buggering up braking
Wonko The Sane
PostPosted: 22:42 - 29 Oct 2014    Post subject: buggering up braking Reply with quote
I really should know and be doing this, however…
There are times when I need to brake a bit harder than I'd like and I find the back end snaking a bit.
How should you brake in the wet if you have to brake hard, I'm obviously doing it wrong?
Mikebike
PostPosted: 22:51 - 29 Oct 2014    Post subject: Reply with quote
Don't brake harder in the wet, read the road and brake earlier and smoother. If the back end is snaking you are leaving it too late. Being Rossi on the road will only lead you to 6ft under.
James83
PostPosted: 22:55 - 29 Oct 2014    Post subject: Reply with quote
I take the view that the back brake is for 3 things
Car park speeds maneuvering when you are new and need the stability
For hill starts until you learn how to use the front brake and throttle at the same time
For thinking "Hmmm, forgot to apply back brake again" just after performing an emergency stop
I long since stopped worrying that I forget about it. As far as I'm concerned, if my rear wheel has enough traction to make a difference during an emergency stop, then its my use of the front brake that needs work
Jonathan A wrote: tart.
Mikebike
PostPosted: 22:57 - 29 Oct 2014    Post subject: Reply with quote
Wow.......really!
Mikebike
PostPosted: 23:10 - 29 Oct 2014    Post subject: Reply with quote
No shit Sherlock...is this amateur hour on riding a bike!
If you are braking and the back is snaking then your hazard perception/control is well off. Just because Rossi/Lorenzo or sheene did it doesn't mean you should on a road.
Get some training in roadcraft (look it up) and ride fast but safe unlike most dickheads that think the throttle is an on/off switch.
It's not rocket science and would make your riding faster/smoother/safe and more enjoyable.
PostPosted: 23:12 - 29 Oct 2014    Post subject: Reply with quote
Confused
Pretty sure the back brake is there to continue a slide which has been initiated with engine braking?
I initially presumed the OP was braking hard enough with the front that the rear was lifting.
The rear is always more likely to slide, but generally less catastrophic if it does.
It sounds like you need less rear and more front, but obviously you do need to be careful overall for the conditions.
It's also worth considering, as well as time taken learning to brake, putting some time learning about the best way to avoid getting yourself into situations where you need to brake hard!
map
Mr Calendar
PostPosted: 23:14 - 29 Oct 2014    Post subject: Reply with quote
You do not brake hard as in quickly pull front lever. Best to squeeze and then continue to squeeze.
In the wet, as said, smooth and controlled, reading the road ahead (it's quite hard concentration).
That's what I try anyhow.
Mikebike
PostPosted: 23:15 - 29 Oct 2014    Post subject: Reply with quote
Continue a slide......are we talking about supermoto racing at three sisters?
PostPosted: 23:29 - 29 Oct 2014    Post subject: Reply with quote
We are talking anywhere you may wish a slide to continue on any bike you may wish this to happen on.
Mikebike
PostPosted: 23:30 - 29 Oct 2014    Post subject: Reply with quote
So your not talking on the road then? Or is it just another forum full of people talking bollocks!i
Wonko The Sane
PostPosted: 23:33 - 29 Oct 2014    Post subject: Reply with quote
It came to light yesterday as I was riding slightly outside my limits trying to catch another biker who's rear lights weren't working in the hope of warning him before he found out the hard way, someone cut him up, he braked (brake light worked but no tail light) so I had to brake harder than I would have otherwise.
I backed off after that as no point me taking us both out just to tell him one of his lights is out. (did manage to catch up safely a bit later and let him know)
My riding is usually more cautious in the wet
I was wondering if I was applying the back brake too early / quick before the front had taken the weight of the bike (I do have a tendency to skid 125's a bit when I jump on one)
Wonko The Sane
PostPosted: 23:35 - 29 Oct 2014    Post subject: Reply with quote
I do squeeze and continue to squeeze, I'm presuming that the weight of the bike over the front, as the suspension compresses is reducing the pressure on the rear = skiddy tankslappy kind of effect
Wonko The Sane
PostPosted: 23:36 - 29 Oct 2014    Post subject: Reply with quote
When NOT to do it is when you've borrowed a friend's bike that's a heavier tourer rather than your normal GSXR1000 commuter, you've just overtaken another bike and there's snow around. Of course, it could be argued that having experience of doing said manoeuvres already is the reason for not ending up on the deck in such a situation.
