Bye Clutch!
Az
PostPosted: 20:03 - 30 Sep 2014    Post subject: Bye Clutch! Reply with quote
So... I think my clutch is dead.
Riding along, there's traffic in front of me, so I slow down and pull my clutch in and bang it in first.
Before I reach the traffic I see that I can filter, so I go to release my clutch... and there's nothing there, it's just 100% play in my clutch lever. My lever felt as if my clutch cable wasn't attached/snapped.
I assumed my clutch cable had snapped, coasted to the side of the road and inspected. My cable was fine and there was tension at both ends, so it hasn't snapped in the middle either.
I call my RAC breakdown (courtesy of MCE Karma ) and have it recovered home free of charge.
The breakdown guy seems to think it's the clutch that's gone.
What do BCF think my problem is? What parts do/may I need? Do I need a mechanic to do it, baring in mind I'm a complete mechanical noob?
ripzay
PostPosted: 20:11 - 30 Sep 2014    Post subject: Reply with quote
Assuming the Bandit 600 here based on my experience there are essentially 4 failure points.. And generally in this order:
1 clutch cable - which you have rules out.
2 springs / bolts
3 push rod (behind the front sprocket cover)
4 actuator worst (dunno proper name - on the front sprocket cover)
I'd check all 4 but start with the external ones (1,3,4) - just need to take the front sprocket cover off to check these. then take the clutch cover off and check the springs, bolts and washers, you can do this without dropping the oil on the Bandit if it is on the side stand.
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
Taught2BCauti...
PostPosted: 20:14 - 30 Sep 2014    Post subject: Reply with quote
If you look at the gearbox end of the clutch cable, you should see where it turns a shaft that goes into the gearbox, as you squeeze the clutch lever with your hand.
It could be that this shaft, or the pushrod it connects with, has snapped inside the gearbox.
There are some videos on YouTube for "changing a motorcycle clutch" that will show you where these parts are and how they work.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Az
PostPosted: 20:19 - 30 Sep 2014    Post subject: Reply with quote
If this pushrod has snapped inside the gearbox, how big of a problem is it?
PostPosted: 20:22 - 30 Sep 2014    Post subject: Reply with quote
Sounds like the release mechanism has gummed up solid or fell apart. Clutches don't usually 'go' just like that unless the basket fails or something. If you pulled the lever and it stayed in I'd look under the sprocket cover first.
Az
PostPosted: 22:41 - 30 Sep 2014    Post subject: Reply with quote
Will have a look tomorrow after work, hopefully it's nothing too serious and I can get it back on the road ASAP.
orac
PostPosted: 12:45 - 01 Oct 2014    Post subject: Reply with quote
from past experience they little actuator thing behind the front sprocket cover fails.
were the cable attaches to it is were it normally fails
https://www.ebay.co.uk/itm/GENUINE-SUZUKI-GSF600-GSF-600-K4-BANDIT-2005-CLUTCH-WORM-ACTUATOR-FREE-UK-POST-/191342296674?pt=UK_Motorcycle_Parts_13&hash=item2c8ce3be62
PostPosted: 14:49 - 01 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
If it's not the cable my moneys on the worm gear. Those things are pricks.
Thumbs Up Thumbs Up Agree
Az
PostPosted: 18:29 - 01 Oct 2014    Post subject: Reply with quote
Push rod was snapped in half although I can't see why the pushrod would cause there to be no tention in the clutch cable ?
Edit: also cleaned up the inside of my sprocket cover, as it was shockingly dirty. Putting it all back together in a bit to see what happens.
PostPosted: 18:40 - 01 Oct 2014    Post subject: Reply with quote
The worm gear is likely overdue some serious grease anyway Laughing However... I wouldn't remove if its working, it can shit itself and go everywhere.
Az
PostPosted: 21:37 - 01 Oct 2014    Post subject: Reply with quote
The worm gear seems fully functional, it turns freely and does that little spring back and forth motion when i was twisting it. I'll still grease it up though when this clutch push rod arrives on Friday.
PostPosted: 21:57 - 01 Oct 2014    Post subject: Reply with quote
Is unusual, but if the mechanism was gummed up it might not have been returning all the ways out and kept a bit of tension on the pushrod and you could still have a loose cable. Are any of the ends of the rod blackened from spin-welding?
Az
PostPosted: 22:04 - 01 Oct 2014    Post subject: Reply with quote
IIRC the ends seem fairly clean, I didn't notice any blackening but then again I didn't look out for it either. I'll have a look tomorrow, or Friday latest and report back.
PostPosted: 12:47 - 02 Oct 2014    Post subject: Reply with quote
Ok so there's probably nothing wrong with your clutch pushrod, it doesn't pass through the engine in one piece anyway.
Az
PostPosted: 23:43 - 03 Oct 2014    Post subject: Reply with quote
I believe it's No.16 on that diagram snapped (it's roughly 8cm in length). It's been replaced now and the bikes all good.
Thanks for all the replies Thumbs Up
Az
PostPosted: 15:39 - 06 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
Pics plz.
I'll post one up later tonight, i'm 98% sure it's No.16. This is the part that I ordered and had replaced, now the bike works.
The last post was made 12 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 107.39 Kb
