FTP Multiple Drive
PostPosted: 10:46 - 10 Oct 2014    Post subject: FTP Multiple Drive Reply with quote
Hi all,
I have a server that among other things acts as an FTP server. I have 2 drives I want to access D:/ and E:/ Currently the FTP account I use has a Root of E:/ is there a way I can set it up so I can choose which drive I connect to without creating a separate account?
CaNsA
PostPosted: 13:20 - 10 Oct 2014    Post subject: Reply with quote
Whats the ftp server, windows server?
A symlink or symbolic link can be easily created in Widows Server 2008 to share a common folders or files amongst projects. Lets assume you have a folder in domain1.com called CSS and you want to share this folder with domain2.com. You could just upload the CSS folder into domain2.com but then you need to FTP and update the CSS folder in 2 places. If both sites are using the exact same CSS this could cause you issues over time as you might forget to roll out updates from one site to another.
Using Windows Server 2008 you could create a symlink to solve this issue. Once you have the CSS folder created on domain1.com then you can run the following command from the command line on the server to create a symlink:
1
MKLINK /D C:\inetpub\wwwroot\domain2.com\CSS C:\inetpub\wwwroot\domain1.com\CSS
The format of the above is: MKLINK [new directory] [where to generate the new folder] [target folder you want the new link to go to]
If you're using Windows Server 2003 you can achieve something similar using:
1
fsutil hardlink create c:\foo.txt c:\bar.txt
There is a good answer on serverfault.com that covers this topic quite well - https://serverfault.com/questions/7109/how-do-i-create-a-symbolic-link-in-windows
PostPosted: 18:10 - 20 Oct 2014    Post subject: Reply with quote
Can't get this to work,...
PS F:\> MLLINK /d f:\ d:\
MLLINK : The term 'MLLINK' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ MLLINK /d f:\ d:\
+ CategoryInfo : ObjectNotFound: (MLLINK:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Any Ideas?
CaNsA
PostPosted: 18:56 - 20 Oct 2014    Post subject: Reply with quote
MKLINK
barrkel
PostPosted: 20:29 - 20 Oct 2014    Post subject: Reply with quote
You have three problems. It's called mklink; you're trying to run mklink from powershell, which doesn't understand it (it's built into cmd); and the arguments don't make sense, the first argument - the name of the link to create - can't be a directory.
Start a command window by doing Start | Run | cmd, and run it like this:
Code:
mklink /d e:\d d:\
this should create a symbolic link (called d) to your D: drive in the root of your E: drive. That way, your existing FTP configuration ought to be able to see into the D: drive.
Depending on the FTP server, it may or may not recognize that as a directory. If it doesn't, try creating a junction instead:
Code:
mklink /j e:\d d:\
If you can't find cmd, you can run cmd from inside powershell, like this instead:
Code:
cmd /c mklink /d e:\d d:\
PostPosted: 20:27 - 21 Oct 2014    Post subject: Reply with quote
Embarassed
Thanks
noobRider
PostPosted: 11:36 - 22 Oct 2014    Post subject: Reply with quote
On Windows I use Symlink Creator, which is a GUI for mklink. Run it as an admin
https://code.google.com/p/symlinker/
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
The last post was made 11 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 54.6 Kb
