Nail in the back of a fairly new tyre
Barton316
PostPosted: 16:38 - 07 Nov 2014    Post subject: Nail in the back of a fairly new tyre Reply with quote
Hi guys,
New bike, had it for around 3 weeks and i've been punished with a nail in the back of my tyre (why did this not happen with my 125??). I'm going garage tomorrow to get it plugged. I'm wondering if this is purely a short term solution? How long do they last? As I don't want to be stuck 30 miles from home with a flat tyre.... Trying to work out whether its worth buying a new tyre. It's super annoying as these tyres dont even have 500 miles on them!
Casper
PostPosted: 16:47 - 07 Nov 2014    Post subject: Reply with quote
Depends who you listen to or how paranoid you are. Me, a professional plug will last the life of the tyre or even a home plug job if you do it correct. Others will say temp but I would only say temp if close to or in the side.
Barton316
PostPosted: 17:59 - 07 Nov 2014    Post subject: Reply with quote
That makes me feel a bit better. Didn't fancy forking out for a brand new tyre when there are christmas presents that need buying. It's more or less bang in the middle of the tyre, so hopefully this should make it easier. Will also let the garage plug it for me as i don't trust myself lol.
monkeybiker
PostPosted: 18:53 - 07 Nov 2014    Post subject: Reply with quote
If the tyre is removed and plugged from the inside it should be a permanent repair.
Some people don't like plugged tyres but I don't think it's based on any facts more they just don't ''feel'' safe about them.
I've plugged my own tyres before and not had a problem.
Nash GT
PostPosted: 19:21 - 07 Nov 2014    Post subject: Reply with quote
Plus one on the professional plug Thumbs Up
Suzuki GSF600N
iooi
PostPosted: 19:25 - 07 Nov 2014    Post subject: Reply with quote
What make of Tyre?
As Avons have a guarantee if wear is less than a certain amount.
Andy_Pagin
PostPosted: 19:26 - 07 Nov 2014    Post subject: Reply with quote
I find the rubber string thingies I use for roadside puncture repairs last the life of the tyre and never leak, so a professionally fitted tyre plug should be even better.
evoboy
PostPosted: 19:40 - 07 Nov 2014    Post subject: Reply with quote
Have done trackdays on plugged tyres before.
As long as it is done correctly, it will be a permanent repair.
APT Motorcycles
sidewinder
PostPosted: 19:42 - 07 Nov 2014    Post subject: Reply with quote
My rear tyre got plugged 6k ago still not blown up or flattened Middle Finger
mentalboy
PostPosted: 21:59 - 07 Nov 2014    Post subject: Reply with quote
I plug my own (but then I suppose that owning a tyre machine puts me more in the professional category Wink ) and have ridden on plugs down to the tyre's nylon belting, at speeds approaching that of the speed of sound. Wink
No kittens have been killed - yet!
I suppose it all depends upon your approach to risk taking and whether your sphincter will clench up every time you exceed 50mph, only you can answer that one.
Make mine a Corona.
Copycat73
PostPosted: 09:39 - 08 Nov 2014    Post subject: Reply with quote
I would just fit an inner tube to the tire of a 125...
even if it is tubeless
caveat emptor
totalllama82
PostPosted: 23:14 - 08 Nov 2014    Post subject: Reply with quote
No problems with a professional plug in the rear of the tyre. I'm a little more wary about the front having one.
The tyre I had before the current one had a plug for near enough it's whole life. No problems what-so-ever even hitting triple figures regularly.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
Barton316
PostPosted: 12:32 - 21 Dec 2014    Post subject: Reply with quote
Well I plugged it and all was fine.... until on Friday I had went into a nail. Get to the garage to get it plugged again and then they see ANOTHER nail! This one was on the edge of the tyre plus plugging it three times doesn't sound smart. So there I am sat in the garage forking 150 quid over for getting a new tyre with it fitted. I'm sure I could have possibly got it a bit cheaper but when your stuck in a garage with one wheel you're not too bothered.
They put in some Bridgestones BT-023 on. No idea if they're good but hopefully they should be.
Was gutted as well as those tyres probably had no more than 1100 miles on.
MattEMulsion
PostPosted: 14:04 - 21 Dec 2014    Post subject: Reply with quote
I would be trying to work out where I was picking up so many nails and modifying my routes to avoid them at this rate.
Yamaha YZF-R6
Triton Thrasher
PostPosted: 14:11 - 21 Dec 2014    Post subject: Reply with quote
I think he's saying it's not a 125. I don't think I'd trust a tube in a tubeless tyre at 180mph.
Which side is the back of a tyre anyway?
Rrrrrrrrrrrrrrrrrr
Andy_Pagin
PostPosted: 14:24 - 21 Dec 2014    Post subject: Reply with quote
Didn't someone on BCF once plug a tyre something ridiculous like twenty times without a problem?
I run on BT-023s, found them to be good tyres.
Copycat73
PostPosted: 18:35 - 21 Dec 2014    Post subject: Reply with quote
yeah .. mis-read Thumbs Up
I don't think I'd trust a tube in a tubeless tyre at 180mph.?
I fitted to a 1998 CBR1000f .. only a 156 mph though Wink
caveat emptor
ADSrox0r
PostPosted: 19:59 - 21 Dec 2014    Post subject: Reply with quote
I run BT-023s, very reliable and confidence inspiring rubber. It's the earlier Battlax tyres that were notoriously shite.
Islander
PostPosted: 21:01 - 21 Dec 2014    Post subject: Reply with quote
I repaired a rear puncture on my Hornet with sticky string earlier this year and it's been just fine. Thumbs Up
mentalboy
PostPosted: 22:57 - 21 Dec 2014    Post subject: Reply with quote
Are you having a laugh??? The Battlax did for tyres what Sinclair did for home computing a decade earlier.
Make mine a Corona.
PostPosted: 09:20 - 22 Dec 2014    Post subject: Reply with quote
Third time is enemy action. Unbaffled at unsociable hours?
Doovy
PostPosted: 11:03 - 22 Dec 2014    Post subject: Reply with quote
I would definitely check to work out how you're picking up so many punctures.
I would also get this kit, it is amazing and is a professional plug without removing the tyre. BCF peeps have seen me plug a tyre in 5 minutes flat with this kit and be on the go again.
Barton316
PostPosted: 11:16 - 22 Dec 2014    Post subject: Reply with quote
Yes I'm unsure exactly why I'm getting so many nails. I work at a school (teacher) and I am going in between 2 buildings (the school and a youth centre I also teach at during the day). The 2 buildings are in a residential area so no idea why I'm getting so many punctures.
There's a tiny chance it could be some little bastard kids but I'm pretty doubtful of that. I park my bike on the curb near the salt bin at my school though and there has been glass around that area, so It wouldn't suprise me about the nails.
Just have to be extra vigilant on where I park from now on lol...
Doovy
PostPosted: 11:22 - 22 Dec 2014    Post subject: Reply with quote
Yes. And get the kit I've recommended too.
PostPosted: 12:49 - 22 Dec 2014    Post subject: Reply with quote
Are you on commission? Wink
I agree do though, I'd recommend that one (although perhaps not at that price). I had a puncture on the Burgman that strings weren't sealing properly, and that mushroom kit sorted it right out.
The last post was made 11 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 127.97 Kb
