Tidy Tidy Query
Snipet
PostPosted: 17:41 - 19 Sep 2014    Post subject: Tidy Tidy Query Reply with quote
Hello peep and peepesses,
Im wanting to get a tail tidy for my GSX650F, to take it from this hideous hunk of plastic:
https://s2.postimg.org/cg510bxwp/740184e0bb83a0122b4df7b438aac37f.jpg
To this tidy piece of ass (It does come with bracket for plate and indicators):
https://s30.postimg.org/f0rnapg1d/GSX650_FUndertail_Shotgun_Fitted.jpg
But Im curious, as the rear light changes completely, would I have to do some sort of re-wiring to get it to work. Or would it come with the correct wire attachment/fitting.
Ive never fitted a tidy before, so a bit nervous about cutting up my existing one to get this one fitted.
First Bike: Pulse Rage 125cc Second Bike: Kymco KR Sport 125cc Third Bike: Kawasaki ZR7-S 750cc
Forth Bike Honda VFR 750cc Fifth Bike Honda NT650 Deauville Fifth Bike Suzuki GSX650F
jeddy11
PostPosted: 18:10 - 19 Sep 2014    Post subject: Reply with quote
Probably will be some wire chopping and re crimping needed but shouldn't be too difficult.
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Snipet
PostPosted: 18:39 - 19 Sep 2014    Post subject: Reply with quote
Thought that might be the case, guess I'll have to find someone with some experience to help install it.
and blame if it fucks up, hehe.
janner_10
PostPosted: 18:42 - 19 Sep 2014    Post subject: Reply with quote
I bought pretty much the same thing for my CBR - it was a case of snip and re-solder.
You just need a cheap soldering iron, some snips/wire strippers/cutters and about 10cm of heat shrink.
All available from Maplins / Ebay etc
talkToTheHat
PostPosted: 23:17 - 19 Sep 2014    Post subject: Reply with quote
If it's a part you might need to take off, consider bullet connectors or modern waterproof connectors rather than permantly soldering it all. Even better if you can re-use your existing lights connectors.
Bandit. does. everything.
Taught2BCauti...
PostPosted: 08:02 - 20 Sep 2014    Post subject: Reply with quote
I would use a 'SuperSeal' connector and solder the wires on each side.
A 3-way should be enough for the stop/tail lamps - 5-way if you include the indicators.
Clicky
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MattEMulsion
PostPosted: 08:27 - 20 Sep 2014    Post subject: Reply with quote
Where abouts are the indicators on that tail tidy? If they are the ones that are integrated into the rear lights AND makes the rear light flash red & orange when you indicate they are illegal. The main problem being at MOT time. Just bear it in mind...
Yamaha YZF-R6
Snipet
PostPosted: 10:56 - 20 Sep 2014    Post subject: Reply with quote
Comes with a simple bracket, so should look like this afterwards:
https://s12.postimg.org/m5uqfsqi5/tailguardjpg.jpg
MattEMulsion
PostPosted: 20:31 - 20 Sep 2014    Post subject: Reply with quote
Vincent wrote:
OP wrote:
........it does come with bracket and plate for indicators
Haha, I'll give you that one... Laughing
Yamaha YZF-R6
WD Forte
PostPosted: 23:26 - 20 Sep 2014    Post subject: Reply with quote
OK Ok, I'm a boring old fart but
The existing lights are much more visible/sensible than
those 'sexy' looking ones.
The partially recessed rear lights have a much narrower field of of view than the original ones and
if the water clear led indicators are anything like the ones I had,
they're pretty useless in bright daylight.
As the whole point of rear lights is to inform other road users
of your presence and intentions, the new one reduce this effect and
if anyone doesn't see you brake or indicate prior to changing
speed or direction, it could be down to your choice of lights.
For me, its always function over form, not the other way round
and I'd go for 'in your face' stuff not pretty wee lights.
bikers smell of wee
Snipet
PostPosted: 21:23 - 23 Sep 2014    Post subject: Reply with quote
Yeah I know, but the old one is just so..........Plastic.
I have some indicators already which are bigger than those little ones.
And i've gone for the bulb version over the LED ones as i've heard they are a bit brighter on the brake lights (not sure how true that is).
Wonko The Sane
PostPosted: 21:31 - 23 Sep 2014    Post subject: Reply with quote
I agree, I occasionally follow someone with a similar tail / light set up on my way home from work and they're not that easy to spot until you're nearly upon them, both filtering and flowing traffic.
WD Forte
PostPosted: 00:43 - 24 Sep 2014    Post subject: Reply with quote
What I found with those water clear yellow leds was they looked small and shiny off and just got a bit shinier when in use.
No contrast y'see?
I put yellow lens tape over them and found they caught the eye better in bright light when going from a dull orange to bright yellow.
bikers smell of wee
The last post was made 11 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.18 - MySQL Queries: 13 - Page Size: 84.68 Kb
