| daslandroverm... |
 daslandroverm... Derestricted Danger
| WD Forte |
 WD Forte World Chat Champion
| daslandroverm... |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 14:03 - 11 Sep 2014 Post subject: |
It maybe a Woodruff's key problem,which is a metal wedge that holds the flywheel on the crankend.
Its common for them to be tightened up while not fully in the slot , using big spanners to tighten the flywheel bolt just flattens em.
Remove the flywheel and check the key and the slot. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| daslandroverm... |
| unitynotsocri... |
 Posted: 12:19 - 12 Sep 2014 Post subject: |
Just remember map and Chinese flywheels , and most other cg copy stuff is not compatible .Early Honda cg s had 6 volt electrics and the flywheels are not comparable with later cg s. .
Make sure the Woodruff's key is OK and the flywheel is correct for the engine. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| daslandroverm... |
| unitynotsocri... |
 Posted: 21:25 - 14 Sep 2014 Post subject: |
Handy hint........buy two Woodruff's keys.
When tightening up the flywheel keep your eye on alignment.Many a duffo haaaave gone mad with a tourque wrench or scaffold bar on the flywheel bolt..........without checking the key sits right...
Good luck. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| daslandroverm... |
The last post was made 12 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
