Zontes Panther 125 no power
Robbiebung
PostPosted: 11:42 - 15 Sep 2014    Post subject: Zontes Panther 125 no power Reply with quote
Hi all,
Firstly apologies if this is super simple but I am pretty new to bikes.
Went to ride to work this morning and found this cable (pictures attached) hanging loose at the side of my bike. The bike gets no power at all. I have taken both side panels and the seat off and can't see anywhere that this should connect to, any ideas?
Thanks,
Rob
PostPosted: 11:50 - 15 Sep 2014    Post subject: Reply with quote
No idea on cable, but dat chain Shocked
mentalboy
PostPosted: 11:52 - 15 Sep 2014    Post subject: Reply with quote
See that kickstand in the background? The unit bolts to the kickstand bolt (hence the threaded hole in the bolt)
It's your cut out switch and has come unbolted, the bike won't start unless you put it back
Make mine a Corona.
Robbiebung
PostPosted: 11:57 - 15 Sep 2014    Post subject: Reply with quote
Great, thanks mentalboy - will it be a specific bolt I need to reattach or can I just buy one?
mentalboy
PostPosted: 12:13 - 15 Sep 2014    Post subject: Reply with quote
Anything you can find to fit the thread in the sidestand bolt will do the trick. It's not a part that needs cranking down really tight or load bearing so anything that will hold the part in place will do.
It should only locate in one possible position so there's not much chance of getting it wrong.
Make mine a Corona.
Robbiebung
PostPosted: 12:21 - 15 Sep 2014    Post subject: Reply with quote
Brilliant, thank you mate.
The last post was made 12 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 45.78 Kb
