Lightweight (Airportable) Landrover rebuild.
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
sickpup
Old Timer
PostPosted: 18:49 - 30 Sep 2014    Post subject: Reply with quote
nowhere.elysium wrote:
Weekends anytime soon?
4 weeks, so you want to drive it then?
PostPosted: 15:49 - 01 Oct 2014    Post subject: Reply with quote
I walked a whole minute out of my way to have a look myself!
#landyselfie
sickpup
Old Timer
PostPosted: 16:59 - 01 Oct 2014    Post subject: Reply with quote
And you didn't drop in for a cup of tea?
PostPosted: 17:48 - 01 Oct 2014    Post subject: Reply with quote
I half expected you to be outside elbow deep in tin worm. I should have but was in a little bit of a rush to get back to work. Next time you are at it during the day let me know, I'll pop over and supervise. Razz
sickpup
Old Timer
PostPosted: 18:13 - 01 Oct 2014    Post subject: Reply with quote
Very kind of you to help sir, probably at it next Monday so will let you know.
No pics so far today but decided I will just rebuild the slave cylinders as per Teffers suggestion.
Now these slave cylinders have a very different set up to a motorcycle caliper in that instead of seals around the piston they are at the ends of the pistons and the pistons are opposed like a boxer engine, both push out from the same fluid supply in opposing directions.
As long as you can get one piston out you can remove the seals for both pistons and then knock the opposing one out with a punch.
This is how the slave cylinder looks while mounted to the backplate on the axle.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0654-1.jpg
As you can see the pistons are opposed with a single inlet around the back next to the bleed nipple.
Bru
PostPosted: 19:26 - 01 Oct 2014    Post subject: Reply with quote
I have never found drum brakes that clean, on any of my cars, and my cars looked 'far' nicer (not that it would be difficult) than yours. Amazing.
sickpup
Old Timer
PostPosted: 19:31 - 01 Oct 2014    Post subject: Reply with quote
The looks of this Lightweight are very deceiving. Its actually in good mechanical condition for its 40 year age and was well looked after, just got bored using it.
Short of needing the rear chassis replaced I'm hoping it won't be an expensive job getting it going again.
Llama-Farmer
PostPosted: 19:46 - 01 Oct 2014    Post subject: Reply with quote
Eurgh, drum brakes and slave cylinders still give me nightmares.
Gonna watch this thread with interest Thumbs Up
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Wonko The Sane
PostPosted: 23:18 - 01 Oct 2014    Post subject: Reply with quote
Copycat73 wrote:
chris-red wrote:
No way that weighs 1/2 a tonne That's under half my fiesta!
I think you`ll find that figure refers to the pay load rather than the un-laden weight.
To chuck it out of a helli you'd not have the roof or doors on there, only the chassis and bulkhead is steel, the rest of the body is alu
sickpup
Old Timer
PostPosted: 13:40 - 02 Oct 2014    Post subject: Reply with quote
Heres the cleaned up slave cylinder. The pistons are now so smooth that if you remove the dust seat the pistons shoot out due to the spring in the middle.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0658.jpg
map
Mr Calendar
PostPosted: 13:56 - 02 Oct 2014    Post subject: Reply with quote
sickpup wrote:
...The pistons are now so smooth that if you remove the dust seat the pistons shoot out due to the spring in the middle...
Out of interest is that with the kit Tef suggested or just as a result of cleaning/tlc?
sickpup
Old Timer
PostPosted: 14:58 - 02 Oct 2014    Post subject: Reply with quote
That was just cleaning. Keep in mind everything on these is big compared to motorcycles so easier to clean.
Aff
PostPosted: 15:26 - 02 Oct 2014    Post subject: Reply with quote
Posting for updates. Thumbs Up
Electric Bike Project
sickpup
Old Timer
PostPosted: 09:16 - 04 Oct 2014    Post subject: Reply with quote
Not a real update, just had some bits arrive.
New under wing mudshields for both sides, steering box cover, a seal for between the vent panel and windscreen and some flap discs.
Hopefully I will get to do some more work this week as I have 6 days off, just have to make sure I don't eat too much at pork rib night.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0659.jpg
Need to decide what finish I want on the mudshields and steering box cover. I'm thinking hot metal spray, powder coat and then underseal just so they last another 40 years.
stevo as b4
PostPosted: 15:29 - 04 Oct 2014    Post subject: Reply with quote
Good Project more interesting than many run of the mill 'I've just stuck a load of tat on my late 90's sportsbike' projects!
Question to Sickpup.
What engine is in your Wagon? I always assumed that the lightweight's had the Rover V8, for it's lightness and grunt, but out on the battle field wet prone electrics and petrol fuel/fire risk would not be the best option, so were they diesel lumps instead?
