| kerr |
 kerr World Chat Champion
| map |
 map Mr Calendar
 Posted: 17:07 - 11 Sep 2014 Post subject: |
Greenhouse heater? The paraffin type was first thing in my head for a heat source.
Or just get very good insulation, top, bottom and sides. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| stevo as b4 |
| gavcarter |
 gavcarter Could Be A Chat Bot
| gavcarter |
| stinkwheel |
 Posted: 18:36 - 11 Sep 2014 Post subject: |
Insulation is the solution to condensation, not heating.
If you make the walls a poor conductor of heat, you'll not have trouble with condensation.
Ply lining with fibreglass underneath would be ideal but possibly a bit pricey. WOuld stop it turning into an oven in the summer too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| gavcarter |
 Posted: 18:42 - 11 Sep 2014 Post subject: |
Skim read first post, just thought he wanted heat lol....
rockwool can be had for nout if you keep looking, there always some left over at builds etc , or just steal it out of the loft and then it get new stuff put back in on one of these government grant schemes that keep knocking at the door  |
| kerr |
 Posted: 20:13 - 11 Sep 2014 Post subject: |
Fibreglass? rockwool? fuck me im going to be busy
Not even dug the garden up for the slabs yet, severely dislike gardening.
The shed has currently got polystyrene on the roof and walls, its hanging off the walls though, is it up to the job, or would the reflective stuff do a better job?
As for the greenhouse heater, someone mentioned it to me, just gives out an ickle bit of heat, my thinking was covering the bike in a cotton dust sheet in the winter with the heater underneath the bike. ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
| Northern Monkey |
 Northern Monkey World Chat Champion
 Posted: 20:19 - 11 Sep 2014 Post subject: |
| kerr wrote: | Fibreglass? rockwool? fuck me im going to be busy
As for the greenhouse heater, someone mentioned it to me, just gives out an ickle bit of heat, my thinking was covering the bike in a cotton dust sheet in the winter with the heater underneath the bike. |
Paraffin heater will produce water vapour as it burns, which isn't ideal if the aim is to keep the shed dry ____________________ Fisty: after polishing the tank with the glistenng beads of sweat from my full hot scrotum, I filled the headrace bearings with 10cc of my manmilk |
| kerr |
 Posted: 20:50 - 11 Sep 2014 Post subject: |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 21:09 - 11 Sep 2014 Post subject: |
I spent 5 mins putting some stupid post together about lighting and lumens per watt and costs of units, advantages / disadvantages etc then pressed ctrl+w and lost it.
In short. Consider getting HID floodlight. Either Metal Halide (White/blue light) or High Pressure Sodium (Yellow).
Bang for buck, they can't be beaten and they are compact.
I've got a 250w MH for £53
HPS slightly more at £54 |
| kerr |
 Posted: 21:18 - 11 Sep 2014 Post subject: |
| Pigeon wrote: | I spent 5 mins putting some stupid post together about lighting and lumens per watt and costs of units, advantages / disadvantages etc then pressed ctrl+w and lost it.
Interesting, so would one of them be cheap enough to run?
Say if she's doing my nut and i need to "go work on something"  ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
| Pigeon |
 Posted: 22:05 - 11 Sep 2014 Post subject: |
You could go for the 150w @ £40
It uses a different bulb fitting, which is smaller (both in size and watts) and cheaper, but with less output.
250w HPS @ 28,000 lumens = 112 lumens/watt
250w MH @ 20,500 lumens = 82 lumens/watts
150w HPS @ 15,000 lumens = 100 lumens/watt
150w MH @ 12,500 lumens = 83 lumens/watt
70w HPS @ 5,300 lumens = 75 lumens/watt
70w MH @ 6,000 lumens = 85 lumens/watt
70w Flourescent @ 6,000 lumens = 85 lumens/watt
Generally, as the wattage increases, the efficiency increases also. Although this peaks around 600watts and falls away a little.
Florescent tubes are still comparable in terms of effciency (but not effectiveness). A 70w tube is 85 lumens per watt, same as 70watt Metal Halide. But tubes don't really go higher than 70w without getting much more expensive.
