Home made DB killer
PostPosted: 15:58 - 11 Oct 2014    Post subject: Home made DB killer Reply with quote
Someone I know bought a 3 yr old Yammy R-125 which has a Scorpion pipe on it. Being a mature person he wanted to shut it up a bit since the yoof he bought it from had launched the factory one so that it sounded wikked Smile
So I said I'd make him a DB killer. I just bought a TIG welded and this could be my first non-paying job so it was a bit of fun for me too. Came out reasonably well.
PostPosted: 16:03 - 11 Oct 2014    Post subject: Reply with quote
Now the funny thing is, when I made it originally it had a much longer tube and no holes in it - it actually made the bike a LOT louder, like ear-drum-tickling loud. I cut the tube down and drilled the perforations and it was much better.
I did take some video on my phone but the noise-cancelling clipped all the loud bits off Sad
CarlosCBR
PostPosted: 17:08 - 11 Oct 2014    Post subject: Reply with quote
Awesome stuff... Fancy a bit of paid custom? In dire need of a baffle, unobtainable in the size I need :/
PostPosted: 17:19 - 11 Oct 2014    Post subject: Reply with quote
What sizes you looking for? I don't do paid work and I only just got started out with TIG welding this week so I can't guarantee results, but if you send me your critical dims I'll see what tube I have got.
RhynoCZ
PostPosted: 17:42 - 11 Oct 2014    Post subject: Reply with quote
Is the end of it sealed - inner part? If not, then it won't work. The pictures look like you just drilled a piece of pipe. Thumbs Up
Check mine (not that nice, couldn't weld thin metal): https://s970.photobucket.com/user/RhynoCZ/media/GPz%20-%20New%20exhaust%20system/Fotografie-0014.jpg.html?sort=3&o=15
PostPosted: 18:07 - 11 Oct 2014    Post subject: Reply with quote
It does work, check out the designs of the ones on eBay. I tried it un-drilled and then drilled and the holes quietened it down a good bit.
I'm surprised yours does with the way you've restricted it. What do you have, a dozen 8mm holes in that? If so that's like having a 28/29mm ID exhaust.
RhynoCZ
PostPosted: 18:22 - 11 Oct 2014    Post subject: Reply with quote
I made the holes bigger after - tuned it up slowly with bigger diameter of the holes. It gave me low/mid range torque boost and made the bike quiet like an OEM exhaust. Thumbs Up
What you did does restrict the exhaust gas flow, but not that dramatically so it'd significantly lower the noise. From my experience it's better to have a bit more noise though. Too restricted exhaust increases the head temperature which is not good. The holes you made have no purpose if the pipe is open.
I checked the google and every single DB-killer there is sealed up. Thinking
Anyway, nice work with the welding, what did you use? Smile
nowhere.elysium
The Pork Lord
PostPosted: 18:43 - 11 Oct 2014    Post subject: Reply with quote
Rhyno, you're just making yourself look daft. Please stop.
robocog
I /think/ I get why it would have been louder when the pipe was longer (and undrilled)
(but not sure if I am able to fully explain in words)
I'll try...
Imagine the tube was even longer - so the pipe was touching the end of the silencer where the exhaust pipe enters
the sound waves would have a direct unhindered route to the outside world - negating the wadding that is behind the oem perf tube and would have little or no effect or even louder than the std can
Making it shorter and holey has made a "trap" that /some/ sound waves will be reflected back into the can - and against the oem's perf tube and wadding
The more convolute the path the sound waves have to take the more silencing the wadding will absorb?
I guess the silencing effect at different rev ranges could be tuned by varying the length of the tube and drillings?
(rather than just an overall silencing effect??)
It's a black art I guess
Regards
Rob
Needs a bigger garage...
Tungtvann
PostPosted: 19:04 - 11 Oct 2014    Post subject: Reply with quote
Well it does work, my factory fitted DB killers are like that and it's considerably quieter.
https://www.mivv-shop.de/blog/wp-content/uploads/2009/08/IMG_5057.JPG
SQL
PostPosted: 19:10 - 11 Oct 2014    Post subject: Reply with quote
Mine is a sealed DB killer (Not that is it in) and it doesn't seem to make much difference to the sound at close proximity
PostPosted: 19:32 - 11 Oct 2014    Post subject: Reply with quote
I'll try...