I know that I've seen several lightweight's with RV8's so if these were not std fit, I assume some have been converted once in civilian ownership?
pdg
PostPosted: 19:04 - 04 Oct 2014    Post subject: Reply with quote
If a lightweight has a V8, it's a retrofit...
As far as I know (which isn't very far Wink ) they all had the 2.25 petrol.
As for the term 'lightweight', they weigh more than a standard civvy series 3.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
sickpup
Old Timer
PostPosted: 21:10 - 04 Oct 2014    Post subject: Reply with quote
V8's were never to my knowledge a standard fit in the lightweight, it wouldn't surprise me if the factory tried it at some point but none that I know of were put into production. All of the ones you see in public are retro fits.
The standard engine was the 2286 petrol but the Dutch did have LHD 2286 Diesels that were a bit of a failure, have a read here for details of them.
sickpup
Old Timer
PostPosted: 18:37 - 07 Oct 2014    Post subject: Reply with quote
No pictures today just an update so I can see that I've done something.
Been off and seen the Blacksmith and after a visual inspection he has agreed to repair the vent panel. We discussed spray hot metal and he agrees its the way forward with an external class powdercoat over the top which will not only give good further protection but stop any Zinc-Aluminium contact so no powdery Aluminium after a year.
Refitted the Rear right slave cylinder so that corner is sorted brake wise, hopefully do more on the brakes tomorrow if I wake early enough.
pdg
PostPosted: 20:38 - 07 Oct 2014    Post subject: Reply with quote
From what you said about it in chat t'other night it seems a good way to go.
Of course, if you only want it to last another 40 days before crumbling away you could always slather the whole thing with waxoyl rust inducing devil spunk......
sickpup
Old Timer
PostPosted: 14:01 - 08 Oct 2014    Post subject: Reply with quote
Need to find out costs but it looks like Hot metal spray, powder coat and then Dinitrol internally.
sickpup
Old Timer
PostPosted: 17:46 - 08 Oct 2014    Post subject: Reply with quote
So the rain has stopped for the moment and to work.
Front right brake time.
Bit muckier in here than the rear, looks like something has seeped in here over time as well but all the seals look intact.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0660.jpg
Had to undo the bleed nipple again to release the pressure on the pads but once that was done the drum came off easily.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0661.jpg
Stripped and cleaned the slave cylinder which seems to be fine, here is how the component parts look.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0662.jpg
These are the shoes, as you can see there's a small amount of what seems to be oil contamination. I'm not bothered by it, if that's all there is since I last took the brakes apart 23 years ago then no problem for now. Quick clean with brake cleaner as well as the drum and it all goes back together.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0665.jpg
So thats another corner done and hopefully by tomorrow I'll have the third corner completed. The Rear left is up against a fence so that ones going to be a bit on the hard side to get to. May have to use a high lift jack and sort of swing the rear over, last time I used one though I shattered my left thumb as Reuben can attest to.
sickpup
Old Timer
PostPosted: 19:53 - 09 Oct 2014    Post subject: Reply with quote
Decided to get the master cylinder and servo off today.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0666.jpg
It's a dual circuit master cylinder, one circuit for the front brakes and one for the rear so has two brake lines going into it as you can see here.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0667.jpg
The servo can't be rebuilt as the four studs that hold it on are badly corroded, luckily a new one is only £65.34 so not too bad. Problem is the master cylinder. The piston is siezed solid so I will be having a chat with a company that reconditions them to see what they can do for me, if they can't re-con it I will have to buy a new one. A cheap no name pattern one is only £60 but I would prefer a genuine Girling as they last well, I suspect the price may run into several hundred for one though.
An empty space where things used to be.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0668.jpg
Shaft
PostPosted: 20:06 - 09 Oct 2014    Post subject: Reply with quote
Try this lot
https://www.powertrackbrakes.co.uk/wcylinder.html#cylinder
sickpup
Old Timer
PostPosted: 20:39 - 09 Oct 2014    Post subject: Reply with quote
Shaft wrote:
Just emailed them, thank you.
sickpup
Old Timer
PostPosted: 11:40 - 16 Oct 2014    Post subject: Reply with quote
Had the vent panel back yesterday, good and bad news. The bottom part that had rusted away has been replaced and its been filled with rust proofer.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0675.jpg
but unfortunately more holes have appeared where the metal has been corroded away.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0676.jpg
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0677.jpg
The metal here is too thin to weld so will need large sections replaced, as a temporary fix I am going to skim the holes with chemical metal, respray and fill the inside with Dinitrol rust proofer. The metal is simply too thin to Hot zinc spray.
Although these sections are repairable it will be cheaper, and it isn't cheap to buy a new one and get that Hot zinc sprayed.
The last post was made 9 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 135.08 Kb
