| cc123 |
 cc123 Geez a joab?
| instigator |
 instigator Super Spammer
 Posted: 11:06 - 19 Jan 2005 Post subject: |
I'll listen in on this one as well. My foot peg hangers are scuffed to buggery by my boots and has worn away some of the finish to leave it shinier underneath.
If anyone can ADD to this topic about what you can and can't polish, thatd be great, as I'm going to do my "Not for road use" this weekend with some autosol, just want to make sure I can do other bits. Particularly the footpeg hangers.
cheers
P.S Sorry for barging in on your topic, but best kill 2 birds with one stone, eh?  |
| cc123 |
 cc123 Geez a joab?
| BLOFLY 636 |
 BLOFLY 636 Brolly Dolly
 Posted: 11:33 - 19 Jan 2005 Post subject: |
I have recently learned how to polish metal! the way I learned is if you were to polish a upper tripple clamp you would remove the part from your bike and place it in a bench vise padded with some soft pine to hold it firmly. Then use either a heat gun or hair dryer depending on the size of the area you want to polish for example a larger area will take a while to polish and could burn the hairdryer out. Start by gently warming the area to a good hot temperature to soften any paint and oxides on the metal surface then begin some hand polishing with some Oven cleaner working over each surface several times to work the oxides out and produce a bright shine the secret is to keep the surface quite hot like 80 degrees celcius after thorough polishing this way then it is time to apply one or two coats of a reputable metal polish such as Autosol and buff to a high shine. I have seen a hayabusa with almost every part polished this way and it looks absolutely TART! by that I mean it looks bloody brilliant  ____________________ Those bloody footpegs......they ought to do away with em! |
| cc123 |
 cc123 Geez a joab?
 Posted: 11:39 - 19 Jan 2005 Post subject: |
What about an Allly frame? I take it there is some mess when polishing metal surfaces?
I'm taking the rear pegs off soon, think it's an idea to maybe experiment with one first before attacking the bigger parts? Or just pay someone to do it!  ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| BLOFLY 636 |
 Posted: 11:46 - 19 Jan 2005 Post subject: |
a good test to do is find a part off a bike or even a bit of scrap metal or alloy and try it out and see how it all goes I believe it works very well on all bikes though as the hayabusa is also an alloy frame ____________________ Those bloody footpegs......they ought to do away with em! |
| BLOFLY 636 |
 Posted: 11:49 - 19 Jan 2005 Post subject: |
or even better try it on a pillion peg! the oven cleaner works like a very fine cutting compound to remove small pitts and oxides and leave a fresh polished surface  ____________________ Those bloody footpegs......they ought to do away with em! |
| cc123 |
 cc123 Geez a joab?
| Frost |
 Frost World Chat Champion
| cc123 |
 cc123 Geez a joab?
| Big Pete |
 Big Pete Spanner Monkey
| Bendy |
 Bendy Mrs Sensible
| cc123 |
 cc123 Geez a joab?
 Posted: 15:29 - 19 Jan 2005 Post subject: |
I did consider that fact about crashed bikes with polished frames.
Didn't know it needed as much care during the winter tho, kinda puts me off a bit as I ride on crappy days too. ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
 Posted: 17:24 - 19 Jan 2005 Post subject: |
Poished alloy is a SERIOUS pain in the arse on a bike that you ride on anything but the sunniest of days. I would give the frame in the picture a maximum of eight hours to look like it has sprouted a fur coat if I rode it the 9 miles home from work tonight.
I polished one of my wheel rims the other day, came out next morning and it looked like I had never touched it. I did it again and soaked it in 30:1 2-stroke pre-mix on the basis that it has kept my mates MZ trophy alloy rims pristine for longer than I have been alive. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 21 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
