Honda cg 125 m 2001 - 5th gear issues
LukeK96
PostPosted: 22:41 - 01 Oct 2014    Post subject: Honda cg 125 m 2001 - 5th gear issues Reply with quote
Hi there, new to the forum,
well i'm not sure if it's an issue, or just something that is common, basically: My honda cg has a decent acceleration, however I feel there's an issue with the gears, - 3rd hits it upto 50mph, 4th about 62mph, however 5th gear just doesn't do anything, it's like 4th is the cap, i've been told it should get upto 67-70mph (Newer models use a higher powered engine, well as ''higher power'' as going from 9hp to 12hp can be) - however there's just nothing there, bike just does the same speed, just a little quieter, is this normal?
Please excuse my wording and if this is a poor question, however this is my 1st geared bike and i'm on L-plates, so don't hate me Wink
Thanks in advance for any help.
Scootaloo
PostPosted: 02:54 - 02 Oct 2014    Post subject: Re: Honda cg 125 m 2001 - 5th gear issues Reply with quote
Depending how large/slick your jacket/trousers are then yes thats about your lot.
It will probably do 70+ easily - downhill with tail wind and you in full Lycra.
Perhaps a small shield on the front headlight might assist you here but a 60mph top speed is not that bad for a CG and the main reason why the CBF125 is able to breach that easier is mostly because of that nose cone fairing.
Source: I've ridden two of them from different eras.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
mudcow007
PostPosted: 07:56 - 02 Oct 2014    Post subject: Reply with quote
my CG would bog down like mad in 5th, so would just use 4th.
Mine hit 60 once, but it didnt like it at all...this was with me sitting as far back on the seat as possible with my chin on the filler cap
if you wanna go faster, i suggest you make something like this to go over the bike
https://i25.photobucket.com/albums/c81/mudcow007/aero_zps2894cfec.jpg
PostPosted: 08:34 - 02 Oct 2014    Post subject: Reply with quote
Sounds normal, my Chinese CG copy-engine would do the same top speed in 4th or 5th. Think of 5th as an economy gear, not a higher speed one.
If you want to go faster, you'll need to add more power, rather than more gearing.
spriddler
PostPosted: 11:28 - 02 Oct 2014    Post subject: Reply with quote
My 2014 CBF 125 (3,700 miles on the clock) will hit an indicated 73 (actually 66 when verified by GPS) on the flat with no wind. I'm 146lbs in me socks.
But at 65 indicated it's revving it's nuts off at 8,300 rpm. and petrol consumption drops to 65'ish mpg.
Info gathered on a 5 days' 1400 mile ride from Calais to Spain via the Pyrenees in June this year.
My main gripe is that it's virtually impossible to select Neutral when stationary at lights etc.
And with that daft kicked rear end throw-over panniers are an ugly fit - and there's nowhere to attach bungee hooks or a cargo net either.
O.K. for town or commuting but definitely not a touring bike (obviously).
Mark65
PostPosted: 12:24 - 02 Oct 2014    Post subject: Reply with quote
Ive managed 65 on the speedo on my CG on the flat with no wind, that was fast enough Shocked .
LukeK96
PostPosted: 14:31 - 02 Oct 2014    Post subject: Reply with quote
Thanks for your responses, Glad to know this is something to be expected and not a fault, i'm 6ft and about 170lb, so the fact i'm even getting over 60mph isn't too bad I suppose, a very mechanic minded mate has said he would cut the emmissions on it to give it a few more mph, not sure it's worth the effect it would have on the engine though.
spriddler
PostPosted: 15:34 - 02 Oct 2014    Post subject: Reply with quote
LukeK96 wrote:
.......a very mechanic minded mate has said he would cut the emmissions on it to give it a few more mph, ...
My doc said cutting down on the pizzas and pies would give me a few more mph and REDUCE my emissions. Rolling Eyes
PostPosted: 16:13 - 02 Oct 2014    Post subject: Reply with quote
Try crouching as low as you can and redlining it in 4th before changing. You might go a bit faster.
LukeK96
PostPosted: 00:46 - 03 Oct 2014    Post subject: Reply with quote
did the same with my old boatian 4 stroke moped, it increased it quite a bit to be honest, but yeah I know what you're saying. i know someone with the lifan chinese version of my bike that did the same and it's a bit quicker, so i'm not completely against it, just don't plan on doing it as want to keep this bike good.
Mark65
PostPosted: 08:19 - 03 Oct 2014    Post subject: Reply with quote
The cg runs very lean as is, thats why your plug is a grey colour when removed, I wouldnt try to lean it out more it may burn through your piston.
Mark
LukeK96
PostPosted: 15:07 - 03 Oct 2014    Post subject: Reply with quote
Asked him about it today, turns out it has already been done...To be honest i'm not overly bothered about top speed, i live in a city and commute within the city so I don't have any need for higher speeds really, unless i'm going out of the city, i'll keep this as is and in a year when i can do the a2 i'll just get a bigger bike, love this bike, don't want to ruin it.
LukeK96
PostPosted: 04:32 - 10 Oct 2014    Post subject: Reply with quote
Instead of setting up a new thread I thought i'd just ask here, there seems to be an issue with the bike slipping into neutral from 2nd, seems to be getting more common, any advice?
PostPosted: 08:56 - 10 Oct 2014    Post subject: Reply with quote
When did you last change your oil and is the chain adjusted correctly? If the answer is Recently and yes and your technique isn't at fault it is likely a new engine/split the cases job.
LukeK96
PostPosted: 14:11 - 10 Oct 2014    Post subject: Reply with quote
oil was a little low, topped up today, chain tension is set, i'll see if it happens again, thanks for your advice.
PostPosted: 15:38 - 10 Oct 2014    Post subject: Reply with quote
The amount isn't the issue, it is the quality of it. If the oil is old it can make the changes worse. Being a small bike you need to change to oil regularly.
alt tab
PostPosted: 16:46 - 10 Oct 2014    Post subject: Reply with quote
Just the case with 5th gear on the CG, absolutely redline it in 4th and you'll see marginal speed gains in 5th, but nothing over a few mph. Really is just a cruising gear.
LukeK96
PostPosted: 13:06 - 11 Oct 2014    Post subject: Reply with quote
Taking it for a run out today, so i'll have a look what I can get out of it, thanks for the advice.
The last post was made 11 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 96.84 Kb
