| Az |
 Az World Chat Champion
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 15:39 - 20 Sep 2014 Post subject: |
Move to the outside of the corner (so on a right hand bend, move left, left hand bend move out towards the white line but be ready to move back across if needed) so that you can see further round the corner sooner
Basically, move on the road to get the furthest view up the road. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| notbike |
 notbike World Chat Champion
 Posted: 15:40 - 20 Sep 2014 Post subject: |
Look at the tree line, if the tree line seems to cut right across the bend then it is tightening. if the tree line seems to be gentle or seems to "open up" as you're entering the bend then it's probably a gentle bend. I dunno how to explain it that great but RoadCraftNottingham has a video on it on youtube which explains it a lot better than I did check him out.
Stop comfort braking, judge your speed into the bend. That group probably practices the same bends over and over so they know the "feel" of the bend and can get all their entry/lines/exit speeds without thinking about it.
Just ride within your comfort zone, go at your own pace, if you lose em then oh well more practice!
Edit again: Nevermind, The Shaggy D.A. posted the video link just below
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 15:41 - 20 Sep 2014 Post subject: |
Might be preaching to the choir, but have you heard of the vanishing point?
[edit] two replies whilst I looked for the video, this is the one Meef referred to. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| CaNsA |
 CaNsA Super Spammer
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 16:29 - 20 Sep 2014 Post subject: |
Depends on the corner. Some I'll pile into on the front brake, a fraction of a second to let things settle, then throw it in (tight corners I'm familiar with). More open, but still can't see where it's going, I'll use more engine braking, drop a gear or two; less need to let things settle this way, and gives you greater flexibility to adjust as you see how things go.
If it's a bend you don't know, always better to go in too slow, in a lower gear, use acceleration to drive out hard. You've heard "slow in, fast out"?
Bear in mind there are no prizes for getting around bends fast on the road; only a rewarding feeling from getting it right. Find a good mix of different corners near you, practice them so that you'll have more idea when you come into unfamiliar territory. As others have said, use clues like the vanishing point, looking across the bend when it's not obscured by trees etc, shift your weight before you tip in, look at where you want the bike to go, rather than where you don't want to! But never go flat out into corners you don't know.
And not forgetting, keep it smooth!
My bet is also on others in your group knowing the roads better. Also, if they're on light sports bikes with quality shocks etc, you'll find it harder on a Bandit. Doesn't mean it can't be done though!
A little summary: corner approaching, blip the throttle on the downshifts (usually one or two) whilst simultaneously shifting your weight to the appropriate side, and lining up your approach to give you maximum view; use all of the available lane where it is safe to do so, going in as wide as you can (on the road, not always possible). All that done, now you can tip into the corner, watching the vanishing point for your guide as to where it's going. When that vanishing point starts to move away from you, the corner is opening up and you can get back on the throttle. The throttle should not be off through the corner; rather neutral (not changing) or gently feeding in to adjust (good reason for "slow in"). Off throttle means less control of the bike.
But an unfamiliar corner can start to ease and then tighten again, so it's a question of constantly reading it, and adjusting as required.
If it tightens up unexpectedly, you can use a little exaggerated counter-steering to get the bike round; push forwards on the inside bar, effectively steering out of the corner (counter-intuitive, but this is how your bike goes around a corner even when you're not aware you're doing it). Practice this at slower speeds on corners you know to get a feel for it.
There are always places and situations on the road where you can't get it perfect or things suddenly change (e.g. due to other road users); you have to be ready for this. I'd say always keep a little in hand, i.e. don't ever be right on the limit, so you have choices when this happens.
I seem to remember you didn't do too badly two-up in Wales  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| CestrianX |
 CestrianX Renault 5 Driver
| esullivan |
 esullivan Could Be A Chat Bot
| barrkel |
 barrkel World Chat Champion
 Posted: 18:10 - 20 Sep 2014 Post subject: |
Do a bike tour through northern Spain. You'll get more bend reading practice in a week there than a year in the UK. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Wonko The Sane |
| chickenstrip |
 Posted: 18:16 - 20 Sep 2014 Post subject: |
| barrkel wrote: | Do a bike tour through northern Spain. You'll get more bend reading practice in a week there than a year in England. |
FTFY
Or keep going up and down the A483 from Newtown to Crossgates for the same effect. Or most of the roads in Wales for that matter  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| barrkel |
 Posted: 18:47 - 20 Sep 2014 Post subject: |
| chickenstrip wrote: | Or most of the roads in Wales for that matter  |
Almost everybody I know who's been to Wales came back with points on their license. I'm not keen to play
PS: I've been through Wales twice on my way to the ferry from Holyhead, but I took it easy, and the weather wasn't great either. I think the roads in the UK are almost all too narrow, and there's almost a hedge fetish for limiting visibility. The roads - and the weather - in Spain are better than everywhere else I've seen, including the Alps, Germany, Italy, Austria, Croatia, etc.
