| steverhysjenk... |
 steverhysjenk... L Plate Warrior
| Pete. |
 Pete. Super Spammer
 Posted: 14:49 - 11 Oct 2014 Post subject: |
You don't need a breather - you need a return. With an external pump there has to be a route back to the tank to bleed off excess fuel from the pressure regulator.
Here is how Suzuki do it on th eHayabusa. There's just a U-shaped piece of pipe welded into the tank bottom and pointing back down. There's also a small hole drilled in the underside of the U-bend I guess that's some kind of anti-syphon to stop it pulling air into the system somehow. This setup will let you get to a very low fuel level before th epump cavitates. I would say that a straight-up inlet would do or a 90-bend would be better.
On my bike I just plumbed the return onto the rear wall and let it spray out but I take care not to work the bike hard at low fuel levels because on a turbo it'll melt the pistons if the pump draws air on boost. ____________________ a.k.a 'Geri'
| steverhysjenk... |
| Pete. |
 Pete. Super Spammer
 Posted: 15:08 - 11 Oct 2014 Post subject: |
The two pipes are probably tank breather and a drain to take rain water or over-filled fuel from around the filler cap. You shouldn't use the breather as a fuel return as you're creating a closed circuit and there's no way for air to get into the tank as the fuel is used up. This could be what's causing your fuel starvation. ____________________ a.k.a 'Geri'
| steverhysjenk... |
| Pete. |
 Pete. Super Spammer
 Posted: 15:23 - 11 Oct 2014 Post subject: |
You just need a return hose barb, as I said in my first reply. ____________________ a.k.a 'Geri'
| steverhysjenk... |
The last post was made 11 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
