low end windows laptop or Chromebook?
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
EazyDuz
PostPosted: 19:11 - 04 Nov 2014    Post subject: low end windows laptop or Chromebook? Reply with quote
Budget around 250. Only really want the full page version of websites, ability to have multiple tabs open with no lag. Also editing a spreadsheet with macros, torrents and movie watching and streaming movies to my TV.
Is the Chromebook a viable option or would I be best off with a low end windows 8 laptop?
Tungtvann
PostPosted: 19:17 - 04 Nov 2014    Post subject: Reply with quote
I know one person who had a chromebook, he didn't recommend it.
Ben90
PostPosted: 19:25 - 04 Nov 2014    Post subject: Reply with quote
Most Chromebooks have about 16gb storage, less when loaded with the OS, so no good for torrents unless you delete files after watching them.. External hard drive would work well but that's more £££
Yamaha FZ6 S2
prawny1
PostPosted: 19:29 - 04 Nov 2014    Post subject: Reply with quote
chromebook requires an internet connection to even log on from what I recall, and because a lot of the programs are browser based most of those have limited functionality with out an internet connection.
Driver support is not great with it either. no Skype (Skype is Microsoft) or gaming out of the box unless you want to tweak for more Linux style functionality than the chromebook comes with in the o/s then you can use wine for windows progs and games etc.
Chromebooks rely on cloud storage for the most part so generally fall down on internal storage capacity.
They are cheaper to buy though which is a plus.
You can pick up high end core 2 or a decent 1st/2nd gen core I laptop for £100-200, use the excess for an ssd and a new/ spare battery job done.
hellkat wrote:
EazyDuz
PostPosted: 20:16 - 04 Nov 2014    Post subject: Reply with quote
Do you have an example of such laptop? I'm not that clued up on processors etc
mentalboy
PostPosted: 21:04 - 04 Nov 2014    Post subject: Reply with quote
My missus has a chromebook and it's a pile of shite.
The blasted thing keeps freezing up (look at reviews, it's a common fault)
And, even more annoyingly, she bought it so I could Skype her and it doesn't do Skype... Rolling Eyes
Make mine a Corona.
prawny1
PostPosted: 21:16 - 04 Nov 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/HP-EliteBook-8440p-14-250-GB-Intel-Core-i5-2-4-GHz-4gb-Ram-Webcam-/131336249996?pt=UK_Computing_Laptops_EH&hash=item1e9440228c
https://www.ebay.co.uk/itm/Cheap-Laptop-HP-Elitebook-6930P-2-53GHZ-2GB-60GB-SSD-WiFi-Vista-/251704429159?pt=UK_Computing_Laptops_EH&hash=item3a9ac0ca67
bump the core2 one up with some more ram (8gb max) and maybe a cpu upgrade (t9900 3.06Ghz is probably max depends on chipset), might need to fit a bigger ssd for daily use as it is only 60gb
Even the core 2 laptops have an early form of turbo boost bumping up clocks on one core at a time.
PostPosted: 23:42 - 04 Nov 2014    Post subject: Reply with quote
I have always been highly impressed with anything made by Asus. Their kit all seems to punch well above its weight.
As such, I'm going to recommend stretching your budget by a tenner to get this:
https://www.ebay.co.uk/itm/Asus-X553MA-Laptop-Intel-Celeron-4GB-RAM-1TB-15-6-Black-/171498807515?pt=UK_Computing_Laptops_EH&hash=item27ee2020db
1TB, dual core processor, HDMI output. a USB3.0 and a big screen and it's new not second hand.
prawny1
PostPosted: 01:07 - 05 Nov 2014    Post subject: Reply with quote
that Celeron based laptop looks like it would be slow as fu(( 1.86ghz dual core with 1mb cache,
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Celeron+N2815+%40+1.86GHz
https://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Celeron+N2815+%40+1.86GHz&id=2158
it would be a low power drain on the battery though.
EazyDuz
PostPosted: 10:40 - 05 Nov 2014    Post subject: Reply with quote
I googled core 2 you suggested earlier against a celeron N2830 and the celeron is supposedly slightly faster. Don't really want to buy ram or upgrade CPU, just want to plug and play really. Maybe just hunt around for a good deal.
My previous Acer 5551a ran windows 7 pretty good and did everything I needed so anything similar to that would be fine for me, though it did lag in its older age
prawny1
PostPosted: 12:08 - 05 Nov 2014    Post subject: Reply with quote
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core2+Duo+T9400+%40+2.53GHz
strange this shows the t9400 as almost double the cpu score of the n2815
don't be fooled by it's age mid- high clocked core 2 and 1st/ 2nd geb core I stuff is often better than what is available in low end ultrabooks and notebooks if not on battery life.
It won't matter if the cpu is twice as power efficient if it take it twice as long to perform the tasks you set it, and considering manufacturers are using the power efficiency to reduce weight by removing or shrinking cell overall battery life is largely unchanged.
A lot of ultra books and entry level laptops have bga chips (cpu soldered directly to motherboard) so upgrading later is often not an option.
Is your old laptop dead? have you considered upgrading that,you might be surprised what it is capable of with some higher spec bits in it.