Also; can I suggest you visit the tin foil hat current affairs section as well as 'Random Banter' to asses the testicular content.
Much as someone would like, sure it's no /b/, but plenty is available.
Doesn't mean others don't ride bikes.
That there is you're problem.
Forget trying to catch up with people. You'll end up getting yourself dead. Stick within your comfort zone no matter what. Should you wish to test your boundaries then you control it not other people's mechanical/electrical faults. Wink
Wonko The Sane
PostPosted: 23:40 - 29 Oct 2014    Post subject: Reply with quote
As I said, this was the one exception for attempting to keep up, dark, wet rush hour motorway with no tail light, I'd like to think another biker would attempt to safely tell me.
There are things outside my control that can give me a shorter stopping distance than myself and my ZZR would like, I have had the same thing happen when stopping at short notice before, thankfully it's a rare occurrence but I'd like to work out what's happening in the hope of learning to avoid it.
Mikebike
PostPosted: 00:12 - 30 Oct 2014    Post subject: Reply with quote
First off, don't try to keep up with some knobhead who can't even check out his own bike you are not his guardian angel.
Secondly if you are risking your life to do so by riding outside your comfort zone then back off and live another day.
FlightRisk
PostPosted: 00:29 - 30 Oct 2014    Post subject: Reply with quote
Are you gripping the tank with your knees when you brake, or with arms going rigid on the bars?
If you grip with the knees and stay loose with the bars there's less rotational force so the front should dive less. Just learnt that the other day.
Honda CB500S
Mikebike
PostPosted: 00:33 - 30 Oct 2014    Post subject: Reply with quote
Roadcraft..... Google it. Spend a few quid getting trained to properly ride your bike. Ignore everything you are told on a bollocks forum and learn to ride your bike properly/quickly and safely
PostPosted: 00:40 - 30 Oct 2014    Post subject: Reply with quote
Just to clarify, do you consider this such a forum?
If so, presumably we should ignore what you tell us.
Which, I believe, leads to your collapse into a paradox!
Andy_Pagin
PostPosted: 00:41 - 30 Oct 2014    Post subject: Reply with quote
I recall a line from Spike Milligan's war memoirs that perfectly sum up how to use brakes.
Spike was doing his basic rifle training and shooting wide of the mark. The sergeant saw that he was snatching the trigger and told him to "squeeze it slowly, like a birds' tits".
Same with braking, squeeze the front brake lever progressively, feeling for the bikes reaction, press the back brake lever just as gently, if either end feels like it's doing something scary then eeze off a bit.
Mikebike
PostPosted: 00:46 - 30 Oct 2014    Post subject: Reply with quote
Ok mate on a CB500 brake as hard as you like as the bike has shitter brakes than my mountain bike!
Roadcraft....Google it then book yourself on!
Forums........WTF
PostPosted: 00:47 - 30 Oct 2014    Post subject: Reply with quote
Commute for 2 hours a day in stop-start city traffic and you'll soon learn what a back brake is best used for.
notbike
PostPosted: 00:59 - 30 Oct 2014    Post subject: Reply with quote
Is it only me who uses both brakes? This guy I randomly met who has a ZX6R was saying how he's pretty much forgotten about his rear brake and uses almost all front except slow speed.
I still use some back brake all the time, even though I always brake harder with the front brake. Sometimes I do use just front, but it feels sloppy to me to come to a stop with the front only.
When coming to a stop at traffic lights I'll use both brakes and ease off the front brake when I'm slow enough to stop using just the rear + the remainder of the engine braking before clutching in last second.
Real life E-Stops with the adrenaline flowing at the thought of impending doom are almost always a rear brake lock for me, so instead of wasting time practicing E-stops that I will never replicate in a real life situation, I try to use just front only and avoid smashing on the rear brake. (Pointing your bike at the nearest gap that gives you enough run-off is also a good way of avoiding the thing you could be hitting, but only brake in straight lines when braking real hard)
It's funny how everyone suddenly becomes an expert in braking when they talk about close shaves and what not, but really my thought pattern is "STOP. STOP. STOP. AVOID. DONT LOCK UP, DONT LOCK UP, DONT USE REAR, AVOID, SHIT, FUCK ME that was close."
Anyway, go practice braking with an instructor and it'll teach you how to use your brakes better than you could teach yourself with advice from the internetz, if you think it'll help you then why not?
The last post was made 11 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 129.51 Kb
