| Wabby |
 Wabby Trackday Trickster
 Posted: 17:45 - 17 Sep 2014 Post subject: |
They are indeed the same rim size as 700c, (ISO standard 622 rims) although perhaps wider. So you CAN use 700c road tyres BUT you will probably need the wider-end ones.
Fitting a 700c tyre WILL leave you with a smaller rolling diameter though because the profile is lower. This means you'll be slightly lowering your gearing by fitting them.
If I was putting road tyres on my 29"er, I'd bung a set of Michelin World tours on there. They do them in 700x35C. They will look odd on your MTB. They are cheap. You will not burst them or wear them out because they were designed for hardcore cycle touring.
You should also be able to use 28" road tyres. These also fit on a 622 rim. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| FlightRisk |
 FlightRisk Spanner Monkey
| Seb |
 Seb World Chat Champion
| mudcow007 |
 mudcow007 World Chat Champion
| sickpup |
 sickpup Old Timer
The last post was made 12 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
