| sickpup |
 sickpup Old Timer
| bamt |
 bamt World Chat Champion
| sickpup |
 sickpup Old Timer
| BravoCharlie |
 BravoCharlie World Chat Champion
 Posted: 21:23 - 28 Sep 2014 Post subject: |
watching with interest. bloody scrotes who vandalised it
what's the overall plan? planning on a respray to the same colour or something else? ____________________ Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today. |
| Furrybiker |
 Furrybiker Trackday Trickster
| sickpup |
 sickpup Old Timer
| Ichy |
 Ichy World Chat Champion
 Posted: 22:11 - 28 Sep 2014 Post subject: |
Nice.
I've owned 3 lightweights and a few series 2a station wagons. I've tended to go for newer versions over the last few years but I'm currently considering a hybrid 1a with a Tdi front end. These things will last forever with a bit of maintenance. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| sickpup |
 sickpup Old Timer
| Tamsin |
 Tamsin World Chat Champion
| nisp |
 nisp Scooby Slapper
 Posted: 22:19 - 29 Sep 2014 Post subject: |
love a good land rover restoration. if it was mine i would leave it in military trim because...... thats how it was made  ____________________ Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976 |
| bikertomm |
 bikertomm World Chat Champion
| Ste |
 Ste Not Work Safe
 Posted: 22:29 - 29 Sep 2014 Post subject: |
Cool thread, am watching and waiting with interest.  |
| groovylee |
 groovylee World Chat Champion
 Posted: 07:54 - 30 Sep 2014 Post subject: |
looks awesome mate, good luck with it. will be watching with interest  ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| map |
 map Mr Calendar
 Posted: 09:09 - 30 Sep 2014 Post subject: |
Good work, looking forward to seeing it at the end.
One thing about Krust is I've always found it needs coating. Tried just leaving and rust is visible after a short while. Coated with primer and a dash of paint and looked good a while longer.
Unless they've changed the formula and can now leave? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Nexus Icon |
| sickpup |
 sickpup Old Timer
| Teflon-Mike |
 Posted: 16:29 - 30 Sep 2014 Post subject: |
Those slave cyls say 'Girling' on them. DONT chuck'em!
If were me, I wouldn't bother buying replacement cyls; chances are you'll end up with Brit-Part pattern replacements, which are notorious.
BUT, for only a few pence, you can still get the Girling overhaul kits, ad they will usually clean up and rebuild 'better' than pattern replacements for the sake of a little time faffing.
Do you have the green bible SIII Repair Overhaul Manual and the Military Air-Portable supplement? If not I believe John Craddocks has reprints of both.
On the notion of your high-ratio X-Fer box; Conversion was done by Turners I think; basically they machine the drop cogs in the X-Fer and turn them upside down inverting the ratio's.. Basically it gives you 30% taller hi-ratio, and most opinion is that it is TOO high, it makes 1st almost as tall as 2nd without up gear. It's best suited to low reving diesel conversions, that have the low down grunt to pull the gear, but not the revs to make the speed, like the old Commer four-pot oil burners that used to get chucked these things in the 80's & 90's. You also loose the PTO port & ability to add an O-D or winch or anything. Plus pulling that box is a bastard!
The 'Cheap' alternative to a Hi-Rat X-Fer is to use 'Coiler' diffs. (90/110, Disco or Range-Rover) These were expensive & hard to obtain in years past, but now there's so many rotted out Disco's littering the streets, cheap ad easy. 3.5:a crown set rather than 4.7:1 they give a 25% increase in overall ratio, but on all ranges. It's not quite so tall, but has advantage it's not as expensive or hard to do, they drop straight into Rover Axles, and doesn't make pulling away quite so judery.
BUT, my advice would be to leave it stock; particularly if you are going gas. Power loss from gas isn't that significant, but you do loose throttle response, so low speed and round town driving with tall cogs could be an even bigger ball-ache than these things already are.
Real solution is an Over-Drive, and they are 'good'... another stem in the forest of levers and something else to fiddle-with on the move! Loads of fun n the (masocistic) Landy spirit.
HOWEVER.. while you are down there looking at the axles, and before spendig much more money on anything like brakes... there lies the other lightweight anomoly to the narrowed series bulkhead you are salvaging... your axle tubes are likewise narrowed and WELDED. Series axles have stub-axles bolted on the ends for the wheel bearings (would recomend you recondition while you are the vacinity, esp if car stood so long) yours are welded on; as is the swivel housing on the front axle, with the chrome ball, notorious for pitting and flaking like a spherical motorbike stanchion.
Common and 'Easy' salvage for an old lightweight with knackered axles is to simply fit Stock SIII axles, improves track width and makes serviceability easier, BUT will spoil the originality of your Landy if it has such great providence.
Bulkhead as you have discovered is tin almost any mig-monkey might salvage with tin-snips and time.... but the axles are another matter, and could be the difference between a viable resto or not. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| chris-red |
| Copycat73 |
 Copycat73 World Chat Champion
| nowhere.elysium |
 Posted: 17:49 - 30 Sep 2014 Post subject: |
| sickpup wrote: | | nowhere.elysium wrote: | Looks fun. Gizzashout if you want an extra pair of hands. |
I'm sorry, you thought you have a choice in this?  | I was only trying to give you the graceful alternative to flat out-demands, pup My mate Bob has also got a full set of manuals which will most likely cover this model, as well as many years' experience working on these, so I'm sure we can dragoon him into it as well, if you like.
Fridays OK by you? I'm free all day this Friday, although it'll only be half-days from next week onwards, since my course starts then. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| chris-red |
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
| nowhere.elysium |
The last post was made 12 years, 6 days ago. Instead of replying here, would creating a new thread be more useful? |
