| P.addy |
 P.addy Red Rocket
 Posted: 15:10 - 02 Nov 2014 Post subject: Honda X8R not starting... |
Hey,
Got an X8R.
Has fuel, is getting fuel to carb happily. Carb is spotless.
Has compression, more than enough.
Is only sparking when you let go of the starter button, just 1 single spark, whilst cranking there is fuck all.
Any ideas? Its crap weather so thought I'd spend the day fixing, however after making sure everything fuel wise is great, it just won't spark on the button, only when you let go.
It does have some aftermarket bits, PM Tuning CDI so perhaps that is causing issues, however there isn't much you can do with it bar adjust "delay" and "rpm" so I won't be messing with it, no idea what they do.
Any hints/tips/fixes I can do would be greatly appreciated, I'm afraid I'm out of ideas  |
| doggone |
 doggone World Chat Champion
 Posted: 15:22 - 02 Nov 2014 Post subject: |
Dodgy coil?
Tried an alternative plug?
| andys675 |
 andys675 World Chat Champion
| G |
 G The Voice of Reason
| P.addy |
 P.addy Red Rocket
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 21:33 - 02 Nov 2014 Post subject: |
We have life.
I just spent a few minutes stripping the coil off the frame. I assume they have lots of spiders in York as I found a family of them chilling on the coil..
I've given it a quick clean up and hey presto, tick tick tick
How to figure out why its not pumping oil  |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 22:25 - 02 Nov 2014 Post subject: |
I shall, however getting to it requires either cutting the frame or removing the swing arm...  |
| Vincent |
 Vincent Banned
| stevo as b4 |
| map |
 map Mr Calendar
 Posted: 10:34 - 03 Nov 2014 Post subject: |
If pump is an issue you can run on premix until sorted. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| P.addy |
 P.addy Red Rocket
 Posted: 12:06 - 03 Nov 2014 Post subject: |
Premix would be fine, however I aim to run an additional fuel tank, just because So would be ball ache to mix an unknown amount of fuel.
That and I'd have to upjet etc. |
| _Iain_ |
 _Iain_ Banned
 Posted: 12:30 - 03 Nov 2014 Post subject: |
| map wrote: | If pump is an issue you can run on premix until sorted. |
I did suggest this.
However, why not run it on premix and leave the engine ticking over with the oil feed off?
Hold pump cable flat out open, disconnect oil feed from tank & blow down it till whatever blockage or goo spurts out the other end, reconnect tank, blow into tank till oil starts coming out at the other end, wait till oil coming through as expected, let oil pump cable back to normal position, re-attach oil feed & done innit.
There's probbably better ways of doing it, but minimal dissasembly required that way & minimal tools required.
https://www.micksgarage.com/images/honda/bikes/SZX50SX_1999_E-9%20CRANKCASE%20-%20OIL%20PUMP.png
| Some pedboi on a scooter forum wrote: | it wont come squirting out tho i warn you now haha, to bleed my oil pump i had to run a drill full pelt on the pump for 2 batteries to get the oil through a tube 10cm long, and with the drill on full it only just dripped out the end |
____________________ Please be aware that the above post may be full of complete nonsense.
| Vincent |
 Vincent Banned
 Posted: 16:07 - 04 Nov 2014 Post subject: |
If you use pre-mix, make sure it's not running too weak before you detonate the top end. And if you're going to try and blow clear the oil feeds, blow backwards 'First place to look for a blockage may be the bottom of the tank. I prefer clear lines on autolube sytems so you can follow them for any bubbles etc, I don't know why the makers use black pipes...down to £'s no doubt
Pumps are usually pretty simple and there's not much to go wrong, I'd try and get it sorted. When I found it hard to get my hands in somewhere on a bike or car...and he was young enough... I'd get my son to undo stuff Nobody about with tiny hands? ____________________ Space Is Deep |
The last post was made 11 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
