 13.5V really.
Idle I'd want low 13s
PostPosted: 20:54 - 02 Sep 2014    Post subject: Reply with quote
When I'm Emperor, I'm going to make remedial multimeter use step 1 of the CBT.
Fangita
PostPosted: 16:43 - 03 Sep 2014    Post subject: Reply with quote
Battery checked with a multimeter.
12.5volts max 3k-4k revs
11.26volts at idle
P.
PostPosted: 16:46 - 03 Sep 2014    Post subject: Reply with quote
11.26volts at idle
Dat regulator.
Find your regulator, check the 3 colours that are the same, set multimeter to AC volts. Check each wire with the + side of tester and put - on a bare part of the frame. Should be about 50V AC each.
If they are showing around that on all 3, or more than that, then your regulator has shit itself. If its in warranty that is definitely a job for that.
PostPosted: 16:51 - 03 Sep 2014    Post subject: Reply with quote
If it's still in warranty, I wouldn't even bother doing that. Down to the dealer (I hope it's close), say "Much fix-fix, chop chop."
Fangita
PostPosted: 18:52 - 03 Sep 2014    Post subject: Reply with quote
Out of warranty, will check the regulator tomorrow, beer and football now.
Thanks for help so far guys Smile
P.
PostPosted: 19:01 - 03 Sep 2014    Post subject: Reply with quote
Can swap for a more reliable one, let us know the output AC volts
Fangita
PostPosted: 14:27 - 04 Sep 2014    Post subject: Reply with quote
Confirmed it's the regulator at a local bike garage, going to leave it to him! Thanks for all your help guys.
P.
PostPosted: 15:37 - 04 Sep 2014    Post subject: Reply with quote
its like £60 to replace it and 5 wires, easy job but at least its solved Thumbs Up
The last post was made 11 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 69.12 Kb
