FIX OR 2ND HAND ENGINE?
dou91e
PostPosted: 19:08 - 09 Oct 2014    Post subject: FIX OR 2ND HAND ENGINE? Reply with quote
I have a real bad knocking noise from the bottom end on my cbf125.
I have been told it is more than likely the crankshaft bearings but until its opened up we cant tell.
So I will have to pay for 2.5 hours labour to be told what the problem is.
If its the crankshalf bearings the parts will cost £70 then the fitting time on top. If its the whole crank needed its gonna cost a shed load more
So do I buy a 2nd hand engine if I can find one or spend between £300-£750+ on mine and get it rebuilt.
Is the cg125 engine the same as the cbf engine? I know the cbf is injected and the cg i think isnt but is the block the same?
PostPosted: 20:14 - 09 Oct 2014    Post subject: Re: FIX OR 2ND HAND ENGINE? Reply with quote
Pretty sure the CBF is totally different.
I would go for a new engine, then look to take the old one apart and have a look yourself.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:47 - 09 Oct 2014    Post subject: Reply with quote
I rebuilt a X5 about 20 years ago, just having the crank rebuilt after dropping the crank off off cost £200.
Let alone all the gaskets etc I had to get and the hours of stripping and rebuilding (plus the two piston kits and rebores).
I would have done what G said, but back then X5 engines weren't easy to find and there was no internets...
Triumph Sprint ST 1050
moonzoomer
PostPosted: 21:33 - 09 Oct 2014    Post subject: Reply with quote
The CBF is a 2 valve OHC engine with fuel injection, the CG 125 is a 2 valve OHV engine with a carb. The electrics on the bikes are totally different due to the fuel injection system on the CBF. Go for a good low mileage S/H engine from a crash damaged CBF from a good breakers who will give some kind of guarantee on the engine. These little bikes need good clean oil with regular top ups and regular oil changes, the most likely cause for a crank or main bearing failure is lack of the slippery stuff, oil changes with quality oil is the best and cheapest maintenance you can give these 125 cc 4t engines, if ignored they will self destruct.
this might give you an idea of replacement engine costs
https://www.ebay.co.uk/itm/CBF125-2009-M9-COMPLETE-ENGINE-VERY-GOOD-RUNNER-STARTS-1ST-TIME-V-SMOOTH-/201186123738?pt=UK_Motorcycle_Parts_13&hash=item2ed7a09fda
PostPosted: 21:57 - 10 Oct 2014    Post subject: Reply with quote
Given the chances of a replacement engine also shitting the bed, best result might be if it burns to the ground or gets stolen.
Not even joking though.
The last post was made 11 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 44.22 Kb
