Little breakdown
recman
PostPosted: 22:42 - 02 Nov 2014    Post subject: Little breakdown Reply with quote
Went out for a spin earlier, stopped off at Tesco in Baldock for fuel but when I tried to set off I only got a couple of turns of the engine, then nothing.
Called the wife to come over with the jump leads but got no joy there either. Leads must be fucked.
Had no choice but to call the AA and fair play, they only took 15mins to arrive.
So he connects up his battery diagnostic/multimeter thingy and tells me all is well with the alternator but the battery has a bad cell.
His portable booster started the bike nicely so I was on my way again.
To be fair, the bike was starting to labour a bit when starting over the last few days but I didn't expect such a sudden failure.
Live and learn. Wink
So does anyone think its worth connecting up my Ultimate or does having a bad cell mean its on its way to battery heaven?
Tl;dr - Went out, got stranded with a knackered battery, called AA, home now.
PostPosted: 22:46 - 02 Nov 2014    Post subject: Reply with quote
Replace battery, however check the charging system. Triumphs have been known to chew their reg/recs...
MattEMulsion
PostPosted: 22:52 - 02 Nov 2014    Post subject: Reply with quote
Your battery is obviously knackered, don't bother trying to save it with an Optimate or such like, just get a new one. Thumbs Up
Yamaha YZF-R6
recman
How do you go about checking the reg/recs?
Would a reg/rec failure cause the battery to have a bad cell?
I suspect its the original battery which is over four years old now so maybe its just given up.
As you say, time for a new one.
recman
PostPosted: 22:55 - 02 Nov 2014    Post subject: Reply with quote
MattEMulsion wrote:
Optimate
Yes, this is what I meant. Embarassed Doh!
PostPosted: 22:57 - 02 Nov 2014    Post subject: Reply with quote
Get the bike started again.
Multimeter + and - on battery, rev to about...5k, hopefully you have 14.1>14.6V going into battery, usually 14.3 or 14.4 on my Triple.
Any more, likely reg rec is toasty. If its still in the mid to low 12s, I'd be checking the stators output, but test that first.
recman
PostPosted: 22:59 - 02 Nov 2014    Post subject: Reply with quote
I'll get onto it when I chuck in the new battery, cheers. Thumbs Up
Pigeon
PostPosted: 23:01 - 02 Nov 2014    Post subject: Re: Little breakdown Reply with quote
Might be worth a shot, if only because Optimate's can report some failures.
My ST has been on Optimate for 3 days every 3 days roughly. Leave it much longer between charges / use and the Datatool possibly drains the batter by the couple of clock re-sets I had early on.
But just a couple of weeks ago, it failed, showing a red light indicating the voltage dropped below 12.5v during it's testing phase.
I tried turning it off/on (the Optimate) and used the bike the next day and both bike + charger have been fine since.
recman
PostPosted: 15:29 - 09 Nov 2014    Post subject: Reply with quote
Quick update.
Since getting the bike home last Sunday, I haven't started it or put it on charge.
The only thing I've done is to put the alarm into the low drain winter mode.
I tried it just now, not expecting too much but it fired up like nothing was wrong.
I tested the battery to see if there was any kind of standing voltage drop or massive drop on turnover but had no problems with either.
Standing voltage was a constant 12.25v with a start up drop down to 10.5v.
So I did the reg/rec test according to Paddy's instructions which gave me the same results, a steady 14.35v.
PostPosted: 15:37 - 09 Nov 2014    Post subject: Reply with quote
Voltage isn't the only test of a battery. Capacity can be reduced near zero and still hold 12V plus.
Do a drop test. Drop it in the bin and buy a new one.
recman
MC wrote:
Bike obviously doesn't like you, I think you should give it to me Wub
But its a Triple! Don't you know how dangerous they are?
Yeah, I know your right.
Even though it seems ok now I don't really want to get caught short again.
PostPosted: 18:29 - 09 Nov 2014    Post subject: Reply with quote
Something like this:
https://www.hobbyking.co.uk/hobbyking/store/uh_viewItem.asp?idProduct=34859
Can easily be carried on a bike and is generally useful to have (I do have various RC stuff I can use it in too, to be fair.)
The item linked will jump start my 2.2lt TD van when the battery won't turn it over at all (just a relay click). So for a bike, you shouldn't need nearly as big/expensive. (Not that it's very big as it is and for the money, offers a lot.)
You will need a charger, however a decent 'balance charger' is useful to have generally and start at around £15 - they can also be used to charge and test the capacity of lead acid batteries.
The last post was made 11 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.07 - MySQL Queries: 13 - Page Size: 83.24 Kb
