ACF50 or FS365?
Itchy
PostPosted: 18:03 - 15 Sep 2014    Post subject: ACF50 or FS365? Reply with quote
So which one should be used? as my first British winter in a while is coming up. (HK winters are 17C if it drops below 13C an alert is issued and old people are given money for heating).
I always used to use FS365 and tbh it worked after a ride a quick spray on exposed parts and blind spray through fairing gaps. It keeps a protective layer of crud on the bike which washes off.
While I read a lot about ACF50 these days and the fact it can cause a cinema floor type stickiness on the bike and can form a black film which requires something called washing with some sort of chemical called shampoo to remove.
Tests like this don't help
https://f2mcltd.blogspot.co.uk/2012/01/winter-salt-protection-acf50-fs365-or.html
As the steel was sprayed with salty water but the FS365 was not re-applied after each ride.
Boris the spider
PostPosted: 18:09 - 15 Sep 2014    Post subject: Reply with quote
I have used ACF50 the past 2 winters on the YBR.
Works just a treat.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
iooi
PostPosted: 18:10 - 15 Sep 2014    Post subject: Reply with quote
ACF 50 Thumbs Up
Put it on and forget
ws4936
PostPosted: 18:36 - 15 Sep 2014    Post subject: Re: ACF50 or FS365? Reply with quote
Itchy wrote:
It was this link that made me go with acf50, good stuff, like purple translucent oil, pretty much the same viscosity so it's not a spray on and leave, more like a spray on a cloth and wipe and leave.
Acf50 from me too Thumbs Up
If everything seems under control, you're just not going fast enough.
James83
PostPosted: 18:41 - 15 Sep 2014    Post subject: Reply with quote
I was reading up about ACF 50 as I have my first can on order. On one of the forums I was reading, the bloke that runs the all year biker company posted up on his experience with it. One of the things he mentioned was that if the ACF 50 is sticky, it means too much has been applied. It only needs "2 one/thousandths of an inch" - more than that and it just kind of sits on top of itself and congeals into a jelly that holds dirt. If you get the right amount on, it should be a smooth as glass, and water should bead off it when rinsed, taking the dirt with it.
He also said that rather than spray it on the bike directly, spray it onto a microfiber cloth and apply it like that. Apparently you can keep said cloth in a zip lock and use it for touch ups without respraying it. For hard to reach areas, spray into the lid until you have a little in liquid form, and use a thin paint brush.
Jonathan A wrote: tart.
ACF50 cos it smells bootiful.
2 ACF soaked rags, 1 for bodywork other for bolts and nuts.
Fisty
PostPosted: 18:45 - 15 Sep 2014    Post subject: Reply with quote
Does that attract the laaaaaaaydees? ACF on your bodywork and nuts?
Fatter and faster than Fret
Northern Monkey
PostPosted: 18:47 - 15 Sep 2014    Post subject: Reply with quote
ACF50 works really well, but it WILL make your bike look like shit after a few days.
The crap sits on top of the ACF50, making everything look dirty. In spring, when you wash it all off, it's clean underneath
Flatbadger
PostPosted: 18:48 - 15 Sep 2014    Post subject: Reply with quote
ACF50 here but I've learned my lesson - I found that my saddle came up a treat, and I'm still getting it off nearly a year later Laughing
You're in ISIS
j00pY
PostPosted: 18:56 - 15 Sep 2014    Post subject: Reply with quote
I'm surprised you can sit on it without sliding off!
PostPosted: 19:24 - 15 Sep 2014    Post subject: Reply with quote
No, I'm afraid it seems to attract men in smelly textiles...but what the heck..at my age I'm not choosy.
Flatbadger
PostPosted: 19:48 - 15 Sep 2014    Post subject: Reply with quote
Quite the opposite, it's a filthy goo now but it's getting easier to scrape off! It's reapplied by my textile trousers Rolling Eyes with the next scraping I'll give them a good scrub on the legs - I did the arse last time. This is what it's like - beware!
