Drz 400 swing arm bolt
hondakawasaki
PostPosted: 03:56 - 06 Sep 2014    Post subject: Drz 400 swing arm bolt Reply with quote
Hello all Very Happy
So bought a drz 400 the otherr day and the swing arm bolt has damage on the first few threads of the bolt the threads on the nut look fine
The guy said he tried bash the swing arm bolt out it wouldn't budge and he ended up damaging the threads Thumbs Down
Any one have any ideas how to sort the damaged threads out?
I was thinking dremel the knackered threads but i could end up making it worse?
Or even a tap and die set, anyone know what size die could be used on the threads
Thanks for the help
PostPosted: 06:02 - 06 Sep 2014    Post subject: Reply with quote
You could try repairing the threads with a die but how much is a new bolt? By the sounds of it the bolt has seized in there which is common on off road bikes. If you need to whack it some more screw the nut on the end to protect the threads and hammer on to that.
Try and get it out and lube everything up, make it part of the maintenance schedule.
c_dug
PostPosted: 12:08 - 06 Sep 2014    Post subject: Reply with quote
As above, you may get away with running a die over it, I'd take a complete stab in the dark at it being an M10 or M12, based on nothing but educated guesswork.
c_dug
PostPosted: 12:09 - 06 Sep 2014    Post subject: Reply with quote
Your profile doesn't mention your location but if you are anywhere near London I have a huge selection of Die's here to save you buying one.
The last post was made 11 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 39.62 Kb
