Yamaha Aerox pad retainer stuck!!
Aeroxdude
PostPosted: 15:57 - 25 Oct 2014    Post subject: Yamaha Aerox pad retainer stuck!! Reply with quote
Hi BCF
I have a problem with my yamaha Aerox 50cc, my front brake pads need to be changed, but my problem is, that the pad retainer is stuck, see pictures.
It's almost like the bolt is too big in the end, so therefore it can't be pushed out, I don't know if they have heated the caliber a little bit, before inserting the bolt....?
But I really need some good advice how to get the bolt out, so I can get new brake pads in, and on the road again...
Thx in advance
c_dug
PostPosted: 19:16 - 25 Oct 2014    Post subject: Reply with quote
Jeez those pads look gammy. Willing to be the pistons aren't in much better condition. Rather than wrestling with it it may be worth seeing if you can pick a decent second hand caliper up?
b422063
PostPosted: 19:55 - 25 Oct 2014    Post subject: Reply with quote
There is so much corrosion all around in that image that I expect it's stuck due to corrosion. Assuming your ditching the pads, penetrating oil and leave for a bit and then remove.
As said, would equally consider a new caliper too.
merquis00
PostPosted: 02:25 - 26 Oct 2014    Post subject: Reply with quote
The fake brembo's on my dna were the same.
Grab a Hammer (small) and punch/tent peg - then tap it out.
Not like its going to get "more" stuck Thumbs Up
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
Aeroxdude
PostPosted: 06:51 - 26 Oct 2014    Post subject: Reply with quote
I think the pistons are still good, but I was hoping that I only had to change the pads, because a new caliber is pretty expensive I think... Rolling Eyes but I will try to tap it out with a hammer first...
But lets say that I get it loose, when I install the new pads, is it a good idea to use cobber grease between the pad and piston, so it won't get stuck right away...?
b422063
PostPosted: 07:50 - 26 Oct 2014    Post subject: Reply with quote
It's good practice to use copper grease, if not just to stop the squealing. I'd strongly recommend cleaning the caliper and piston up whilst the pads are out.
Aeroxdude
PostPosted: 11:01 - 26 Oct 2014    Post subject: Reply with quote
Ok i will do that, and when I get some spare time, i will try to tap out the bolt, and we see how it goes, i keep you updated...
Aeroxdude
PostPosted: 01:26 - 04 Nov 2014    Post subject: Reply with quote
Update: I got the bolt out, and cleaned it all and mounted the new pads, but when i cleaned it, i pushed the brakehandle, to get the pistons in the caliber a bit out, so i could clean it better, with that result, that the piston got all the way out of the caliber (bad luck Sad), and a bit of brake fluid got out, i put the piston back in as fast as i could, but i think the seals (i think that's the name for it) may have been damaged in the process, because when i push the brakehandle now, after assembly of the front brake, i have no pressure, i have also tried bleeding it, but no results, so now i have bought new pistons and seals for the caliber, and i cross my fingers, i will update when i've tried that Smile
Dave M
PostPosted: 01:44 - 04 Nov 2014    Post subject: Reply with quote
Rebuild it with new seals or just buy a second hand one.
mudcow007
PostPosted: 09:51 - 04 Nov 2014    Post subject: Reply with quote
pop the pistons out again an post a picture up on here
you may be able to get away reusing your current pistons, but its probably worth getting new seals
people swear by using red rubber grease when refitting the new seals, but i struggled an ended up just using shit loads of brake fluid to coat everything in
oh buy some coppaslip too
The last post was made 11 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 64.47 Kb
