Bolts suitable for brakes?
AzzA1990
PostPosted: 20:45 - 23 Sep 2014    Post subject: Bolts suitable for brakes? Reply with quote
I need to replace all 6 bolts that that hold my rear disc onto the wheel
I have been told not to use stainless steel bolts how ever the only bolts i can find that look identical to the original ones are either A2 or A4 stainless steal or high tensile 10.9?
Does anyone know what type of material manufactures use for there brake bolts?
Thanks
AzzA1990
PostPosted: 20:49 - 23 Sep 2014    Post subject: Reply with quote
Have just found these i need the M6 20mm, any good?
https://www.ebay.co.uk/itm/M3-M4-M6-M8-SOCKET-BUTTON-HEAD-ALLEN-KEY-SCREW-BOLTS-HIGH-TENSILE-12-9-ZINC-/121365388812?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item1c41f0de0c
Aff
PostPosted: 20:57 - 23 Sep 2014    Post subject: Reply with quote
10.9 grade bolts will most likely be what is on there from the factory.
Electric Bike Project
Robby
Dirty Old Man
PostPosted: 06:14 - 24 Sep 2014    Post subject: Reply with quote
Either use the originals, or get new ones from the manufacturer. Not advise I would usually give, but shear strength is important for brake bolts.
bugeye_bob
PostPosted: 08:34 - 24 Sep 2014    Post subject: Reply with quote
As said Buy new steel as stainless is very soft,
I've replaced a lot on a show car and I used stainless on a lot of bits but titanium On suspension etc where it was required.
PostPosted: 12:48 - 24 Sep 2014    Post subject: Reply with quote
You are aware that titanium is also weaker than high tensile steel?
It's a lot lighter than steel and it is stronger per unit weight. A steel M8 bolt is stronger than an M8 titanium bolt. An M10 titanium bolt is both stronger and lighter than an M8 steel one.
Titanium parts should ideally be bigger and chunkier than their steel equivalent.
The last post was made 11 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 47.8 Kb
