I swear my bike is possessed..........
mudcow007
PostPosted: 21:29 - 10 Sep 2014    Post subject: I swear my bike is possessed.......... Reply with quote
So, cast your minds back 2 weeks ago. i receive a tank through the post, i clean out my carbs an all is well with my bike...Oh how we laughed as all of my running woes were behind me
fast forward to tonight, i arrange to go to a bike meet at a local pub (Scotch Piper), as my bike has been all good since fitting the new tank/ cleaning carbs etc get as far as bickerstaff an the bike is hesitating an then lunging all over the place an really rough idle
we arrange to meet up with other people at a garage, so pull in an stop the bike, sat there for 20mins or so, go to start the bike an nothing...it turns over but doesn't even try to start, notice there is white smoke from exhaust (doesn't smell like oil - but has a weird horrid smell)
finally get it going with a bump, on the motorway going back it wont go over 70, after i stopped at a set of lights its back to normal (going past 70)
when i get home its rough again spluttering in low revs an generally being a fuckwit
any ideas before i set it on fire
oh an sorry for the epically long post.....
HotdogMcDraw
PostPosted: 21:49 - 10 Sep 2014    Post subject: Reply with quote
could be the float needle valve is out of alignment or sticking. Had this problem on my previous bike when it had the same problems as you (white smoke, spluttering etc). Unless someone else corrects me you might have to look at the carb again.
https://www.bikechatforums.com/viewtopic.php?t=284963 - What to expect on a MOD 1 (contains video footage) - Posted by BG5067
Honda Rebel 125 (L Plate Warrior) - Nov 2013 to Aug 2014, BMW G650 GS ABS - Aug 2014 to Current
SQL
PostPosted: 22:02 - 10 Sep 2014    Post subject: Reply with quote
Have you changed the fuel tap? I know mine is rough if running low on fuel maybe that's clogging it up
mudcow007
PostPosted: 22:05 - 10 Sep 2014    Post subject: Reply with quote
thats a point actually, i have replaced the tap, but havent cleaned it since the last tank (which had a dissolving tank liner fitted) will have a look at that cheers
quite annoying as i brimmed the tank tonight aswell grr
Wonko The Sane
PostPosted: 22:17 - 10 Sep 2014    Post subject: Reply with quote
Cheap petrol can + length of hose from B&Q is how I drain my tank when needed.
map
Mr Calendar
PostPosted: 22:25 - 10 Sep 2014    Post subject: Reply with quote
That's a euphemism isn't it. Still, I wouldn't like to criticise another's wank techniques.
Robby
Dirty Old Man
PostPosted: 08:32 - 11 Sep 2014    Post subject: Reply with quote
Water in the carb(s). Drain into a receptacle, look for evidence of water.
If you find water, drain the first half gallon out of the tank with the tap set to reserve. Water is heavy, it sits on the bottom of the tank. Separate off the water, pour the fuel back in the tank, and add a cupful of meths. Meths will bind with water and provide something with a fighting chance of igniting when mixed with enough petrol.
mudcow007
PostPosted: 08:43 - 11 Sep 2014    Post subject: Reply with quote
on the way back last night (after we bumped it)
coming down the slip road onto the motorway it wasn't exactly quick, but it was still pulling, i got to 70 an went into 6th where the revs started to die, drop to fifth an the revs came back up but the throttle was pinned an it was going no faster
if that helps!?
map
Mr Calendar
PostPosted: 09:38 - 11 Sep 2014    Post subject: Reply with quote
mudcow007 wrote:
...i got to 70 an went into 6th where the revs started to die, drop to fifth an the revs came back up but the throttle was pinned an it was going no faster...
If this was a few months on I'd say those symptoms could describe carb icing. So a fuelling issue. So in the carb/fuel tap/some gunge in there area?
mudcow007
PostPosted: 10:34 - 11 Sep 2014    Post subject: Reply with quote
cheers map
i will take the carbs an tank off again at the weekend, admittingly i havent cleaned the tap out since swapping the tank, maybe a bit of the sludgy line was in the tap an has now clogged a jet or float....maybe?
its getting on my tits though
austin460
PostPosted: 21:27 - 13 Sep 2014    Post subject: Reply with quote
Partially blocked tank breather?
mudcow007
PostPosted: 11:58 - 22 Sep 2014    Post subject: Reply with quote
having left my bike alone for nearly 2 weeks, i tried to start it yesterday, first press of the button it starts an idles...
Evil or Very Mad
the only thing i have done is left my battery on my optimate thingy
i think i need to get probing
PostPosted: 12:59 - 22 Sep 2014    Post subject: Reply with quote
A good probe will make you feel better if nothing else... Whistle
MattEMulsion
PostPosted: 21:51 - 22 Sep 2014    Post subject: Reply with quote
What bike is it???
Yamaha YZF-R6
mudcow007
PostPosted: 08:53 - 23 Sep 2014    Post subject: Reply with quote
mk1 600 bandit
The last post was made 11 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 86.02 Kb
