sticky throttle when closed
thx1138
PostPosted: 18:55 - 02 Nov 2014    Post subject: sticky throttle when closed Reply with quote
When fully closed, throttle sticks, needs an extra bit of "oomph" to twist it open pas the sticking point. Otherwise it seems to ride fine.
What's the likely cause? I'm guessing there is some sort of springy thing, that makes the twisty thing shut the throttle off, and is snagging when its turned back to open it?
SQL
PostPosted: 19:07 - 02 Nov 2014    Post subject: Reply with quote
normally frayed pull cable
qarka
PostPosted: 19:10 - 02 Nov 2014    Post subject: Reply with quote
Push/pull throttle or just pull (1 cable)?
Got to be sticky cables or sticky throttle linkage (at the carbs).
You can lube the cables by making a hole in the corner of a freezer bag, push the cable through, tape/zip tie it up and fill the bag with oil then squeeze till it drips out the other end.
If it's the linkage then disassemble clean and lube it up I guess.
Might need a new spring.
HTH
thx1138
PostPosted: 09:58 - 03 Nov 2014    Post subject: Reply with quote
@ qarka it's a two cable jobby
and yes, twist grip must have come off, as it has had replacement handlebars put on
so...
maybe the cable is just too tight?
I'll run it down the road to the local mechanic I use and ask them to do it
(and before anyone says, do it myself, no, just no Laughing I cannot be trusted with spanners)
edit: Stopped doing the sticky thing when I rode it. Got it looked at anyway, bit of grit or something in there, and cables now too tight with risers and new handlebars, adjustments to slack made as much as possible - will look at putting different throttle cables on, took vin numbers and will get back to me later today.
but it actually rode fine no problems.
mudcow007
PostPosted: 13:09 - 03 Nov 2014    Post subject: Reply with quote
i found my grips were err gripping my bar plugs, might be worth checking them too
The last post was made 11 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 47.97 Kb
