Can You Re-Prime An Aerosol Can?
andym
PostPosted: 11:50 - 14 Oct 2014    Post subject: Reply with quote
Can't you just use an air line? (not sure what kind of fitting you would use though)
angryjonny
PostPosted: 11:51 - 14 Oct 2014    Post subject: Reply with quote
https://lifehacker.com/5660420/recharge-an-aerosol-can-with-an-air-compressor
duhawkz
PostPosted: 12:39 - 14 Oct 2014    Post subject: Reply with quote
awaits the "oh shit I've blown my fingers off" thread Shocked
Aff
PostPosted: 12:44 - 14 Oct 2014    Post subject: Reply with quote
Yes.
I've soldered a Schrader Valve into the top on quite a few large spray cans.
You can then remove the core, pour a bit of whatever liquid you want to spray into it. Put the core back in and pump up (i use a bike pump) to about 100 psi*.
Works well.
I will post a pic later if I remember.
*I asked a guy that's a production manager at a factory that makes WD40 what pressure they use. He said it's around 100 psi ± 10 psi.
He did say he thinks thats a bit lower than most aerosols use though.
Electric Bike Project
PostPosted: 13:04 - 14 Oct 2014    Post subject: Reply with quote
Vincent wrote:
How could/would that happen?
Typing with his toes.
iooi
PostPosted: 13:32 - 14 Oct 2014    Post subject: Re: Can You Re-Prime An Aerosol Can? Reply with quote
Vincent wrote:
I've got a large spray can of brake cleaner, over half full that won't spray....it just doesn't seem to have any pressure behind it.
You sure its not just the nozzle that is blocked.
monkeybiker
PostPosted: 16:25 - 14 Oct 2014    Post subject: Reply with quote
Do you know what I would do, I would go to the shops and buy another can Thinking
Aff
PostPosted: 16:28 - 14 Oct 2014    Post subject: Reply with quote
Why spend 4 quid a can on brake cleaner when you can buy 5L of Acetone for a tenner and pump in some free air?
monkeybiker
PostPosted: 16:50 - 14 Oct 2014    Post subject: Reply with quote
Vincent wrote:
That's what they want you to do Wink
Well good for them.
smegballs
PostPosted: 17:46 - 14 Oct 2014    Post subject: Reply with quote
You can recharge them with lightergas refill quite well, you leak a bit of butane but be careful and it's fine.
I've recharged plenty of WD40 cans with £1 lighter gas refills before.
Ariel Badger
PostPosted: 22:29 - 14 Oct 2014    Post subject: Reply with quote
You could heat it with a blowlamp but it may well blow up and take your face off.
Dave70
PostPosted: 22:45 - 14 Oct 2014    Post subject: Reply with quote
Interesting suggestions.
What could possibly go wrong? Laughing
Hurt
kramdra
PostPosted: 22:54 - 14 Oct 2014    Post subject: Reply with quote
wd40 aerosols are silly. Pierce can and drain oil out into a suitable air pump spray bottle. Its also a lot cheaper to buy it in a bottle, and paraffin is even cheaper.
Brake cleaner probably not a great idea tho.
andym
PostPosted: 22:59 - 14 Oct 2014    Post subject: Reply with quote
Why not? In college I asked for some when I stripped my calipers.... they handed me a 5 litre tin of brake and clutch cleaner, a cheap spray bottle and funnel and told me to fill it myself
bikertomm
PostPosted: 23:02 - 14 Oct 2014    Post subject: Reply with quote
When WD40 cans get to the end it's best practice to stamp on the fucker until it works again is it not?
Even better when you create a small hole so it pisses out perfectly.
I thought this was the manly thing to do. Wink
duhawkz
PostPosted: 23:10 - 14 Oct 2014    Post subject: Reply with quote
Paraffin is oil, probably don't want to spay it all over your brakes.
Make great release spay though, diesel works well too
PostPosted: 23:55 - 14 Oct 2014    Post subject: Re: Can You Re-Prime An Aerosol Can? Reply with quote
Vincent wrote:
I don't think it is....will check tho.
Be careful. It is a real pain when you have taken the nozzle off and are looking at the can to check it isn't blocked and press it instead. With paint it takes ages to scrub it off your face Razz
kramdra
PostPosted: 00:37 - 15 Oct 2014    Post subject: Reply with quote
Brake cleaner is 'light petrol'. I assume one could not use actual unleaded petrol as the additives could effect braking. I dont know where to buy cheap 'light petrol'? but I have been using quite a bit recently. 2 quid a can Shocked
Petrol being highly flamable, might not be good in a bottle with a pump mechanism which might create static electricery?
The last post was made 11 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 133.22 Kb