Regards
Rob
I think you are along the right lines. The longer tube was more than half the length of the silencer so there was less room inside for the pulse to expand and lose energy. I cut it down to the length you see and it was much quieter but still quite intrusive so I then drilled holes in it. That made the biggest difference, the noise is less and it picks up better too. I might get some wadding and pack that around the perforated section to see how that affects it. I might also make a cap for the end just to see what it does. I've got some very fancy noise measuring equipment at work so I could bring that home and record the actual difference.
robocog
PostPosted: 20:56 - 11 Oct 2014    Post subject: Reply with quote
I'd be be very interested in your findings
esp just compared to a cap or stub
The ones in the pic Tungtvann posted also look like they have a bend on the end
If this was pointing towards the perf tube and packing I would think it would be muchmuch quieter - unless I am not understanding the images
I have a tig set here (DC only) - very satisfying stuff!
Just watch out for HF zaps , broken a few tunstens and end caps from dropping/lobbing the head (I assume keeping my gloves in metal roofed garage and working on a metal covered workbench is not helping)
Best thing I got for it was a flexible WP17 head and gas lens - ace for getting round tighter stuff with more stickout and being able to angle the head
I considered making a db killer for my GPZ after 1 escaped somewhere on the A32 (after a meeting and someone wanted to hear what they were like without and rather unhelpfully forgot to tighten the allen screws up)
Thing is I didn't notice till I got home and it sounded lumpy/uneven at idle (running twin exhausts)
I just bought another to replace it with as I didn't have any tubing the right diameter and mine is of the sealed type with a rather nice rounded end which I am not confident I could have made
What mine look like
https://i.ebayimg.com/00/s/MTAyNFgxMDI0/z/hEMAAOxycmBS514W/$_1.JPG?set_id=8800005007
Looking at the type you have and those images I'm now doubting that the type mine came with is doing as good a job as it could
I guess the type I have is just reducing the inner space that the sound travels through hoping more gets absorbed by packing?
It could be that mine needs re packing as it does seem much louder than when I first fitted them a few years ago, mainly at higher RPM
Regards
Rob[/img]
PostPosted: 21:20 - 11 Oct 2014    Post subject: Reply with quote
How's the fuelling and the exhaust values?
robocog
PostPosted: 21:28 - 11 Oct 2014    Post subject: Reply with quote
Is that to me Roger?
Regards
Rob
PostPosted: 21:43 - 11 Oct 2014    Post subject: Reply with quote
Shout out to all my peeps. But mostly Pete.
It's probably helped, but I'd be a bit hesitant to stick my dick in there, so to speak.
PostPosted: 21:53 - 11 Oct 2014    Post subject: Reply with quote
Injected bikes commonly run rich when fitted with a more open exhaust. Dunno why but this one is no exception the exhaust was black with soot. I don't know what effect the baffle will have as it's waiting for bits for it's 1st MOT.
Cockercas
PostPosted: 22:21 - 11 Oct 2014    Post subject: Reply with quote
Mine is pretty much the same as that. Unsealed.
105db without
97db with.
At 7k
stonesie
PostPosted: 22:26 - 11 Oct 2014    Post subject: Reply with quote
Nice work, it looks quite like the OEM Scorpion baffle except that is closed at the end.
https://shop.t3-racing.co.uk/ekmps/shops/t3racing95/images/scorpion-serket-exhaust-baffle-1009-p%5Bekm%5D300x168%5Bekm%5D.jpg
PostPosted: 22:29 - 11 Oct 2014    Post subject: Reply with quote
Aah, I never saw that pic. I have since spoken to a guy who has one and he said that he knocked the end cap out.
PostPosted: 00:16 - 12 Oct 2014    Post subject: Reply with quote
On what sample set are you basing that?
Honest question. I ask because I've just chopped up an end can for Ze Beemer, and it's like three weeks of work to get at the plugs to see how badly it's nobbing the fuelling.
PostPosted: 00:27 - 12 Oct 2014    Post subject: Reply with quote
Commented on it to the dyno man and he said it was often the case. Common belief is that they run lean like carbed bikes do with a pipe and a filter but he said that often the opposite is true esecially on FI bikes in the low-mid range.
Only way to know for sure is take it to the dyno or use a wideband. My wideband is broke right now with a failed sensor so I can't check this bike but I will when I get hold of another LSU4.2
The last post was made 12 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 124.68 Kb
