yamaha aerox
nicolasjamie
PostPosted: 15:12 - 06 Nov 2014    Post subject: yamaha aerox Reply with quote
hi. i have a yamaha aerox. i have just bought a performance exhaust and had it deristricted. i was wondering is ther anything i need to do to make it run smoothly with a standard engine. i have heard a few things about upjetting but truthly i dont have a clue what this means
map
Mr Calendar
PostPosted: 15:35 - 06 Nov 2014    Post subject: Reply with quote
So you want to de-restrict?
You will not achieve much by just doing the exhaust.
If your scoot not previously hacked you probably need to look into changing the washer at the pulley (they're usually restricted here) and maybe change the rollers. That'll help the back wheel engine keep up with the engine. TBH don't know if you'll need a cdi change.
Sorry if the previous paragraph was a foreign language to you.
Try the search on here or failing that google.
However, as you don't know what a main jet is I'd back away from doing any mods yourself now and be prepared to pay money to someone who does know (not that they say they know or can bodge do the work, someone who actually knows).
...or just wait and get a bigger bike. Speed comes to those who can wait.
...or feel free to join the ranks of ped-boi enthusiasts. I understand there's a regualr meet at McDs (any McDs). Don't forget the uniform of trackies and trainers and learn to perch that helmet on top of your head.
wr6133
PostPosted: 15:40 - 06 Nov 2014    Post subject: Reply with quote
Usually will be jetted lean for emissions if you have properly derestricted it and added a better flowing pipe you may need to alter it. You'll need to find the size of the stock one and then buy a range of larger ones (up to about 10% bigger and all in between). Then get testing (so you'll want a pile of clean plugs too).
A lot of effort for a few MPH as map said just wait till you can have something faster. You are throwing money at something slow to make it less slow but it'll still be stupidly slow. If you really absolutely must do it then get a big bore kit 72 or 80cc is going to do something marginally more meaningful and it's just as illegal as derestricting it anyway.
nicolasjamie
PostPosted: 16:03 - 06 Nov 2014    Post subject: Reply with quote
so really me putting on the new exhaust is not going to make to much difference. thanks for the advise tjhink im just gunna buy a better bike. cant see myself hanging around mcds to much tbh.
c_dug
PostPosted: 16:37 - 06 Nov 2014    Post subject: Reply with quote
To be fair the Aerox wasn't that slow a moped when done properly, you'd probably push 45-50mph out of one if it was done right.
I disagree to an extent about stepping back, we all learn somehow and I certainly knew diddly squat when I started out. Asking advice and knowing who's advice to trust are certainly a decent place to start though.
I'm far from an expert but I'll say this much. To run at it's best an engine has a fairly specific air:fuel ratio, this is basically achieved by balancing the airflow through the engine with the jetting of the carburettor (jets are basically small brass bolts with holes drilled through them in very specific sizes), or on modern engines with a fancy fuel injection system. If the air fuel mixture is wrong it can ultimately kill your engine.
By adding a sports exhaust you have changed how much air can flow through the engine. Assuming it now flows more air you need to allow more petrol in to maintain the correct ratio.
The supplier of the exhaust might be able to tell you the correct jetting, or maybe a scooter forum (though bare in mind what I said about knowing who's advice to trust), one way or another though you will probably want to change the jets.
The actual process of changing them is easy enough if you have access to some tools, and you'll learn a bit along the way too. Cross that bridge when you come to it though, find out what you need first.
map
Mr Calendar
PostPosted: 16:40 - 06 Nov 2014    Post subject: Reply with quote
nicolasjamie wrote:
so really me putting on the new exhaust is not going to make to much difference...
Well, it'll make the thing work a little quieter. However, if you're wanting 50mph+ from a 50cc moped (you didn't say if yours was a 100cc model) then it'll cost a bit of time, effort and money and TBH it's subject to the law of diminishing returns.
nicolasjamie wrote:
...im just gunna buy a better bike...
Nothing wrong with the little aerox. It's been around for years so tried and tested. Just perhaps not suitable for your needs/wants/desires, which is a slightly different thing.
