head bearings cage keeps releasing
Baron von helmet
PostPosted: 16:12 - 06 Nov 2014    Post subject: head bearings cage keeps releasing Reply with quote
Am re-building my hoda cg and trying to fit a new head set top and bottom bearing's, thought it was an easy enough job but every time i get the bottom bearing almost seated to wear it needs to be the cage has released all the bearings! done it twice now, really frustrating, what am i doing wrong? i have the old bearing case on top and using that to drive the new bearing down. using pyramid bearings. didn't think they would be so fragile as the force required to get them seated is quite a lot.
what's the trick? can't afford to buy any more bearing's!!
cheers.
PostPosted: 16:37 - 06 Nov 2014    Post subject: Reply with quote
They pop back in again.
You using ball bearings or tapered rollers?
Whatever you are using to drive them down with should only be acting against the inner race. Like a bit of pipe.
Baron von helmet
PostPosted: 17:17 - 06 Nov 2014    Post subject: Reply with quote
tapered roller type, the inner race seems to move around a lot, i could almost displace the rollers from there houings by shaking the bearing about. i have a thick washer then a tube over it and drive it down with steady taps from a hammer. first time they just came loose from being moved about second time the inner race split.
gotta wait for the third bearing to turn up now. might just not risk it and take it to a mechanics see if they'd squash it in for me. just dont like the hassle of having someone else do it. least it sounds like im doing it right.
I grease them up a lot, but does'nt seem to stop them just coming out
PostPosted: 20:14 - 06 Nov 2014    Post subject: Reply with quote
The INNER split? That suggests it's either being forced down over too large a diameter or it wasn't going down perfectly square. Check you are ordering the correct bearing of a decent quality. Make sure the metal on the spindle is clean and free of damge and that you tap the bearing down absolutely square. Shouldn't need grease, I'd have it spotlessly clean and clean up any scratches and dings with fine emery paper.
Remember, you should ONLY be hammering against the inner race. Using a washer sounds like you might be clattering the top of the bearing cage too. I've always used a thin piece of pipe as a slide hammer to do this or very slowly and gently tapped it down using a punch and hammer.
Putting the yoke in the freezer and the bearing in the oven might even cause enough expansion/contraction for it to drop almost all the way on. It'll certainly make it easier to get started.
Where you getting the bearings? There are a lot of shitty Chinese ones out there and the tolerances can be all over the place. For a '89 CG125BR you need a 41H/225H and a 41H/24H taper roller bearing. Try your local bearing factors.
Baron von helmet
PostPosted: 12:23 - 08 Nov 2014    Post subject: Reply with quote
Im using these bearings,
https://www.ebay.co.uk/itm/271205913617?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
seems as good as any other. think its a BR04 or something. seems to fit correctly (should the top bearing be smaller than the bottom?) i'll do as you say and run some emery paper over the spindle and try the hot and cold trick, i can't afford to have this next bearing not go on though so may run it into a mechanics if it looks like its not going right. they can press it on for a few quid.
cheers for the replies. no doubt i'll have a many more questions to come.
saying that i do…….How tight should the swing arm bolt be done up? If I do it up to how tight it feels good the arm doesn't move, theres nothing on the bolt/nut either to stop it working loose if its to loose? seems like bearings would be better than bushes.
Suntan Sid
PostPosted: 00:54 - 09 Nov 2014    Post subject: Reply with quote
As you now have some parts from a couple of fubar'd bearings, cut through one of the inner cages with a grinder, use this to drive the new bearing.
Being an inner cage it can only drive onto the new bearing's inner cage, as you've cut a piece out of the cage it will come off the stem with the slightest tap of a hammer!
I've just done exactly this on my project bike!
Baron von helmet
PostPosted: 13:16 - 09 Nov 2014    Post subject: Reply with quote
All good now, followed the advice putting the stem in the freezer and the bearing in the oven for a bit, I also purchased a different brand bearing for the bottom and it went on a lot easier using another bearing inner. Having said that, I used the Inner of the busted bearing and it actually fell to bits while I used a punch on it to seat the bearing. so half way through was just using the punch on the new bearing directly. I was'nt gentle with it either, so for future ref, I wont be buying pyramid bearings again.
Vincent wrote:
If the swingarm is locking up when tightening, there must be something missing from the pivot assembly. Are there end caps with shims inside?
Looking at the haynes for the CG https://die-kleinkraftrad-ig.de/wissensdatenbank/reparaturanleitungcg125.pdf
On page 76, it shows the swing arm and to me what looks like just one long bolt and 2 washers (presuming one either end not both together)
the exhaust mounts to this bolt also I think but wont make any difference in terms of how it moves freely up and down. so I'm a bit stumped by it atm, as it doesn't feel right.
Suntan Sid
PostPosted: 13:42 - 09 Nov 2014    Post subject: Reply with quote
Have a look at this video for installing steering head bearings.
Real world, no fancy tools used, worth a watch!
They're ozzies, but no ones perfect!
https://m.youtube.com/watch?v=_Ozfh93CvBs
Baron von helmet
PostPosted: 15:40 - 09 Nov 2014    Post subject: Reply with quote
Vincent wrote:
When you tighten the swingarm up, the pressure should be on the bushes, (N0. 12 in the pic), and not the swingarm itself.
But if the bushes in the swing arm are solid, as that's their design, and pressed in, when you tighten down the bolt the washer will be on the metal inner of the bush and this will have the same effect. as the bush
(and it's inner) are solid and don't rotate, so will be just metal on metal contact and the tighter I go (because I don't want the nut working loose)
the more it will just bind up. It does seem like there's something missing in the way it all works.
PostPosted: 21:32 - 09 Nov 2014    Post subject: Reply with quote
Never use a punch on a bearing, the hardened punch can split the hardened bearing race as you have found. Use a drift - a piece of material softer than the part you're moving. Mild steel, brass, copper, aluminium etc.
Another thing to watch out for is that you don't mar the stem when removing the old bearing. If you raise a burr then try to press the new bearing over it you will very likely split the race there too.
The last post was made 11 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 93.18 Kb
