| G30 |
 G30 Nitrous Nuisance
| G |
 G The Voice of Reason
| thx1138 |
 thx1138 World Chat Champion
| stevo as b4 |
| yen_powell |
| Fladdem |
 Fladdem World Chat Champion
 Posted: 21:09 - 15 Oct 2014 Post subject: |
I love the EXC300, but out the box it is not a beginners bike. I would say it is best aimed at someone that has ridden for a couple of years and wants to go fast easily, rather than potter about. The suspension and engine cover up mistakes quite well, but on another note, the can cause it to get out of hand VERY quickly. Which will happen as a novice, wrong positioning, lack of confidence. It'd be like a gsxr 1000 as a first bike, easy engine at the bottom, due to torque of large engine, but too easy for corners to start arriving faster and tighter than expected, so you get a little flustered and the controls get muddled so you get spat off.
My advice, aim to get the 300 next. Start with a Serow or XR 250/400 or a KMX 200 if you fancy a smoker or even a Pampera 250. Something small, slow-ish, simple and cheap. It's the first trail bike, you will throw it down a hill, you are going to come off and it's better to do it to something easy to fix. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| G |
 Posted: 21:27 - 15 Oct 2014 Post subject: |
| Fladdem wrote: | I love the EXC300, but out the box it is not a beginners bike. I would say it is best aimed at someone that has ridden for a couple of years and wants to go fast easily, rather than potter about. The suspension and engine cover up mistakes quite well, but on another note, the can cause it to get out of hand VERY quickly. Which will happen as a novice, wrong positioning, lack of confidence. It'd be like a gsxr 1000 as a first bike, easy engine at the bottom, due to torque of large engine, but too easy for corners to start arriving faster and tighter than expected, so you get a little flustered and the controls get muddled so you get spat off. |
GSXR1000 is a pussycat, so, err, yes?
If you try and go flat out on the EXC, you're going to get yourself in trouble at a higher speed. But go at the same speed and it'll be able to cope better.
Although, given M1ke's impression of the EXC compared to yours, maybe you're just a bit of a wimp on it?
I had plenty of novices ride my 300 and none found it a problem (bar the height for the less confident shorties - and we're talking a chunk shorter than 5'7".) |
| stevo as b4 |
| G |
 Posted: 00:51 - 16 Oct 2014 Post subject: |
Sure, a XR125 in the right hands can be pretty capable, no doubt.
But, put it in inexperienced hands trying to ride at a pace they could easily on something like the EXC and I suspect it's a lot more likely to end badly.
To start with, the XR is listed at 15kg heavier than the EXC. Pick that up a few times and you may well be starting to notice it, for a start.
If you give the EXC a handful in the midrange, you're going to get a reasonable hit. Which is why you ride it a couple of gears up until you get used to it.
And how do you think the guys on the Betas would have done on an XL? There's a reason that he could handle a heavy road 4 stroke and I'd suggest that's because he's got the skills already - those that don't such as myself, do better on a light weight competition 2 stroke .
Similarly, there was a video of someone ascending a pretty steep hill very comptently on a XR250, which are pretty capable bikes. But I still bet if you give an inexperienced rider a XR250 or a 300EXC, they'll do better on the 300 and probably be less likely to hurt themselves too.
I've ridden a reasonable range of bikes off road, from a DT50 to a ZX9, via most sizes of competition and road 2 and 4 strokes. Small capacity 4 strokes and more road biased 2 strokes are hard work if you don't want to dwaddle - because you have to be really on the gear changes and keeping it on song.
Some of my first proper green laning was done on a DR600. They're not TOO heavy and I was generally a gear or two higher to just use the bottom end - but for people that weren't generally reasonably confident already, having to muscle the extra weight around isn't ideal.
I still think the 300 enduro bikes provide the most user friendly introduction to dirt biking. With the caveat that the rider isn't a total twonk that's going to try and set lap records - which certainly will end in pain. |
| Fladdem |
 Posted: 23:28 - 16 Oct 2014 Post subject: |
I may be wrong, but that 300 of M1kes is a pussycat because the PV is playing up and because him and Rhys, the lad that had it before, spent a lot of time messing with it to make it that way. It was his first trail bike but even after that he said it was a bit much for him.
As to a hit there is none... it pulls like my TTR off the bottom, then at half revs, where my bike stops making power and the throttle just controls noise, the KTM keeps making power in a very linear smooth method until the rev limit. But the revs change MUCH faster than my bike and being so light I reckon a novice could get over excited quickly.
Also, imagine keeping up with orange bikes on a Serow, how easy would it be when you upgraded? I started on my MT5, you needed to be on it constantly to get anywhere, my TTR made it so much easier afterwards. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