You could buy that 150w metal halide. £40, includes the bulb. It's compact, won't mind being wet.
Looking at running costs, assuming 15p / kWh for electric. It costs you 15p per 1,000 watts.
Roughly speaking 15p buys:
70w = 14 hours 15 minutes (1.05p/hour)
150w = 6 hours 30 minutes (2.25p/hour)
250w = 4 hours (3.75p/hour)
If I were doing a metal shed. I'd go with the 150w metal halide. Cheap to buy and to run, compact design and easy to fit.
150w bulb will cost around 2.25p an hour. Seems pretty good.
You could buy two 70w florescent tubes, but it would cost double, they are both 6ft long AND while the coverage may be 12,000 lumens to match the MH, the penetration won't be. The light diminishes away from the tube. Two 6,000 lumen tubes are not going give the depth of 1 12,000 lumen bulb.
One downside of HID's. They are not meant to be turned on/off every 5mins. In fact, once switched off, you should not attempt to re-start them for 30minutes, otherwise you are likely to blow the bulb!
They also get HOT. But because these are floodlights, the bulb is behind glass.
EDIT:
Oh, and they also take 1-2 minutes to reach full power. When first turned on, they are worse than "energy saving" bulbs, no light for 20 seconds. Then 2 minutes to get the full effect. |
| kerr |
 Posted: 23:38 - 11 Sep 2014 Post subject: |
| Pigeon wrote: | You could go for the 150w @ £40
EDIT:
Cheers for that  ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
| kramdra |
 kramdra World Chat Champion
 Posted: 01:42 - 12 Sep 2014 Post subject: |
That is a lot of light your talking about. How big is this metal shed?!?!?
My recommendation would be a couple of power LEDs. Plenty of choice, they are cheap, last forever and will light up a normal sized car garage like a UFO has landed in it I dare say a 250w HID would be blinding, consider that a normal house bulb has about 700 lumens and most rooms use only one.
A Cree XML does work very nicely, the 12v variety are ideal for connecting to a spare bike or car battery. I have a small solar panel on roof to keep battery topped up as its 50 meters from house. These use 5-20 watts so battery lasts a very long time.
I have mine attached with a flexible foamy/wire/bendything so it can also be pointed where needed.
Small disadvanage that it is a point light source, it would be better to have several lower power LEDs spread out to prevent shadows. |
| Robby |
 Robby Dirty Old Man
| janner_10 |
 janner_10 World Chat Champion
 Posted: 11:18 - 12 Sep 2014 Post subject: |
As Kramdra says, either a simple battery set up or use 12v LEDs and a simple cheap driver.
I would avoid the halide idea, they will convert much more power into heat than the LEDs and the life will be much less in hrs compared to LEDs. Plus you will be blinded with that light in a shed.
For mine I used 5 m of https://www.ebay.co.uk/itm/3528-5050-1M-3M-5M-Waterproof-Cool-White-LED-STRIP-LIGHT-for-Bright-Supermarket-/301242793075?pt=UK_Home_Garden_Night_Lights_Fairy_Lights&var=&hash=item4623783c73
which came with the driver and I cut into strips and stuck to the roof and placed an odd 1m strip above the bench - if you are handy with the soldering iron you can cut them to any length and just daisy chain them anywhere.
Any simple mains frost heater will do the job and as said, definitely bung some old carpet tiles on the floor. I found some on gumtree that were used and free to collector! ____________________ Yamaha FZS600 (Now gone to heaven) > CBR600F4i (SOLD) > '99 YZF-R1 |
| J4mes |
 J4mes World Chat Champion
| Northern Monkey |
| iooi |
 iooi Super Spammer
| kerr |
| Pigeon |
| kerr |
| Pigeon |
| Vincent |
 Vincent Banned
 Posted: 01:48 - 14 Sep 2014 Post subject: |
Modern parrafin heaters are pretty good and, unlike the old ones, give off little smell or condensation apart from when being fired up. I have one and run it outside for 5 mins before bringing it in and it's fine.
Google "Zibro Kamin"...they do excellent programmable convection heaters.
Best bet might be a small multi-fuel stove though  ____________________ Space Is Deep |
The last post was made 12 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
