Should I expect to be a little wobbly?
markk21
PostPosted: 19:03 - 06 Sep 2014    Post subject: Should I expect to be a little wobbly? Reply with quote
I have been riding for about a week now after getting my cbt. I'm loving it but one thing I notice is that I wobble a bit when moving in slow traffic. It's not on the level where it's dangerous but I obviously would rather not be doing it. Would this be expected or do I simply need to get up to a better standard? I'm riding round on the roads as well as practising hill starts, slow riding etc. in places such as quiet car parks and roads. I have noticed that it seems that I struggle more when I purposely practice say the hill starts for example but when I do one on the road in traffic, I do okay (apart from when I was in Macclesfield the other day and stalled it on a steep hill and made a tit of myself because I couldn't find neutral). Do you have any tips on how I can improve?
Thanks!
hedgehugger
PostPosted: 19:10 - 06 Sep 2014    Post subject: Reply with quote
Simply practice.
More you ride, less you'll wobble.
When I was first riding on my CBT I'd make a point of practising 'something', be it gears, slow riding, u-turns, roundabouts, hill starts etc.
Once you get one of those to a ,mostly, respectable, proficiency, it is something less that your brain has to think about.
PostPosted: 19:17 - 06 Sep 2014    Post subject: Re: Should I expect to be a little wobbly? Reply with quote
Thanks!
It's normal to struggle at low speed.
Relax your grip on the bars. Don't keep your arms locked straight, support your body weight with your legs and bend your elbows a little. Keep on a little bit of power and control your speed with the rear brake when going very slow.
PostPosted: 19:28 - 06 Sep 2014    Post subject: Reply with quote
Light bike, narrow tyres = wobblier. Small engine with minimal inertia = easy to stall. Nothing to fret about, you're doing everything right.
When you get on to a bigger bike you'll be amazed how much easier it gets. Wink
gdj444
PostPosted: 20:15 - 06 Sep 2014    Post subject: Reply with quote
My instructor many years ago urged me to slip the clutch more at slower speeds, he said he had hardly ever had to replace a clutch in the many years he had taught, once I started using a few more revs and slipping the clutch at slower speeds it all became a little more controlled.
Jonesy
PostPosted: 20:41 - 06 Sep 2014    Post subject: Re: Should I expect to be a little wobbly? Reply with quote
Thanks!
Hibel road traffic lights? Smile
Pete.'s advice is what I do....and the clutch slippage thing.... it's almost de rigueur with a big cc twin. Also make yourself look further ahead. i.e head up.
As for not getting into neutral. First check the amount of slack in your chain.
PostPosted: 00:38 - 07 Sep 2014    Post subject: Reply with quote
Pretty much agree with Pete too. Give the engine something to work with and slip the clutch, you will have learnt slow control as part of your CBT. Get the engine buzzing it will make slow riding and moving away a lot more stable.
CaNsA
PostPosted: 00:51 - 07 Sep 2014    Post subject: Reply with quote
Keep your head up, and facing the direction you want to go.
Look ahead, not at the bit of road directly in front of you.
Relax your shoulders.
Watch these vidz.
https://www.bikechatforums.com/viewtopic.php?t=286410
Uncle fester
PostPosted: 08:15 - 07 Sep 2014    Post subject: Re: Should I expect to be a little wobbly? Reply with quote
As for not getting into neutral. First check the amount of slack in your chain.[/quote]
When you say check slack in the chain does this make it hard to find neutral? My varadero is a bugger for finding neutral.
Tomorrows another day .just as we'll at my age
markk21
PostPosted: 11:20 - 07 Sep 2014    Post subject: Reply with quote
Great advice! Thanks very much for the help guys.
Roger - yeah I wondered about whether some thing would be easier with a more powerful bike. It does get a bit annoying at times when I have to change up so quickly when riding at slow speeds although I am trying to keep the revs down until first service.
HT - yeah that's the one. I can't remember if it was at the
lights or at the roundabout. It was rush hour and I was trying to get to Knutsford and went the wrong way at the roundabout and ended up in Wilmslow eventually!
markk21
PostPosted: 00:00 - 08 Sep 2014    Post subject: Reply with quote
I went out on my bike before and tried to put into practice your advice and it really helped. I felt a lot more confident and was much more steady at lights, roundabouts etc.. Thanks again guys!
