| Tamsin |
 Tamsin World Chat Champion
| Ballpien |
 Ballpien Trackday Trickster
 Posted: 19:06 - 01 Oct 2014 Post subject: |
Almax.
Every. Single. Time.
I spoke to both recently. Pragmasis acted like they were too busy to take my call, like it was too much trouble. Almax on the other hand couldn't have been more helpful if they'd tried. I spoke to Alex for about an hour and a half, discussing different security methods through to street lighting (it went off on a tangent a few times ) The upshot being that my custom felt welcomed.
I went for a ground anchor too - now I neither know nor care whether he has a tie in with Y-Max ground anchors, as that's what I was going for anyway - but rather than recommend one from his own site he said it sounded like the Y-Max would be best for my needs.
I was also told that I'd not need to buy the more expensive 19mm chain (which was what I intended to buy) but that the 16mm series 3 would be more than enough for a single bike locked at a domestic premises. (this may change with your location, rural Wiltshire will be less at risk than Islington). I didn't get charged delivery and it turned up next day. Couldn't be happier with it.
Anyway, Tl;dr...Almax. ____________________ R125 - FZ1n ABS
Looking forward to the 5,000,000th post in 2017 |
| Snop Doog |
 Snop Doog Brolly Dolly
| ADSrox0r |
 ADSrox0r World Chat Champion
| Knacker |
 Knacker World Chat Champion
| -Matt- |
 -Matt- World Chat Champion
 Posted: 19:22 - 01 Oct 2014 Post subject: |
I'd go with an Almax personally - probably want a 1.5m rather than 1m one to get it around a lot of things, especially if you've got a large rear wheel on the bike.
Series III's are good enough generally; the Series IV's take marginally longer to get through with power-tools, but if they're confident to goto that much effort in the first place its going to get nicked either way probably, regardless of an extra minute or so to get it broken.
Never had a Pragmasis, although i've heard good things about them too - would agree with Ballpien about Almax having a lot of time for their customers though
| Moo. |
 Moo. World Chat Champion
| Ste |
 Ste Not Work Safe
 Posted: 19:27 - 01 Oct 2014 Post subject: |
Almax, Pragmasis and a bit of rope tied with a knot.
| Rogerborg |
 Rogerborg nimbA
| Flatbadger |
 Flatbadger World Chat Champion
 Posted: 19:59 - 01 Oct 2014 Post subject: |
I have the Almax 19mm 2m and 16mm 1.5m for the topbox, which I tie into a knot. Pragmasis anti-pinch pin too (although I don't tie that in a knot, that would be silly). 2 1/2 years and still nick free
I also have had a long talk with Alex, he asked me to call him back for a special tip when installing the ground anchor but it's still in the cupboard, I ended up using a fence post. ____________________ If you can keep your head when all about you
You're in ISIS |
| Vincent |
 Vincent Banned
| Northern Monkey |
 Northern Monkey World Chat Champion
| Amber Phoenix |
 Amber Phoenix Traffic Copper
 Posted: 10:30 - 02 Oct 2014 Post subject: |
Had two Pragmasis chains, locks and one Torc anchor now (for two bikes, not because there was an issue).
Found Pragmasis very helpful with advise on securing the Torc anchor after discovering the concrete in front of house wasn't as deep as I hoped, rendering the supplied resin based bolts a failure - they just got pushed into the soft ground below. ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
| Val |
 Val World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 03:19 - 04 Oct 2014 Post subject: Re: security chain recommendations? |
Locks are generally weaker than chains, there doesnt seem to be many expensive ones worth looking at, the squire and abloy both have skinny shackles compared to the chain diameters they are paired with. Theres absolutely no point in a 19mm chain with a 13mm lock shackle, or even 16mm shackle. Both need to be the same diameter or your wasting weight/strength of the chain.
This one is interesting but 40 quid.
https://www.youtube.com/watch?v=HIO-_yDdaX8
I dont think chains are ideal, they have equal strength all over but use twice as much metal for the diameter. Instead bar could be used with pins, but pins are the weak point unless they are the same diameter, which means the end of each bar needs to be bigger. The advantage comes from weight if the link pins are very long 150-300mm (any longer and they could be used as levers to break the pin)
example - 20mm bar, 40mm end of bar, 20mm riveted link pins. |
| stevo as b4 |
 Posted: 15:01 - 04 Oct 2014 Post subject: |
I have one question.
Why do many bike dealers and bike accessory shops stock a large range of other brands of locks and chains, if Almax and Pragmasis are the only two worth buying or strong enough to resist most hand operated bolt croppers?
Why is Almax only available direct from the firm or on Ebay? Do bike shops not want to stock the best chains, or are they prevented from doing so, either by tie ups with other manufacturers/exclusivity or do Almax etc only want to sell direct?
I've never been to a bike shop that sell's Almax/Pragmasis products that I can think of? Many local (west mids) shops to me sell Oxford, Squire, Abus gear instead.
Also do these firms believe their products are better than they are, or are they happy to sell security that is not as strong/resistant to bolt croppers as they could be?
I cannot believe Abus etc have not seen the independent chain tests, and having had their products sometimes easily defeated or shown up by Almax etc, that they have not wanted to do something about it?
Or is it that other makes are cheaper and still sell well, so why change something that still makes you money?
Sorry for the long post, and I know that this opens up a whole can of worms, but these are questions I'd like to know about. |
| -Matt- |
 Posted: 15:15 - 04 Oct 2014 Post subject: |
| stevo as b4 wrote: | Why is Almax only available direct from the firm or on Ebay? Do bike shops not want to stock the best chains, or are they prevented from doing so, either by tie ups with other manufacturers/exclusivity or do Almax etc only want to sell direct? | Theres probably more to it in terms of shop-retail/marketing/distribution costs, but for high-street dealers and bike shops more than anything it might be down to the fact most of these chains are very heavy, particularly the longer ones. I certainly wouldn't want to lug one back from a bike-shop in town very far, and assuming a lot of shoppers will be on bikes, most will probably be unable/have to prepare the bike to carry such chains back home so would rather go online. The majority of these really heavy duty chains probably rarely get used away-from-home anyway once they arrive on the door-step.
| Quote: | I cannot believe Abus etc have not seen the independent chain tests, and having had their products sometimes easily defeated or shown up by Almax etc, that they have not wanted to do something about it? | I think there will always a market for these chains, mainly as lots of new bikers don't realise how weak they are; I certainly didn't when I got my first couple of chains, so I guess theres no incentive for the companies to spend more on development and quality when they can sell cheaper n' weaker for nice profits  |
| Tamsin |
| wr6133 |
 wr6133 World Chat Champion
| Val |
| -Matt- |
| Ste |
 Ste Not Work Safe
| andys675 |
 andys675 World Chat Champion
| kramdra |
 Posted: 02:57 - 05 Oct 2014 Post subject: |
Id be very surprised if a £100 oxford lock cost trade more than £20-30, and that is why most shops sell them. The actual manufacturing cost will be under £12.
Very expensive lock for an 11mm shackle. Note that this type closed shackle does not add to the protection as they have no support from the shackle, a bolt cropper will break the thin shrouded bit off in seconds to get more access... it might buy an extra 10 seconds of protection though. |
| Musketeer |
 Musketeer World Chat Champion
 Posted: 11:10 - 05 Oct 2014 Post subject: |
Almax chain and decent padlock  ____________________ Current Bike: Yamaha XSR900 Previous bikes: Honda CBR1000RR Fireblade, Kawasaki ZX-6R Ninja, Aprilia RS125 2-stroke |
The last post was made 11 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
