1st Gear Trouble
Dave M
PostPosted: 00:28 - 04 Nov 2014    Post subject: 1st Gear Trouble Reply with quote
Right, now I have a problem with 1st gear. In early mornings I don't let the bike warm up as it's a little too noisy and there are a lot of old nice people on my street, it wouldn't be fair on them. Anyway, I roll the bike back and turn so I'm facing slightly downhill on my driveway, start her up, select 1st gear and she struggles as if the gear hasn't engaged fully. I always give it a sharp tap down to get into 1st as I've been told this is the best way! So, I have to flick it up to 2nd asap to get her going. After that she's spot on. This only happens on my drive when I'm facing down a slight hill. It never happens on the flat or even uphill? Could this be related to my previous post which I have just updated? See link below. Cheers for any help!
https://www.bikechatforums.com/viewtopic.php?t=296191
PostPosted: 09:25 - 04 Nov 2014    Post subject: Re: 1st Gear Trouble Reply with quote
weedave wrote:
struggles
Define, please.
Revs rise but the bike doesn't move? = clutch cable is slack, springs are soft, plates are on the way out.
Bike lurches when the gear is engaged? = clutch cable needs tightened or clutch is binding a bit from cold - which is fairly normal, just be ready for it.
Engine hesitates while pulling away? = Nothing to do with the gears.
Taught2BCauti...
PostPosted: 10:31 - 04 Nov 2014    Post subject: Reply with quote
After reading your other post, I definitely think you have a problem with the clutch plates. The 'burning clutch' smell is quite distinctive, and the fact that the problem is worse when facing downhill, when there is probably more oil in the clutch area, suggests you need to remove the clutch cover for a closer look.
I wouldn't just replace the friction plates though, whilst you have everything apart, replace all of the plates, and the springs too, and double-check the basket for wear or damage - to be sure of a thorough job!
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Dave M
PostPosted: 18:19 - 04 Nov 2014    Post subject: Re: 1st Gear Trouble Reply with quote
Rogerborg wrote:
weedave wrote:
struggles
Define, please.
Hi. Sorry. The bike hesitates when pulling away in 1st. Should also have said I've just put a new clutch cable on. When I put cable on I had to wind the handle bar adjuster nearly all the way out to tighten it. This doesn't seem right to me? I've just had an op today so I will be readjusting the cable when I'm back to normal. Anymore advice appreciated. Thanks.
Dave M
PostPosted: 18:22 - 04 Nov 2014    Post subject: Reply with quote
Ok I've been looking at friction plates and springs but wasn't going to change steels as I was under the impression these wouldn't new changing. I'll take your advice on board and give it a good inspection. I have a service manual so I can refer to that. Thanks for advice.
PostPosted: 20:35 - 04 Nov 2014    Post subject: Re: 1st Gear Trouble Reply with quote
Depends. I had to do the same on the Enfield's replacement cable - proudly Made in Britain... Rolling Eyes
Hesitates when pulling away in 1st when cold? What makes you think that's a gear / clutch problem rather than fuelling, or brakes binding? I mean, does it rev but not move?
Dave M
PostPosted: 22:42 - 04 Nov 2014    Post subject: Re: 1st Gear Trouble Reply with quote
Do you mean clutch slip? No it won't rev either. Just get enough to change up to 2nd. It seems fine then.
The last post was made 11 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 55.08 Kb
