Adjusting a chain with the wheel on the ground?
SofaBear
PostPosted: 11:49 - 09 Oct 2014    Post subject: Adjusting a chain with the wheel on the ground? Reply with quote
Hi All,
I have an ER6f, i want to adjust the chain as its getting a bit slack however i have no access yet to a paddock stand in order to raise the wheel up.
can you adjust the chain when its on the side stand? is it possible? is it advisable?
Copycat73
PostPosted: 11:53 - 09 Oct 2014    Post subject: Reply with quote
my Kawasaki is adjusted on the side stand ... read your riders hand book.. if you haven't got one google for a pdf. follow instructions in it .
caveat emptor
fatjames
PostPosted: 12:53 - 09 Oct 2014    Post subject: Reply with quote
Should be fine with the wheel on the ground. Just be very careful and make sure you adjust each side the same amount.
As you adjust it, the wheel will move backwards, but it's only a tiny amount.
I can't remember the specifications, but you will need to torque up rear axle.
Last of all, don't forget to put the split pin back in (or replace it, if needed)
HTH
FJ
PostPosted: 17:01 - 09 Oct 2014    Post subject: Re: Adjusting a chain with the wheel on the ground? Reply with quote
No problem either way. In both cases there is a small load on the rear suspension, which will tighten the chain a tiny amount. But unlikely to be enough to worry about
blackbosh
PostPosted: 18:21 - 09 Oct 2014    Post subject: Reply with quote
even so thats why your manual says to adjust between Xmm and Ymm slack, get it in the middle and you can't go far wrong
PostPosted: 18:56 - 09 Oct 2014    Post subject: Reply with quote
Be sure to check the tension after tightening the spindle. Many times doing the spindle up tight will pull the chain tighter.
Nemo
PostPosted: 20:58 - 09 Oct 2014    Post subject: Reply with quote
On top of what everyone else has said check the tension when you're sat on it as well, and if there's a tight spot tension at that part
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Pigeon
PostPosted: 21:55 - 09 Oct 2014    Post subject: Reply with quote
Depending on the bike, you might have a side-stand that's man enough to take the load of the bike.
I've only had a few bikes and never had a problem lifting the bike onto it's sidestand and wedging a stick between the ground and the swingarm.
It takes 2 seconds to put in place and costs nothing......as long as your side-stand doesn't give out Smile
SofaBear
PostPosted: 09:25 - 10 Oct 2014    Post subject: Reply with quote
Ive had it on the side stand and the wheel in the air, with the misses spraying the chain for me in the past. That worked well, but i want to get away from that lol not saying i don't trust her or anything ...
I may just wait it out for a paddock stand, just to be safe lol just got images of being smacked in the face by the back wheel as it goes forward and left.
Wull
PostPosted: 17:58 - 10 Oct 2014    Post subject: Reply with quote
Just to clarify chain tension is whilst the bike is on the side stand and or paddock stand,either way it'll give the same readings.
Chain slack is also without rider on the bike,let's be realistic here how the fuck are you suppose to check tension whilst sitter on the bike,fuck that.
Chain slack is also upward and downward movement.
Usually you'll get roughly 20-25mm up and 5mm down depending on what the specs are.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
PostPosted: 18:57 - 10 Oct 2014    Post subject: Reply with quote
More importantly, chain slack is to take account of the chain getting tighter as the suspension compresses to a point (most likely where the gearbox output shaft, swinging arm spindle and wheel spindle are all in a line). If there is a random weight rider on the bike then the amount of movement to that point in the suspensions movement is random, and hence the amount of chain tension is random.
Doing it on the side stand / centre stand / paddock stand / whatever is specified for that bike at least means the measurement should be consistent. With nobody on the bike the suspension movement on the side stand should be nominal.
The last post was made 11 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 70.19 Kb
