recommend me an e-cig
Baffler186
PostPosted: 15:09 - 20 Oct 2014    Post subject: recommend me an e-cig Reply with quote
So, I’ve read through the e-cigging threads but I’m still rather confused. Can someone link me to a kit that is relatively cheap and small?
For the past (ages) I’ve been using those cigarette-type ones that you can buy in Morrisons, taking the lid off the cartridge and filling with cheap e-liquid (3 bottles for £5).
But, after a week or two the packing inside seems to break down and it leaks everywhere and won’t hold any fluid, meaning I have to buy the extortionately priced cartridges at £7 for 2.
I just need a small kit, battery life not an issue, as cheap as possible so I can just refill it without it leaking.
Also has anyone used the ones they are selling in the Premier convenience stores? They are £14 but not sure how good they are or how long they will last? The ones I've seen on the other thread all seem to be £40 and up.
thanks
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
wr6133
PostPosted: 15:21 - 20 Oct 2014    Post subject: Reply with quote
https://www.vapourlites.com/stoptober/advanced-stoptober-kit.html
Use the code STOP50 at checkout and it's half price. Doesn't have a charger though so check your charger from your current stuff fits.
Baffler186
PostPosted: 16:17 - 20 Oct 2014    Post subject: Reply with quote
Cheers, that looks good, but it says the clearomizer is disposable and should last 1-2 months. Are they all like that? I don't want to be buying parts!
wr6133
PostPosted: 16:46 - 20 Oct 2014    Post subject: Reply with quote
I've got clearomizers here I've used a lot longer than that. If they do wear out then they don't cost a whole lot on eBay (10 for around 9 quid).
I've got the set I linked and a couple of same but unbranded batteries from eBay, I find with 3 I can vape all day without needing to charge (2 would probably be enough if you can get to a usb to charge at some point in the day). The branded vapourlite battery lasts longer than the larger unbranded ones I have.
Mark_F
PostPosted: 16:47 - 20 Oct 2014    Post subject: Reply with quote
You can get all sorts of clearo's, cartomizers, tanks etc whereby you can clean them and just replace the heads (EVODs are the current early go-to, and replacing a head is cheaper than replacing the whole clearo).
You will always need to buy parts of some description though. I usually have 5 or 10 spare heads knocking around so when one starts tasting a bit off, or getting tight in the draw, I just clean it and replace the head.
trevor saxe-coburg-gotha
PostPosted: 17:51 - 20 Oct 2014    Post subject: Reply with quote
Here's where I started:
https://www.totallywicked-eliquid.co.uk/products/electronic-cigarette-starter-kits/advanced-kits/starter-kits/tornado-t-starter-kit-and-2-x-e-liquid-product.html
Almost certainly not the best, ditto the cheapest. But it all works adequately, and most important of all, the amount of fags you smoke will shrink to almost none. Maybe just the odd one here and there, which you'll probably just accept if offered.
17-in-87
PostPosted: 18:45 - 20 Oct 2014    Post subject: Reply with quote
https://myepack.co.uk/kits/mini-protank-2-kit.html
This one.
Comes with 5 spare heads, all you need to add is liquid.
£20 Thumbs Up
K1 GSX-R 600 - blue n white of course....
Growing old is compulsory - growing up is optional...
Baffler186
PostPosted: 20:34 - 20 Oct 2014    Post subject: Reply with quote
This one.
£20 Thumbs Up
that looks just the ticket. Much obliged all
el_oso
PostPosted: 22:29 - 20 Oct 2014    Post subject: Reply with quote
I never liked the pro tank. It used to spit in my mouth Embarassed
I've got the aspire nautillus. By far the best tank I've used, it is massive though and not really one to take out doors. The nautillus mini is better on the move but still rather large. Same adjustable airflow as with the full size nautillus.
My really mobile one now is the aspire k1. No adjustable airflow on this one but still really good flavour with them dual coils. The k1 head is more expensive, but you can replace just the coil on these which is something like £2 a pop.
Duke 390
Car: Jeep Wrangler 4.0L
Slacker24seve...
PostPosted: 07:03 - 21 Oct 2014    Post subject: Reply with quote
Evod, or preferably an Evod 2 or glass.
Cheap, simple, doesn't look like a space age medical implement but very satisfying.
Banger rallies are ace
Method
PostPosted: 16:16 - 21 Oct 2014    Post subject: Reply with quote
Exclamation Do not do this. Please.
If it does not come with a charger, and you are just getting started - BUY AND USE THE CORRECT CHARGER FOR THE DEVICE.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
CaNsA
PostPosted: 16:20 - 21 Oct 2014    Post subject: Re: recommend me an e-cig Reply with quote
Did you not ***Read Kerr's Post, Middle of p39 for newbies.*** ?
TBH, would have been a better idea to post this question in the actual thread IMO.
Turkish
PostPosted: 19:46 - 21 Oct 2014    Post subject: Reply with quote
For genuine tabacco flavours go here: https://www.houseofliquid.com/
No affiliation. All their liquids are made from tabacco leaves and then steeped in oak barrels. The result is a very potent and smoky tabacco flavour with woody notes. The "Cellar Reserve" is steeped for 3 weeks in an oak barrel used for storing Metaxa brandy - you can probably imagine how that tastes (i.e. fucking awesome).
My personal favourite is El Toro Guevara, tried the 12mg and 18mg. Both are good.
The only downside is that they have a very high % VG which clings to your coil and reduces it's useful life to around 10mls of vaping before replacement - once every few days with moderate/high use.
If you buy rebuildable coils though you can get a 50 or so rebuilds worth of wire & wick for around £5. It is a bit fiddly though. Having said that, I quit smoking around 3 months ago - there is no way I will ever go back now.
ZX-6R G2
CBR125R RW6
The last post was made 11 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 80.01 Kb
