CBR125 struggling to start
el_oso
PostPosted: 16:00 - 01 Nov 2014    Post subject: CBR125 struggling to start Reply with quote
recently purchased a CBR125 as a winter/commuter hack. I've had no real luck trying to get it started. The bike has been sat (apparently) for the the last 18months.
So far I've tried fresh fuel and checked the airbox and breather hoses for blockages all seem clear. I've taken the carb off and cleaned it, didn't seem to gummy anyway. I've had the spark plug out to check the spark and it's good and blue. It's strong enough to shock me through two pairs of gloves. The one thing I did think that was a bit odd was that the plug was bone dry. I would have thought that if fuel was going through and not igniting it should at least be slightly damp.
I've had it running a couple of times but would die instantly unless I have the throttle open at maybe halfway or more. Any ideas? Clean the carb again paying particular attention to the pilot circuit?
Duke 390
Car: Jeep Wrangler 4.0L
UrbanRacer
PostPosted: 16:23 - 01 Nov 2014    Post subject: Reply with quote
Side stand sensor fault? Killswitch fault?
el_oso
PostPosted: 16:38 - 01 Nov 2014    Post subject: Reply with quote
why would it run sometime but only with half a twist of throttle?
Duke 390
PostPosted: 17:22 - 01 Nov 2014    Post subject: Reply with quote
Assuming 04-early 07 given the carb, they use a vacuum tap which is terrible. Make sure that it is working as intended. The rubber hose degrades and means no vacuum.
Also, the take breathers get caught VERY easily, sitting on the bike, right hand side, 2 rubber hoses should be under the tank, make sure its not kinked.
el_oso
PostPosted: 11:07 - 03 Nov 2014    Post subject: Reply with quote
yeah, I had a quick look at the tap and it didn't seem great. I removed the breather hoses after a while and still no luck. I'll have a look at the vacum hose tonight see if there are any leaks.
Fuel seems to be getting into the float bowl though. I undid the float bowl drain screw and that was full of fuel, just not sure anything is getting into the cylinder. Can't be sure though. I would expect the plug to be wet though.
Duke 390
PostPosted: 12:04 - 03 Nov 2014    Post subject: Reply with quote
Only thing then would be jets, but assume you'd have cleaned them when you cleaned the carb?
el_oso
PostPosted: 13:54 - 03 Nov 2014    Post subject: Reply with quote
I would have thought so to. Might have been a little careless as it looked pretty clean anyway.
Duke 390
The last post was made 11 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 5 - MySQL Queries: 13 - Page Size: 50.44 Kb
