Honda cbf 1000 loud bang when knocking up into second gear.
WULFSTAN
PostPosted: 20:34 - 22 Sep 2014    Post subject: Honda cbf 1000 loud bang when knocking up into second gear. Reply with quote
hello like title says really if i rev 1st up to say 8k revs it don't seem to do it as much any help would be appreciated
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Copycat73
PostPosted: 21:12 - 22 Sep 2014    Post subject: Reply with quote
oil level correct ?
fresh oil ?
caveat emptor
WULFSTAN
PostPosted: 21:15 - 22 Sep 2014    Post subject: Reply with quote
Copycat73 wrote:
oil level correct ?
fresh oil ?
Yes to both
Copycat73
PostPosted: 21:18 - 22 Sep 2014    Post subject: Reply with quote
hydraulic or cable clutch adjusted correctly ?
stood for a while ?
drive chain tension correct ?
caveat emptor
WULFSTAN
PostPosted: 21:36 - 22 Sep 2014    Post subject: Reply with quote
stood for a while ?
Hydraulic and fluid is fresh used everyday and chain tension is about right.
moonzoomer
PostPosted: 23:59 - 22 Sep 2014    Post subject: Reply with quote
WULFSTAN wrote:
stood for a while ?
Check that the clutch is not dragging and that the clutch fluid level and Clutch pushrod operation is correct allowing the clutch to lift fully between gear changes (front sprocket cover casing), another possible cause is that the clutch simply needs bleed but that might point to a leak in the hydraulic system so well worth a look before doing anything drastic.
temeluchus
PostPosted: 01:07 - 23 Sep 2014    Post subject: Reply with quote
remove the clutch slave cylinder and clamp the piston back so it cannot move (with a u clamp or similar). This will greatly aid bkeeding the clutch system. it is very hard to get a hydraulic clutch to work correctly without doing this.
The last post was made 11 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 53.36 Kb
