O2 sensor wont unplug :|
thekeeper199
PostPosted: 18:51 - 19 Sep 2014    Post subject: O2 sensor wont unplug :| Reply with quote
hi im trying to put the o2 sensor bypasser for my klx250s.
but the stupid connection cannot be unpluged Neutral
Busa1340R
PostPosted: 19:20 - 19 Sep 2014    Post subject: Reply with quote
That ought to come apart easy enough.
Firmly press the plastic tab top right of block marked A side facing you in photo.
Firmly push the two halves of the connector together, you may feel/hear a bit of a click and then pull apart.
It may be easier to remove the connector from the metal bracket by gently prising out the plastic retainer on the back of block A.
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
thekeeper199
PostPosted: 19:45 - 19 Sep 2014    Post subject: Reply with quote
hmm well i didnt see a press tab on the connector.. i tried just pulling.. ill check again.
i wanted to remove the connector from the metal bracket but the connection of the 2 connectors dont allow.. when connection removed u have the space to pull it outside ..
thanks for the reply! ill update
ADSrox0r
PostPosted: 20:15 - 19 Sep 2014    Post subject: Reply with quote
Yup, it'll be a tab you need to pry and pull at the same time. I bled fuck out of my knuckles trying to get the diagnostic connector cap off on the VFR before I realised there was a tab under there.
Sheer cuntishness; that's why they put them there.
Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30
thekeeper199
PostPosted: 07:32 - 20 Sep 2014    Post subject: Reply with quote
yup a tab it was... right where you said. thanks!
The last post was made 12 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 43.65 Kb
