| FlightRisk |
 FlightRisk Spanner Monkey
 Posted: 13:13 - 17 Sep 2014 Post subject: Braided hose vs. master cylinder rebuild? |
My front brake on the CB500 is still not where I would like it to be after cleaning the caliper and replacing the fluid.
Despite doing the tie the lever overnight trick the brake is still a bit spongey and the lever comes back quite far before getting firm.
The pads are fine, the disc is worn and probably needs replacing soon but it's not warped, I see no signs of fluid leaking anywhere.
I'm wondering what to do next, I was going to order a HEL braided line but I don't want to be replacing bits for bling sake. For the same money I could order a master cylinder rebuild kit. I need a cheap fix really.
Any chance just stripping and cleaning the m/c and caliper might fix this?
What say the BCF braking team? ____________________ Honda CB500S |
| Itchy |
 Itchy Super Spammer
 Posted: 13:16 - 17 Sep 2014 Post subject: |
Re-bleed the master cylinder and the whole system.
A lot of people stop bleeding the brakes once the big bubbles are out of the system leaving it spongy.
You need to keep bleeding them until all the tiny bubbles are gone, meaning the overnight thing is not required. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Busa1340R |
 Busa1340R Nova Slayer
 Posted: 13:27 - 17 Sep 2014 Post subject: |
Have you a reason to suspect the master cylinder is at fault. Has the bike got high mileage or been used a lot for town work?
Does the lever come right back to the bar if held on for a while?
You may be suprised at how much difference a new disc makes, it doesn't necessarily need to be warped. A dished disc can also cause lever travel.
I suspect a braided line and maybe a pressure bleed may help, but could also mask the real problem. ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 22:40 - 17 Sep 2014 Post subject: |
Keith has it spot on again.
Strip it, get a trusted car/bike garage, engineers, someone clever to blow your pistons out, do not use pliers unless of the internal variety specific to brake piston removal (these are shit, anyway). I have dedicated piston pullers, but even these have had only limited success on cacked calipers. Not worth the dosh, for a one off.
I may be going against the grain on this forum, but use red rubber grease when installing your NEW seals, as brake fluid is hygroscopic, why attract moisture to where you least want it..? Get the braided hose, works wonders on shite brakes (like mine, which are now awesome). Clean, clean, clean. You may find the need for a bit of a rub down and a blow over. You will be amazed. Take your time, and enjoy it, don't break out heavy tools and check the many videos on youtube.
As amazed as I was when Itchy posted the above re; bleeding, and did not once mention China or HK! Good advice, there. |
| davebike |
 davebike World Chat Champion
| steveh |
 steveh World Chat Champion
 Posted: 08:13 - 18 Sep 2014 Post subject: |
| bern wrote: | Keith has it spot on again.
All true ^ but depending on the caliper it can be alot easier to push the pistons out under the force of the hydraulic line before you strip it, remove pads, pins etc and pump the brake untill both pistons are nearly falling out, if one is stuck, use mole grips, or some kind of clamp to hold the free one, and pump the sticking one out.
A collegue of mine used compressed air to blow one out once.. he lost a fingernail.  ____________________ Current : 06 Zx10r, 07 Wr450f SM, 74 850 norton commando, 63 bsa b40, 1962 Triton 650, 67 Triumph Tr6r, 1955 Triton 750, 1978 TY250E. |
| FlightRisk |
| FlightRisk |
| MCN. |
 MCN. Banned
 Posted: 13:21 - 18 Sep 2014 Post subject: |
Or as I once saw, drill through from the back of the caliper so you can drift the piston out, then tap the hole so you can stick a bolt in the caliper (with a copper washer under it mind you). Sickening  |
| Dalemac |
 Dalemac World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 21:17 - 18 Sep 2014 Post subject: |
I might be late, but I had a chance to experience the difference between OEM brake hose and the braided one on a 98 CB500 (Brembo calipers on both wheels) and I say braided hoses are overrated, at least on that bike. The performance was worse, the lever got far too hard to be used sensibly and it gave you no real control of the brake.
If you want a ''proper front brake'' take MC and caliper from a sportbike, although I think the OEM caliper and MC on the CB500 is sufficient enough. Also having progressive springs will also increase the front brake performance.
It all comes down to your personal feel and taste. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| FlightRisk |
| FlightRisk |
| Taught2BCauti... |
 Posted: 06:56 - 19 Sep 2014 Post subject: |
Try gripping the brake hose tightly with one hand, whilst applying the brake with the other. If you can feel the hose swelling, you will definitely benefit from fitting braided hoses.  ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| matto |
 matto Crazy Courier
| Dalemac |
| stirlinggaz |
| MattEMulsion |
 MattEMulsion World Chat Champion
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