You're in ISIS
doggone
PostPosted: 19:51 - 15 Sep 2014    Post subject: Reply with quote
iooi wrote:
ACF 50 Thumbs Up
How long does it last?
Is once a year enough, or can you stretch it further if you don't try to wash it off?
Barnoe
PostPosted: 23:08 - 15 Sep 2014    Post subject: Reply with quote
And how hard is it to wash off when you want it off?
we talking power washers?
or soap and sponge kinda wash?
You know you are old when you're told to slow down by your doctor and not the police.
Pigeon
PostPosted: 23:36 - 15 Sep 2014    Post subject: Reply with quote
I use both. FS365 all over the metal bits. ACF50 on the lower 1/3 that gets hit by road spray.
Dave70
PostPosted: 23:41 - 15 Sep 2014    Post subject: Reply with quote
I used it through last winter and it worked a treat.
I sprayed it into the lid and applied with a cloth and used a small paintbrush for harder to reach places. I think I also just gave it a blast straight from the can in one or two areas as well.
As has been said, the bike looked filthy before too long, as I used it every day for commuting. I'd re-apply a bit every now and then to some of the more exposed parts of the bike.
As for removing it come the better weather, it wasn't a problem. I just used muc off with a sponge and warm water like I always do and underneath all the crud that had built up over winter, was a shiny, rust free bike. I also was living by the sea at the time too, so it had the extra salt to deal with.
WD Forte
PostPosted: 01:18 - 16 Sep 2014    Post subject: Reply with quote
ACF50
bikers smell of wee
talkToTheHat
PostPosted: 04:33 - 16 Sep 2014    Post subject: Reply with quote
Muc off and a cloth/brush/sponge/gentle hose will strip acf50. Dont put too much on your rims or it will be all over your tyres. Apply to smooth surfaces with a cloth. Power washer entirely unnecessary. Keeps my chromed out monstrosity looking filthy but rust free. I ride through pretty much anything except ice, and caked in road salt is a frequent look.
Bandit. does. everything.
Wull
PostPosted: 05:35 - 16 Sep 2014    Post subject: Reply with quote
I've used acf50 for a few years now and its great stuff,tbh I don't ride in harsh weather anymore,don't need to and don't use it as much these days.
As above,water based degreasers will remove the acf50,usually you can tell if you still have a good coating of the stuff as the water beads when you wash the bike,or when it rains,once it stops doing this its time to reapply.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Northern Monkey
PostPosted: 07:36 - 16 Sep 2014    Post subject: Reply with quote
My handy acf tip is to make sure you dont accidentaly spray in on the disks Embarassed
Dave70
PostPosted: 08:54 - 16 Sep 2014    Post subject: Reply with quote
Laughing I bet that was an interesting experience.
iooi
PostPosted: 09:10 - 16 Sep 2014    Post subject: Reply with quote
What is this word wash??????
Just normal car wash stuff will do..
But the whole point is you don't want to take it off... You let it build up a layer of protection Thumbs Up
Northern Monkey
PostPosted: 09:16 - 16 Sep 2014    Post subject: Reply with quote
It was the back disk, not the front, but it did reduce the effectiveness just a little
DrSnoosnoo
PostPosted: 09:20 - 16 Sep 2014    Post subject: Reply with quote
My handy tip, after doing anything, lubey/oily etc. give your disks and calipers a quick blast with brake cleaner.
blackbosh
PostPosted: 09:32 - 16 Sep 2014    Post subject: Reply with quote
So after buying some acf50 after recommendations from people in actual real life I dont have a clue what Im doing with it. Is it true i spray it on leave it whole winter and wash it off the muck in spring? Cause if thats the case my clean freak mate will go apeshit if he sees my bike covered in road salt, saying that I wont see him in winter as hes a fair weather guy
The last post was made 12 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 130.93 Kb
