brakes stuck after replacing wheel
ultinator
PostPosted: 23:49 - 06 Nov 2014    Post subject: brakes stuck after replacing wheel Reply with quote
Hi i swapped my rims, and remounted the discs. at no point whilst the callipers were off was the brake lever pressed. I managed to get the callipers back on and bolted up.
now the wheel it stuck, it seems to be stuck on the brake pad that doesnt move with the (piston) as in the one in the inside of the wheel,
is it possible i tightened them too much and this has brought it into contact? its dark and raining so i havent been able to play around much, and i havent ridden it anywhere yet.
thanks guys
PostPosted: 23:55 - 06 Nov 2014    Post subject: Reply with quote
Check that the caliper is free to slide. There is a carrier that bolts to the fork which has a couple of pins on which the caliper body slides. These often stick.
ultinator
PostPosted: 00:29 - 07 Nov 2014    Post subject: Reply with quote
hi thanks for the quick reply. i wont be able to check anything tonight, but i been reading and could it be that i tightened the axle too much? i kind guessed as i dont have a torque wrench - which im thinking maybe i should have used?
Raffles
PostPosted: 00:50 - 07 Nov 2014    Post subject: Reply with quote
It might be an idea to disassemble and ensure that you have replaced all spacers etc and in the correct order.
Eddie Hitler
PostPosted: 01:00 - 07 Nov 2014    Post subject: Reply with quote
99% it's the pistons, unless you messed the spacers up which is hard to do.
ultinator
PostPosted: 01:06 - 07 Nov 2014    Post subject: Reply with quote
i saw the shims/spacers as exactly the same size and thickness, so i havent really thought much about that, and the spacer bit in the middle is a little loose. but its the same as the old rims i removed.
so maybe the shims/spacers are differnt,
or maybe the callipers need a little jiggle or two,
or maybe its the pistons (and what would i do to sort that?)
or maybe the axle bolt it over tightened,
or maybe i should call a professional ha
dont know if it helps, but the wheel was freely moving before i swapped them
PostPosted: 19:07 - 07 Nov 2014    Post subject: Reply with quote
Nope. That should make no difference at all (unless you tighten the spindle enough to crush the spacer in the middle of the wheel - no chance of that).
The last post was made 11 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 52.23 Kb
