AGM battery plus old car battery trickle charger?
FlightRisk
PostPosted: 12:58 - 06 Sep 2014    Post subject: AGM battery plus old car battery trickle charger? Reply with quote
My battery has gotten a bit run down and I want to give it a boost before it strands me somewhere but the only thing I have around to charge it is this old car battery charger.
The battery is a 12V 8Ah sealed AGM type.
The charger is a very old trickle charger. It has no controls, just a 6V/12V switch and an ammeter needle on the front which goes from 1 to 6A. I'm told it starts at the high end and drops lower as your battery charges.
Are these likely to play nice together or will it fVc< up my battery / explode in a shower of acid in my living room?
Honda CB500S
Robby
Dirty Old Man
PostPosted: 13:03 - 06 Sep 2014    Post subject: Reply with quote
Bike batteries are typically charged at about 1A. Charging at too high a rate may damage the battery.
You have three options.
1. Just put it on the charger, it'll probably be fine.
2. Charge the car battery, hook it up to the bike battery with jump leads, which will charge the bike battery.
3. Get a proper bike charger.
wr6133
PostPosted: 13:24 - 06 Sep 2014    Post subject: Reply with quote
I've charged motobatt AGM things with one of those £3 chargers that is little more than a plug with a couple of wires and some crocodile clips.
Zero explosions occurred, so I would imagine your charger is ok
FlightRisk
PostPosted: 14:52 - 13 Sep 2014    Post subject: Reply with quote
Hmm...
So I hooked it up, the ammeter didn't go anywhere near the 6A end. Started at 1.1A and then very quickly dropped to about 0.8A, which seems ok-ish.
But, it started to make a faint bubbling sound and then after about 5 minutes a very very faint 'tss...... tss...' sound like tiny bits of gas escaping.
I'm not sure if that's ok?
My multimeter is somewhere inaccessible with some other tools I could use. Sad
Honda CB500S
The Artist
PostPosted: 15:01 - 13 Sep 2014    Post subject: Reply with quote
Bubbling is normal but keep an eye on it. Ideally get a smart charger but a standard charger will work fine.
AGM's work on the same principle as lead acid and the hissing is just gas escaping to prevent them exploding. AGM's and Gel batteries are just VRLA's essentially.
WD Forte
PostPosted: 15:44 - 13 Sep 2014    Post subject: Reply with quote
I'd suggest you play safe and dont leave it connected for too long
until you've tested the output voltage on float charge.
Personally I'd just charge it enough to get the bike started then let the bikes system take over until i knew I could trust the old charger.
bikers smell of wee
The last post was made 12 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 46.71 Kb
