| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 13:12 - 03 Nov 2014 Post subject: Wiring in voltage meter thingy.. |
So just bought one of these badboys
as i have a feeling my battery is losing the will to live
how would i go about wiring it up?
ideally i only want it on, when the ignition is on, an also what do i do with the 3rd wire!? |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:46 - 03 Nov 2014 Post subject: |
Black to earth, red to switched live, yellow to battery live. At a guess. If you're feeling posh, pop a fuse on the red wire too. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| bugeye_bob |
 bugeye_bob World Chat Champion
 Posted: 13:55 - 03 Nov 2014 Post subject: |
| Aff |
 Aff World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| WD Forte |
| instigator |
 instigator Super Spammer
 Posted: 14:35 - 03 Nov 2014 Post subject: |
| P.addy |
 P.addy Red Rocket
 Posted: 14:42 - 03 Nov 2014 Post subject: |
No and I don't know why anyone would bother.
Does it give you a decent reading, does it tell you when your reg rec has failed and you are jamming 20v into your battery or when another charging fault has occurred so you aren't getting over 12v.
I like to know what my bike is getting and when so I can stop before the damage happens. |
| Aff |
| instigator |
| mudcow007 |
| Aff |
| mudcow007 |
| P.addy |
 P.addy Red Rocket
| instigator |
| Aff |
| mudcow007 |
 Posted: 16:47 - 03 Nov 2014 Post subject: |
Cheers Aff  |
| smegballs |
 smegballs World Chat Champion
 Posted: 16:50 - 03 Nov 2014 Post subject: |
https://i.imgur.com/G5nnUQx.jpg
My one is littler and I fitted it inside my tacho housing. Uncrimped the tacho bezel, melted two holes with soldering iron and screwed in with glue as a backup.
I took the power off the pilot light for the tacho so it displays the voltage when the sidelights/headlights are on.
Be warned however that it will only show the voltage at the point of insertion, so it will show any voltage drops you might have in the wiring up to that point. For example:
Sidelights on mine reads 14.2V
Headlights on mine reads 13.6V
For both readings the actual voltage across the battery (my R/R is hardwired, with fuse, directly across battery terminals) is 14.4V in all scenarios. What is happening is the as the headlights turn on it pulls more current through all the loom, ignition switch etc etc. The high current then leads to a greater voltage drop at the point of measurement. The battery, with its heavy cables, direct to the R/R doesn't have any of these voltage drops and thus "sees" the whole 14.4V.
One thing I want to do one of these days is to install headlight relays, to get that juicy 14.4V straight across the headlight bulb terminals. Bulbs have a non-linear voltage:brightness relationship so that 0.8V from 13.6V to 14.4V will likely result in much higher brightness.
https://i.imgur.com/hBJTcOQ.png
https://www.danielsternlighting.com/tech/relays/relays.html
| stinkwheel |
| WD Forte |
| mudcow007 |
| The Shaggy D.A. |
| Casper |
 Casper World Chat Champion
 Posted: 21:49 - 03 Nov 2014 Post subject: |
I have one built into my clocks. Not 100% accurate but gives you as close as voltage. Don't you love 80's bikes.
| mentalboy |
 mentalboy World Chat Champion
| MCN. |
 MCN. Banned
 Posted: 23:18 - 03 Nov 2014 Post subject: |
Jesus. Do you guys really have that many charging system related breakdowns you feel the need to clutter up your dash with more tat???  |
The last post was made 11 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
