| tmsjns |
 tmsjns L Plate Warrior
| john24ssj |
 john24ssj Trackday Trickster
| Fizzer Thou |
 Posted: 10:18 - 07 Nov 2014 Post subject: |
Do you have one of the hoses looped over the back of the front mudguard?If so,it is quite likely that there is air trapped in the top of the loop.If you remove the caliper and can bleed it with the hose straightened upwards,you should be able to get rid of the air.Might take two people to do this as it can be awkward.
As for the master cylinder,try and get this pointing slightly downward.Pull the lever in about 20mm at a time and look for air bubbles rising through the bleed holes in the bottom of the reservoir.Keep doing this until no more bubbles appear,then bleed normally.
There are a few good videos on youtube that are worth watching  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| wr6133 |
 wr6133 World Chat Champion
| MeatHelmet |
 MeatHelmet Scooby Slapper
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