<rant>
IMO 50cc mopeds have their use and place if you're in a major city and used for commute. However, once you get into 40mph, dual carriageways and NSL roads and struggle to keep with the traffic flow (let alone, God forbid, overtake) they're frankly quite dangerous.
The 'wheels to work' organisation(s) use them, I also think that's iffy. With W2W they're used in rural areas as public transport pants. Yet IMO 50cc on NSL country roads aren't right tools for the job. My lad used the scheme and it was good for him. Given he also managed to ride off an unlit road into a hedge. I guess for W2W getting insurance on 125cc kit would kill off the scheme with having to repair/replace machinery too.
</rant>
nicolasjamie
PostPosted: 17:07 - 06 Nov 2014    Post subject: Reply with quote
which jetting would you recommend. for a 50cc
nicolasjamie
PostPosted: 17:08 - 06 Nov 2014    Post subject: Reply with quote
wr6133
PostPosted: 17:11 - 06 Nov 2014    Post subject: Reply with quote
It's not an exact science. You need to find out the stock jet. Then what I would do is buy every size upward to a maximum of 10% up. Get a handful of spark plugs as well. Then try each jet (you tube plug chops/upjetting for a how to) until you get it right.
map
Mr Calendar
PostPosted: 17:20 - 06 Nov 2014    Post subject: Reply with quote
TBH I haven't a clue.
However, google threw up this little article
pedparts.co.uk wrote:
...basic rules are that if you've fitted a sport pipe the jetting should be increased by 10%...
Which is what wr6133 also states above.
That article worth a read as getting your mixture ratio wrong can lead to either being too rich or seizing piston.
Google also hints original main jet is 62 or 64. So somewhere between 70 and 74ish (read posts above, you may need to experiment). Can be had from the likes of WEMoto (Gurtner carb jets - you will need to check your carb.)
wr6133
PostPosted: 17:36 - 06 Nov 2014    Post subject: Reply with quote
You'll want to check it has been derestricted properly as well. I don't know the exact restrictions on your ped but normally you will have a combination of
Electronic - CDI restricition. Either need a replacement or snip a wire
Gearing - The variator will have some kind of ring in there that stops it coming together properly. You'd need to take apart the variator (normally requires an impact gun) and if the ring is present remove it
Fueling - Can be done a few ways but the normal is a bit of extra plastic that stops the carb needle moving fully.
Exhaust - You got that covered
That's just what I've come across doing the ped my wife uses and a few neighbours GY6 based ones. You need to get on google and see if the aerox has any of those or any others.
Once it is derestricted properly you need to get it tuned in right. Part of that is getting the jetting spot on but also the roller weights may need changing (google what they are and what they do).
Now if you are going to go to the trouble of doing all that I'd say buy this and whack it on after you remove all restrictions but before you get it tuned in https://www.ebay.co.uk/itm/Yamaha-Aerox-50cc-Cat-03-11-70cc-Big-Bore-Cylinder-Piston-Gasket-Kit-/400789929688?pt=UK_Motorcycle_Parts&hash=item5d50f0fed8 (this will need rejetting and new roller weights).
Andy_Pagin
PostPosted: 18:02 - 06 Nov 2014    Post subject: Reply with quote
Afterwards remember to inform the DVLA that you've converted it from a Moped to a Motorcycle, tell your insurance company the same, check your licence permits you to ride motorcycles and get a motorcycle MOT if it's old enough to require one.
nicolasjamie
PostPosted: 18:16 - 06 Nov 2014    Post subject: Reply with quote
how do i find the standard rollers size and what to change them too
evoboy
PostPosted: 19:23 - 06 Nov 2014    Post subject: Reply with quote
Telling us what exhaust it is will help...
To go faster on a scooter you need to spend money.
The more you spend the faster it goes.
Is it a Liquid Cooled Aerox or an Air Cooled one with a fan?
The 3 best things you can do to a standard Minarelli engine after de restricting the variator by removing the washer ( this is the only restriction it has) are;
-Sports exhaust.
-17.5mm carb as the standard 12mm one will choke it.
-Setting up the gearbox correctly.
You should see a good 50-60mph ( depending on your weight ).