A quick google shows that model was available with a 2.1Ghz 35w n830 triple core cpu officially (paired with 95w power brick) so should in theory be able to take all the 25w and 35w cpu's 45w might be pushing it with the cooling though you would need to check what microcode is in the bios to see exactly what is supported..
ram can take up to 8gb and those models that have a discrete gpu can handle the hd5650 too.
prawny1
PostPosted: 13:10 - 05 Nov 2014    Post subject: Reply with quote
If you would be happy with windows 8 and just won't it for browsing and office stuff have you considered a windows 8 tablet?
the Toshiba encore and encore 2 look reasonable only 1.33ghz but is quad core which can boost to 1.86 when needed, the 7 & 8" screen versions are cheaper because they don't have to buy a licence from Microsoft for them.
https://www.argos.co.uk/static/Product/partNumber/3143029.htm#pdpPromotions
The 7" is available new from argos and a few other places for £100 lower res screen and only 16gb storage rather than 32gb with the newer ones but you get 1tb onedrive storage included.
Running windows will make it far more compatible with generic programs than a chromebook, and comes with a years office 365 subscription.
EazyDuz
PostPosted: 14:52 - 05 Nov 2014    Post subject: Reply with quote
I have a tablet now, a 2012 nexus 7 but its slow now, and I miss faster browsing with a laptop.
No my old one broke and I sold it for spares, shame because it was pretty good.
If I eBay 'laptop' and sort it as best match there are a lot of dell machines being sold as refurbs which look good, some have sold in the hundreds. Have you seen them?
EazyDuz
PostPosted: 14:55 - 05 Nov 2014    Post subject: Reply with quote
Like this?
https://www.ebay.co.uk/itm/WINDOWS-7-DELL-LATITIUDE-LAPTOP-CORE-2-DUO-4-80GHZ-2GB-80GB-WIFI-CHEAP-LAPTOP-/181265566455?pt=UK_Computing_Laptops_EH&hash=item2a34450af7
sensi5446
PostPosted: 18:53 - 05 Nov 2014    Post subject: Reply with quote
Love my HP chromebook, does everything I need it to do apart from downloading torrents. I use a lot of google services like G+ and google docs so it works a treat with them. For general use, surfing the net, youtube, sending email etc its perfect. Can download pics, music, docs straight onto my 64gb pen drive so space isn't a issue.
prawny1
PostPosted: 19:01 - 05 Nov 2014    Post subject: Reply with quote
most of them look like ex big office stock the latitude is the basic run of the mill stuff, the precision range is usually better speced though.
EazyDuz
PostPosted: 19:36 - 05 Nov 2014    Post subject: Reply with quote
Hmm I'm unsure now. Didn't really want a refurb but if the low end new ones are shit I suppose I'll have to. I'm not too fussed which laptop it is as long as its as good as or better than my old one
prawny1
PostPosted: 19:48 - 05 Nov 2014    Post subject: Reply with quote
I know it isn't really a good judging criteria but have a mooch around a few showrooms and check the wei scores for these newer models.
You often see lower clocked amd and intel stuff with score reminiscent of an old pentium m, all in one touch screens seem worst for it.
EazyDuz
PostPosted: 20:16 - 05 Nov 2014    Post subject: Reply with quote
Look at this one if you will
https://www.ebuyer.com/639630-toshiba-satellite-pro-c50-a-1mm-laptop-pscg7e-038041en
My 5551a had this processor (found it on argos reviews, where I bought it from)
https://cpuboss.com/cpus/Intel-Celeron-1005M-vs-AMD-Athlon-II-PCs-P320
Would it be safe to assume something like that will perform similar if not a bit better than my old laptop? It has an extra gig of ram too
mentalboy
PostPosted: 21:38 - 05 Nov 2014    Post subject: Reply with quote
I've got a slightly different model Toshiba C-50 but with the Intel Core i3-3110M Processor which is slightly better quality than the Celeron chipped one you mention - It's a cracking bit of kit (although I'm not a gamer so I couldn't tell you what it's like for that) Thumbs Up
Make mine a Corona.
hmmmnz
PostPosted: 00:00 - 06 Nov 2014    Post subject: Reply with quote
what about a galaxy note 10.1 tablet (£189 delivered)
i have the older version (not the 2014 version)
its got a decent dual core processor, and a couple of gig of ram,
16gig internal memory, also will take a 64gb micro sd card as well,
coupled with a keyboard dock, and a keyboard case, its pretty handy, and has an exceptional battery life
the humans are dead
I kick arse for the lord
prawny1
PostPosted: 13:59 - 06 Nov 2014    Post subject: Reply with quote
the problem with non windows tabs is not all websites work properly with them, they are getting better at it but not quite there yet.
hmmmnz
PostPosted: 22:20 - 06 Nov 2014    Post subject: Reply with quote
surely thats a browser issue rather than an operating system issue,
i have firefox on mine and am yet to come across a website that its had a problem with,
my only complaint with tablets is no frigging right click, i never realised how much i right click the mouse untill i didnt have one
the humans are dead
trevoriv
PostPosted: 23:24 - 06 Nov 2014    Post subject: Reply with quote
I know its over the OP's budget but I've just picked up a surface pro 2 with i5 and 128gb ssd for £365. Granted its another £80 for a keyboard but I'm just using an old Bluetooth keyboard with it at the moment. Still pricey but a decent bit of kit.
panrider_uk
PostPosted: 01:04 - 07 Nov 2014    Post subject: Reply with quote
Don't you just press and hold for a right click?
The last post was made 11 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 132.15 Kb
