HELP! At work in Dudley with a siezed rear brake...
Slacker24seve...
PostPosted: 09:44 - 01 Oct 2014    Post subject: HELP! At work in Dudley with a siezed rear brake... Reply with quote
...and I need to get home to Worcester.
Bike's toolkit is pathetic, was going to take the sliding pin out and remove the pads but I've chewed the cap that goes over the pin (if you've seen a Nissin caliper you'll know what I mean)
Does anyone local have the tools so I can take the whole bloody thing off just to get home?
Banger rallies are ace
monkeybiker
PostPosted: 09:49 - 01 Oct 2014    Post subject: Reply with quote
Can't you get a taxi? If it's a long way home then a taxi to shops and get a spanner and cable ties to hold brake out of way.
raesewell
PostPosted: 09:56 - 01 Oct 2014    Post subject: Reply with quote
Call the AA
Yamaha FJR 1300 Normanton West Yorkshire
Slacker24seve...
PostPosted: 10:08 - 01 Oct 2014    Post subject: Reply with quote
mpd72 wrote:
Sometimes just loosening the calliper mount bolts a couple of turns will be enough to free it up as a temporary get you home bodge. Surely someone at work has a spanner or Allen key of the correct size in a car?
Sounds like a winner Thumbs Up
richfar
PostPosted: 10:12 - 01 Oct 2014    Post subject: Reply with quote
Try pushing bike backwards a few feet, worked for me then rode home not using back brake.
Tarmacsurfer
PostPosted: 10:34 - 01 Oct 2014    Post subject: Reply with quote
Get this sorted?
I'm immortal. Well, so far.
mgh0
PostPosted: 10:50 - 01 Oct 2014    Post subject: Reply with quote
I'm pretty local to dudley, got lots of tools.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
PostPosted: 11:15 - 01 Oct 2014    Post subject: Reply with quote
Could you undo the banjo/nipple to let the fluid out then lever the piston(s) back in with a screwdriver/bit of flat bar?
jimbopea
PostPosted: 11:21 - 01 Oct 2014    Post subject: Reply with quote
when this happened to my er5 front brake i found a few light blows with a hammer released it enough.
Slacker24seve...
PostPosted: 11:35 - 01 Oct 2014    Post subject: Reply with quote
I'll try doing the same. It was too hot when I got to work, actually smoking a little.
If not, halfrauds is half a mile away, I'll pop over at lunch and buy a cheap socket set and zip ties.
map
Mr Calendar
PostPosted: 11:38 - 01 Oct 2014    Post subject: Reply with quote
jimbopea wrote:
...a few light blows with a hammer...
My lad's goto tool out of the box. Closely followed by the angle grinder....and he's got a vehicle maintenance qualification Shocked
On topic I have tried the pushing backward trick. Released enough for me to move bike where I had more tools. I guess trial and error and luck if it's successful on every bike.
Tarmacsurfer
PostPosted: 14:16 - 01 Oct 2014    Post subject: Reply with quote
You never actually said if this is sorted or not. I was going to offer to drive over with the tool kit and/or a suitably large hammer (the light taps method does indeed work), bit late now as I've got a job on, can't wait on a reply any longer Laughing
Taught2BCauti...
PostPosted: 16:29 - 01 Oct 2014    Post subject: Reply with quote
I only just spotted this post (4:25pm) but are you sorted now?
I'm close to Dudley and would be happy to help.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MaybeGuy
PostPosted: 16:34 - 01 Oct 2014    Post subject: Reply with quote
back off the lever.Are you using one of those shitty chinky brembo rip offs?
PostPosted: 17:06 - 01 Oct 2014    Post subject: Reply with quote
mattsprattuk wrote:
back off the lever. Are you using one of those shitty chinky brembo rip offs?
Do brembo make aftermarket rear brake levers?
PostPosted: 17:10 - 01 Oct 2014    Post subject: Reply with quote
Danmoto make some sketchy rearsets...
But no. i get you Wink
Slacker24seve...
PostPosted: 20:28 - 01 Oct 2014    Post subject: Reply with quote
For Nissin calipers?
Anyway, with a combination of the caretakers hammer (using the stale, not the lumpy end, I'm not a heathen) and rocking it backwards and forwards I freed it and didn't use it on the way home.
Got it home and removed the chewed cap thing with lots of plus gas and an impact driver. On closer inspection the seal seems to be buggered. I just won't use it until I can get a new seal sorted. Basic tools now going in my bag in case I forget!
MaybeGuy
PostPosted: 04:18 - 02 Oct 2014    Post subject: Reply with quote
I think that's the most retarded thing I've ever seen you write on here. Shame on you.
Anyway, I was referring to an over-tight lever (at the master cylinder), as this will block any backflow into the master cylinder. Causing brake seizure when it's hot.
I don't see how a brake calliper could seize while you were at work unless it began when it was hot.
PostPosted: 12:47 - 02 Oct 2014    Post subject: Reply with quote
Now post a picture of an aftermarket brembo rear brake lever or you have to admit to everyone you're a double retard.
PostPosted: 12:53 - 02 Oct 2014    Post subject: Reply with quote
Calls stinkywheel retarded... dis gon b gud! Pass the popcorn
Conzar
PostPosted: 12:57 - 02 Oct 2014    Post subject: Reply with quote
SHOTS FIRED! Pass the popcorn
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
MaybeGuy
PostPosted: 13:11 - 02 Oct 2014    Post subject: Reply with quote
Levers operate master cylinders. I never said brembo levers. Simply asked if it was a chinky knock off brembo master cylinder. Back in your cage you ginger bearded bastard.
PostPosted: 13:50 - 02 Oct 2014    Post subject: Reply with quote
That's it, keep reversing. Yah fud.
Islander
PostPosted: 14:34 - 02 Oct 2014    Post subject: Reply with quote
I'll just quote this here then... Laughing
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.31 - MySQL Queries: 13 - Page Size: 132.18 Kb