ADSrox0r
PostPosted: 06:23 - 08 Sep 2014    Post subject: Reply with quote
It's pretty much the same as riding a horse, use more knees and arse and your grip on the reins slackens automatically and she responds in a more relaxed manner.
matto
PostPosted: 01:55 - 11 Sep 2014    Post subject: Reply with quote
For slow speed control the best thing is to slip the clutch as mentioned above but use the rear brake (and only the rear brake) to control speed. It keeps the drive train/chain under tension thus making slow speed control very smooth.
A slack chain and just clutch control can make for very jerky progress, so can using the front brake to bring yourself to a stop as you load the forks which then release upwards as you arrive at a stop.
Also as mentioned above a slack chain can cause all sorts of gearbox annoyances, difficulty in getting neutral, dropping out of gear, false neutrals etc, Honda's seem to be quite picky about chain tension.
PostPosted: 06:18 - 11 Sep 2014    Post subject: Reply with quote
I never slip the clutch for slow speed riding on my Bandit. Most bikes will move at pretty-much walking pace on idle, if I have to go slower than that I just pull the clutch in and roll to a stop. I think that clutch-slipping is just adding a new complication for a novice rider.
Wonko The Sane
PostPosted: 07:36 - 11 Sep 2014    Post subject: Reply with quote
For slow speed, especially going up hill I have to slip the clutch a bit on the ZZR. Think it depends on the bike and how smooth it's tickover is.
Stobo91
PostPosted: 09:23 - 11 Sep 2014    Post subject: Reply with quote
I did my CBT about 2 months ago now and im still wobbly at times but nowhere near as bad as when i first went out by myself. I haven't helped myself by forgetting all i had learned and picked up some bad habits.
Slow speed stuff i was just sticking it in first gear with clutch out and feathering the throttle but this really doesn't work on a 125 with a slack chain. I also rarely used my rear brake (squeals like mad and hardly has any bite, needs replacing asap). Makes for really jerky slow speed movement.
Now im getting the hang of riding the clutch and keeping my feet up to guide me through slow speed manouvers and when filtering.
Rear brake is still shagged but i will start to implement that when ive had it replaced.
Thanks for the point about the slack chain causing gear issues etc. My YBR125 ocasionally slips out of gear and false neturals quite abit so will look at tightening it up.
Wonko The Sane
PostPosted: 09:37 - 11 Sep 2014    Post subject: Reply with quote
Check your bikes handbook on adjusting your chain, too tight and you can damage components. There should be an amount of slack to allow suspension movement - on my bike it's 3cm when the bike is on its centre stand - it'll be different on yours!
When setting off don't rush too much to get your foot up, don't leave it too long but don't panic about it.
My 125 I could come to an almost stop on it after commuting daily on it for 6 months with my feet up and set off again smoothly, it's taken 1.5 years to get to that point on my current bike, if I change bikes I'll need to re-learn for that bike
matto
PostPosted: 10:35 - 11 Sep 2014    Post subject: Reply with quote
Letting a bike roll on idle doesn't give you completely smooth control though, certainly on some of the newer stuff that are really very snappy around closed throttle due to some silly settings to meet emission regulations.
I disagree that it's an added complication, keeping your hands still while controlling speed with your right foot is way easier for a learner... once they have practised it a little anyway.
markk21
PostPosted: 16:47 - 11 Sep 2014    Post subject: Reply with quote
Thanks for the extra advice. I haven't tried slipping the clutch yet but will give it a go.
Today I bought some lighter gloves as I had very thick winter gloves and I was sweating in them and the gloves and my hands stunk. As the new gloves are much lighter they are much more comfortable to wear but what was such a pleasant surprise was how much easier it is to ride with them. The whole feel is better and I find it much easier to use the clutch and the front brake now. I feel more confident riding with the new gloves and as a result my whole overall riding is much more smooth
Stobo91
PostPosted: 16:52 - 11 Sep 2014    Post subject: Reply with quote
I tried a few pairs on in the shop and i agree, the thinner lighter (cheaper Very Happy) gloves felt alot better on my hand and gave more control. Been great so far but these early morning rides have been bloody cold on the fingertips! Already not looking forward to winter and its bloody September!
PostPosted: 17:15 - 11 Sep 2014    Post subject: Reply with quote
You missed the 'roll to a stop' and 'below walking pace' bits I guess.
The last post was made 12 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 123.42 Kb
