Bars Judder 40-60mph
superdaaan
PostPosted: 21:28 - 06 Oct 2014    Post subject: Bars Judder 40-60mph Reply with quote
Hi guys,
I have a 98 CBR600 F3, had it for 4-5 months. Recently I noticed if I take my hands off the bars at around 50mph they shake quite a lot. Not enough for me to hit a tank slapper, but enough to worry about.
Anything below 40 and above 60 is fine? Suppose I should just drive everywhere at 70mph (i was being safe officer, honest)
Changed the wheel bearings, the head bearings had no play or notchiness. Wheel isn't buckled and rear suspension seems fine. Replaced rear tire, no cupping or wear on front so left that. Have stiffened up the pre-load - I'm out of ideas???
Many thanks in advance....
If I wanted to listen to an arsehole, I would fart.
salem1987
PostPosted: 21:37 - 06 Oct 2014    Post subject: Reply with quote
is the front tyre balanced ok? Thinking maybe one of the weights has fallen off and its totally out of balance.
superdaaan
PostPosted: 21:41 - 06 Oct 2014    Post subject: Reply with quote
Replaced the rear as there was a nail in it, got them to balance the front whilst I was there. Same issue
Islander
PostPosted: 22:43 - 06 Oct 2014    Post subject: Reply with quote
Have you checked your tyre pressures?
UrbanRacer
PostPosted: 00:01 - 07 Oct 2014    Post subject: Reply with quote
Check the front tyre, make sure its on the rim properly.
Is the tyre old?
Do you have a front paddock stand? if so lift the front wheel off the ground and spin it and see if you can see any wobble or bulges.
Check the wheel itself and make sure its not cracked or anything like that.
do the same with the rear
davebike
PostPosted: 07:06 - 07 Oct 2014    Post subject: Reply with quote
Tyre pressure or uneven ware from low tyre pressure are the most common causes
Then wheel bearings and over tight head races and just faintly possible wheel balance
Start with the tyres pressure and how worn in less than 2mm tread left change
Good tyres = good ride
Worn tyres will always give poor handling and often wobbles
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Skudd
PostPosted: 10:04 - 07 Oct 2014    Post subject: Reply with quote
Having a top box can cause this as can having a knackered rear shock, but most bikes waggle a bit at a certain speed even if the window of speed is only 2-3mph
RodYork
PostPosted: 19:47 - 07 Oct 2014    Post subject: Reply with quote
as others have said...9/10 faulty tyres...if its not that...then possibly head stock bearings...but a cheaper test to ensure you stay Coolio on't road isto check the tyre pressures/seating on't rim and tyre tread depth ( min 1mm over 3/4 of wheel)
work towards the problem..keeping cash firmly in't wallet!
( signed up Yorkshire man...with ferrets)
Bike trip through Europe! https://www.youtube.com/watch?v=Z2yTtFPM7Xc
The last post was made 11 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 59.48 Kb
