Author |
stevo as b4 |
 Posted: 09:53 - 03 Aug 2014 Post subject: |
It's got my vote for project of the year 2014!
Do you reckon with that frame and suspension, it will eclipse the TZR pit bike you had for it's level of awesomeness?
Oh and the MX125 pipe will look a million times better than the AF1 pipe too! Don't junk the old pipe though in case you ever start a 125cc road bike project! |
Back to top |
binge |
 binge Emo Kiddy
 Posted: 10:19 - 03 Aug 2014 Post subject: |
Cheers!
With the TZR, I was young when I built it. Fairly un-skilled compared to now, and the bike never ran quite right because of that.
I cut corners on things like an inlet manifold, and nut/bolting everything, rather than welding.
After I broke the TZR for parts, I used to talk about building another 2/ pitty, but the grueling work I put into the TZR always put me off.
I'm so glad the Rotax 123 cropped up on ebay so cheap though, because it's been a really smooth project this time. Having the MIG welder and a far better tool kit, has made it so much easier to do.
Handling wise, I can not say yet, as it really is a Frankenstein build. The frame was meant to have longer forks and swing arm, along with 17" wheels.
The TZR build, was all on a modified KLX110 (Pit bike) Chassis, with Pit bike swing arm, KTM65 forks, and 12" pit bike wheels.
The Rotax build is on the Malaguti frame, with the KLX110 pitty subframe fitted to it.
Pit bike forks, GSXR600 yokes (Modified by Pete), a pit bike swing arm, And 13" Aprilia SR125 wheels.
Oh, and a Ducati rear shock!
I've bought a pack of spacers with an ID of 30mm, as the stem bolt is too long for the frame.
I can swap the spacers to the bottom, or top of the stem bolt (On the outside of the bearings), to move the frame, up and down, between the yokes. This will really help out with the set up of the frame, as there isnt much movement with the fork legs in the yokes, they're already right at the top and the front end could do with coming up a bit.
At the moment, with no headstock spacers fitted, the frame is obvs sitting on the bottom yoke, I've got about 15mm of gap to play with, so can stick all the spacers underneath to start with, and see how it sits.
Rear shock is adjustable massively too! And there are multiple top mount holes, I can move the angle of the shock too.
And if that is not enough, the bottom mount actually unbolts from the swing arm, so I can spacer that out too!
My main concern is the wheels.
They are insanely wide! 3.5j front and rear.
The tried and tested widths on a pit bike, are 2.5j rear, and 2.15j front.
That said, there has never been a pit bike I know of, on 13" wheels.
Need to decide on some tyres, I'm warming towards the Michelins as they are dual compound.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/p526x296/10557188_10152578686660606_4180090319221026438_n.jpg?oh=5ad7fc9b67b84bfd1838e061717bdfb8&oe=54446291&__gda__=1413593130_2d0fdf60db73c08f4b69295a5749795c
Time will tell I guess, it'll no be finished fully for a long long time. Things will need to be changed and tweaked along the way. |
Back to top |
binge |
 binge Emo Kiddy
 Posted: 20:28 - 12 Aug 2014 Post subject: |
Back to top |
P. |
 P. Red Rocket
 Posted: 20:31 - 12 Aug 2014 Post subject: |
This thing is sick! Let me know when it is running, I need to see this  |
Back to top |
Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 16:15 - 16 Aug 2014 Post subject: |
What wheels are you running? ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
Back to top |
MattWadz |
 MattWadz Trackday Trickster
Back to top |
1cyl |
 1cyl World Chat Champion
Back to top |
binge |
 binge Emo Kiddy
Back to top |
stevo as b4 |
Back to top |
binge |
 binge Emo Kiddy
Back to top |
BenR |
 BenR World Chat Champion
 Posted: 20:09 - 18 Aug 2014 Post subject: |
I would suggest fitting some tyres before riding.  |
Back to top |
binge |
 binge Emo Kiddy
Back to top |
sulphur |
 sulphur Trackday Trickster
 Posted: 21:54 - 06 Oct 2014 Post subject: |
I genuinely can't wait to see the finished product, and watch the vid to hear/see it go. Muchos kudos on the build, it looks awesome.  |
Back to top |
binge |
 binge Emo Kiddy
 Posted: 12:56 - 07 Oct 2014 Post subject: |
Picked up a block of ally round bar today. Got a 240mm front disc coming for it and going to get my Grandad to turn an adapter plate to run a 5 bolt disc on the 3 bolt wheel. Will stop on a 6pence with the KTM Brembo caliper and NC29 master cylinder.  |
Back to top |
binge |
 binge Emo Kiddy
 Posted: 13:00 - 07 Oct 2014 Post subject: |
Back to top |
P. |
 P. Red Rocket
 Posted: 16:03 - 07 Oct 2014 Post subject: |
You have a MIG now? Any details as I reckon I could do with learning how to do this sort of stuff... that and I have some bits I need welding  |
Back to top |
binge |
 binge Emo Kiddy
Back to top |
binge |
 binge Emo Kiddy
Back to top |
binge |
 binge Emo Kiddy
 Posted: 18:19 - 10 Oct 2014 Post subject: |
Set of plastics arrived today, so fitted up the remaining 3 graphics, and fitted them up to the bike.
Also bought a proper axle for the rear wheel, and a high tensile spindle for the swing arm, all fitted and spaced up nicely. PLENTY of sprocket/chain clearance now too.
Slight issue / school boy error. While fitting up the exhaust, I didn't have the shock fitted. Res fouls stinger pipe. DOH!
Rather than sacrifice my Ducatti shock for some Chinese piece of crap, I think I will just start again with the exhaust end can/stinger to make it fit around the shock.
https://scontent-b-lhr.xx.fbcdn.net/hphotos-xap1/v/t1.0-9/10392429_10152748507670606_7689195393682294462_n.jpg?oh=f64b100bf10c84a423d77d648bde0f63&oe=54B3DB7F
Tomorrow I will mostly be welding the frame some more, removing any more bits that are not needed, and just double-double checking everything before it goes off for powder coating. |
Back to top |
binge |
 binge Emo Kiddy
 Posted: 19:47 - 13 Oct 2014 Post subject: |
Rads have arrived. They look awesome. Going to fit them up tomorrow with some weld on brackets. And once they're done, I do think it's time to get the frame and wheels powder coated.  |
Back to top |
Eddie Hitler |
 Eddie Hitler World Chat Champion
 Posted: 20:13 - 13 Oct 2014 Post subject: |
Back to top |
binge |
 binge Emo Kiddy
Back to top |
Eddie Hitler |
Back to top |
binge |
 binge Emo Kiddy
Back to top |
Eddie Hitler |
Back to top |
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