APT Motorcycles
nicolasjamie
PostPosted: 20:24 - 06 Nov 2014    Post subject: Reply with quote
nicolasjamie
PostPosted: 20:28 - 06 Nov 2014    Post subject: Reply with quote
its a tecnigas q-tre exhaust. its also liquid cooled
c_dug
PostPosted: 11:14 - 07 Nov 2014    Post subject: Reply with quote
This one?: https://www.adrenalin-pedstop.co.uk/p-Tecnigas_QTre_exhaust_system_for_Aerox_Nitro_50_etc-5599.aspx
Might be worth emailing the company in the link for more specialist advice, they only mention needed lighter rollers so it may be that it is designed for the standard jetting.
c_dug
PostPosted: 11:16 - 07 Nov 2014    Post subject: Reply with quote
Or Technigas directly: [email protected]
evoboy
PostPosted: 19:22 - 07 Nov 2014    Post subject: Reply with quote
It should be re jetted.
People have already said the amount you should upjet, 10%.
Non of us know what jets you are currently running.
Non of us know what rollers you are currently running.
APT Motorcycles
Old_Steeve
PostPosted: 16:34 - 08 Nov 2014    Post subject: Reply with quote
First of all at 16 years old moped level I fail to see a better scoot on the market for the money. True you could get a sports moped of italian exotica with the same basic malossi engine and gear and spend an awful lot more on not going any faster.
I have been riding bikes 30+ years and have owned many bikes from the first footings on a FSIE via superbikes like an RGS Corsa, Aprillias, Ducatis and GSXR's and virtually every type of bike you could name over this period. I currently own an Aerox 50 as well as a few other more accepted sportsbikes. Why? Because racing round rural somerset on a radically tuned 70cc moped is a surprisingly fun alternative type of motorcycling. The Minarelli engine is superb, the handling and ridiculously low weight as entertaining as it gets in a lot of ways.
Anyway, the aerox is restricted in the exhaust (check) and the variator only (undo, remove washer and bingo). There is no inbuilt restriction in the carb or cdi although they both benefit from a little bit of fettling.
To get maximum benefit from the pipe you will need a big bore kit, and air filter and before you know it over 10 bhp will be winging through those silly little (corsa shod I hope) wheels and you will be grinning like a cheshire cat on your microlight aerox. Power to weight and therefore acceleration even exceeds the limits for a 125 though top speed will be slower.
My personal favourite resource for all things Aerox is the ridiculously informative ped parts website. Various set ups are explained on there with tutorial guides and how tos. They are also ultra helpful by phone as well. Depending where you are also you can save a lot of trial and error by booking a session on their dyno especially for carb issues and optimising roller weights. This sounds like a plug and it really isn't but they are simply the best I have found for Minarellis by some margin.
You can have tremendous fun on an Aerox, tuning them is a fantastic introduction to learning the mechanical side of motorbikes and mistakes are relatively cheap to correct. As I said mine is a bit over the top and the last dyno run shows 17bhp and it's geared for about 85mph but the look on some peoples faces when they are putting far more effort than expected to keep with a moped on their "proper"bikes or the face of a copper when the helmet comes off and a diminutive 50 year old is grinning back at them is priceless.
Edited for malapropisms Embarassed
Old_Steeve
PostPosted: 17:06 - 08 Nov 2014    Post subject: Reply with quote
_Iain_ wrote:
At a guess,
58-64 main jet, 4.5gr 15x12 rollers & expect an indicated 55-60ish mph. See how it goes on a 64 & a 62 though, as a lot of peds seem to run pretty sweet on one or the other and opt for 4.75gr rollers if you're fat.
Unsure why people seem to think that doubling a vehicles top speed for £75 + an hours work is a complete waste of time & money. Rolling Eyes
Also worth giving Adrenalin Pedstop a call - they're pretty shit hot & have some tables whereby you tell them what your bike is, how much you weigh etc and they'll tell you what jets need to be fitted & what rollers you ought to run. They've helped me a lot in the past with customers having setup issues.
01226 630020
Especially when you think people are quite happy to spend several hundred pounds on an exhaust to make a bike sound nicer and yet a 200% power increase for a third of that isn't worth it.
The last post was made 11 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 130.38 Kb