Meanwhile, going to Scotland in the hopes of getting good weather is a gamble that rarely pays off. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| thomp1983 |
 thomp1983 Crazy Courier
| CG Sam |
 CG Sam Crazy Courier
| mentalboy |
 mentalboy World Chat Champion
| Sload |
 Sload World Chat Champion
| MCN. |
 MCN. Banned
| Teflon-Mike |
 Posted: 21:30 - 20 Sep 2014 Post subject: |
"Always ride at a speed in which you can safely stop, in the distance you can see to be clear'.....
Are you sure its YOU that is doing it wrong?
Lot of folk pile into bends faster than is prudent, 'cos ninety-nine times out of a hundred on that or similar bend, there's never been anything in the space they cant see they have needed to haul up for.... Hindsight, is 20/20 "I could have taken that bend flat out"... is only granted after you have seen the whole picture, not before. & Its a dangerouse thing to try and rate your own riding by others; you can easily learn their faults as their strengths.
So back to the initial proposition of the highway code...Always ride at a speed at which you can stop in the distance you can see to be clear... so how can you increase the distance you can see?
Usually bends are less than 90 degrees, and eve with hedges either side, you should e able to see through them, to see they are clear. So only on tighter turns you will have a 'vanishing point' where the road ahead disappears from view ... as you approach, the vanishing point will be getting closer... distance you can see to be clear getting shorter... so you probably aught be slowing down.... and continuing to slow, right up until that vanishing point starts to go away from you and the distance you can see to be clear is increase, not reducing....
Next step is to ride for sight lines, so as to maximise the distance you can see to be clear, as has bee mentioned, 'edging' to left or right of centre, so you can see more of the corer before you get to it, then, as has also been mentioned NOT turning your corners before you reach them.
99% of people turn long before they need to; which takes you into the corner earlier strangling your sight line, as well as reducing the time and space you have to do anything differently, and pick the best line and speed, and frequently demands a mid-corner change, as initial 'early' line is to wide or too tight.
Next time you are at at a set of traffic lights; watch the cars turning right into the road next to you; invariably, they will start steering towards their exit the moment they pass the give way line, rather than going 'straight' those extra few feet that's the width of the left hand lane you are sat in; if they take it in one wide curve, they are probably a couple of cars lengths past the give way you are sat at, before they are straight; more often though they will realise they are turning too soon, so straighten up, go diagonally a little, then have to make another turn into the exit. If they JUST went that extra cars length or so first, 'straight', they would have more space and time, before they had to turn into potentially on-coming traffic; they could make one, neat, tight turn into their exit, and be accelerating two, three cars lengths earlier, spending less time in the 'danger-zone' as well as being better able to see any danger, d do anything about it.
Now, don't sweat country roads and trying to read them. Ponder, this 'early turning'' business, and round-town, try it. When you are at a set of lights turning right, DON'T turn straight from the give way; stay straight to the middle of the road you are entering, then make the turn in one, short shot. That's the principle here; and in that situation you can see more readily how it works, and how much extra time and space you can make, not 'rushing' your corners.
It's easy to get the sense of it round town junctions, where you have nice road markings, central bollards and the like to give you easy references to see how it works, and all hopefully at friendly speeds.
The you can start applying it on country roads. Finding your OWN sight lines, making your OWN road room, remembering the rule, to ride at speed in which you can stop in the distance you can see... not at the speed some-one else might, in which they may or may not be able to stop in the distance THEY can see, which may or may not be the same space YOU can either see OR stop in! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:59 - 20 Sep 2014 Post subject: |
| Solyent Blue wrote: | Agression is king. |
Grove Street is king.
Teffers is quoting Roadcraft, not the Highway Code, but his meds are working tonight.
If "fast ride" means someone else's pace, let them do a tank slapper.
If you want to up your pace, book a track day. ____________________ Biking is 1/20th as dangerous as horse riding.
| evoboy |
 evoboy World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:23 - 22 Sep 2014 Post subject: |
Try a trackday to gain confidence just dont push it too far, its better to be slower than a corpse.. they move super slow. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Mario_Kempes |
 Mario_Kempes Trackday Trickster
| Skudd |
 Skudd Super Spammer
| SteveSmith |
 SteveSmith Nitrous Nuisance
The last post was made 12 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
