COLD START PROBLEM
RHBIKER
PostPosted: 00:16 - 07 Nov 2014    Post subject: COLD START PROBLEM Reply with quote
I have a 2008 Aprilia 750 Shiver that I bought this summer, I love it and it has been fine for several months, now the weather has changed I have hit a problem, the bike will not start when cold, its a nightmare, almost flattens the battery before it fires up.
The battery is kept on a trickle charge and has been tested so its not that, the starter is also ok, engine turns over it just want start, I do notice a strong smell of petrol, any idea's what is wrong with it.
I have bought some new plugs but not convinced this will resolve the problem.
RH.BIKER
Fisty
PostPosted: 00:32 - 07 Nov 2014    Post subject: Reply with quote
Just because it's on a trickle charger does not mean it's not the battery. Cold weather kills them. I'd bet Smilers virginity that the battery is your problem.
Fatter and faster than Fret
alt tab
PostPosted: 00:35 - 07 Nov 2014    Post subject: Reply with quote
Have you checked the subframe? It is commonly known that the 2008 Shiver's have big issue with the subframe warping during the colder months of the year, leading to issues with starting.
As you rightly say, you've trickled charged the battery, so that is definitely fine. Personally, I would go to a local motorcycle garage and ask them to measure the subframe dimensions. They have laser rigs for this purpose, it should only cost around £15.
HTH Thumbs Up
CaNsA
PostPosted: 00:36 - 07 Nov 2014    Post subject: Reply with quote
HTH Thumbs Up
Nice effort, but you still fail at BCF
alt tab
PostPosted: 00:37 - 07 Nov 2014    Post subject: Reply with quote
HTH Thumbs Up
I know, Cansa, I know. Sad
DottyDuck
PostPosted: 00:43 - 07 Nov 2014    Post subject: Reply with quote
maybe the bike is shivering? put a quilt on it.
https://i1.kym-cdn.com/photos/images/original/000/434/244/817.png
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
Fisty
PostPosted: 00:46 - 07 Nov 2014    Post subject: Reply with quote
Go make me a sammich.
RHBIKER
PostPosted: 01:01 - 07 Nov 2014    Post subject: Reply with quote
Thanks for the replies, will try a new battery and a duvet cover, may even treat it to a hot chocolate, will try anything at this point.
RH.BIKER
DottyDuck
PostPosted: 01:11 - 07 Nov 2014    Post subject: Reply with quote
Don't forget the marshmallows and cream.
p.s hope you get it fixed Thumbs Up
ADSrox0r
PostPosted: 07:54 - 07 Nov 2014    Post subject: Reply with quote
If it makes you feel any better I have a similair issue with the Viffer. Starts fine until the temps drop below 5 degrees, then when you crank it over the revs drop to 800 or below then stall out unless you hold the throttle till it warms. Fast idle works fine normally and will fast idle once stabilised. I suspect wax idle unit fuckery but it's a dog to diagnose.
If your bike has a wax idle control then check that out, see if it's sticking.
The last post was made 11 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 66.67 Kb
